Duh Lost My Key #63089
05/25/08 09:52 AM
05/25/08 09:52 AM
Lost and Spaced
bboogieart Offline OP
Lost and Spaced
I lost my key to an 81 Dodge Van.
Does any one know how I can take the colmn apart so I can start and move the thing, with out wrecking the whole mess. I at least need to unlock the stearing, so I can pull it into the back yard.
Thanx in advance folks.
Re: Duh Lost My Key [Re: bboogieart] #63090
05/25/08 09:57 AM
05/25/08 09:57 AM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
You can remove the steering wheel to gain acces to the ignition switch.
You will need a small punch, or stiff wire to push the locking pin in to slide the ignition switch out.
You could then change the ignition switch, or if you are parting this, or dont plan on having it stolen you can remove the small metal plate off the ignition switch and drop out all the pins and springs... now any mopar key will start it.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Duh Lost My Key [Re: bboogieart] #63091
05/25/08 10:00 AM
05/25/08 10:00 AM
State of Confusion
hp383 Offline
hp383  Offline
State of Confusion
also if this van doesnt have a steering wheel lock, you could just hot wire it by running a wire from the battery + to the ballast resistor, and then jumping the starter.
Re: Duh Lost My Key [Re: hp383] #63092
05/25/08 10:00 AM
05/25/08 10:00 AM
Lost and Spaced
Lost and Spaced
hp 383 thank you very much.
Yeah it's for parts just need to get it moved.
Re: Duh Lost My Key [Re: bboogieart] #63093
05/25/08 12:25 PM
05/25/08 12:25 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Aren't all '78+ vans for parts?
Re: Duh Lost My Key [Re: In_The_Pink] #63094
05/25/08 12:30 PM
05/25/08 12:30 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Isn't the door key the same on that model, pull the door cylinder and take it to a lock smitha nd he car cut you a key. Another option is to drill the cylinder out from the key slot using progressively larger bits until you release the tumblers. I believe removing the wheel and pushing the pin wont release the ignition switch until the key is turned.
Careful, your character's showing!
Re: Duh Lost My Key [Re: In_The_Pink] #63095
05/25/08 02:54 PM
05/25/08 02:54 PM
Lost and Spaced
Lost and Spaced
Come on Casey you oughta know My van is a 77
parts van is 81
hp383 I got it apart, had to remove a little more than stated but you got me on the right track.
Now I can cut my grass as the parts van has been driven to the back yard.
Thanx every one fer da help.
Re: Duh Lost My Key [Re: mopar346] #63096
05/25/08 02:59 PM
05/25/08 02:59 PM
Lost and Spaced
Lost and Spaced
Thanx for yer imput,
check the pick fer future reference.
Once everything is out the cylider comes right out when the pin is pushed in.Didn't want to wait fer locksmith, gotta cut the grass befor my yard turns into a hay field.
