Piston weight difference, OK? #630812
03/04/10 10:32 PM
03/04/10 10:32 PM
Lexington,VA
68gtxsurvivor Offline OP
Lexington,VA
I have a balanced assembly, crank,rods,pistons. I am wanting to switchout the pistons to gain more compression. The pistons balanced to the kit weigh 658grams, the pistons I want to use weigh 640 grams. Do I need to rebalance the setup or will it be ok?
Re: Piston weight difference, OK? [Re: 68gtxsurvivor] #630813
03/04/10 11:05 PM
03/04/10 11:05 PM
The Great White North
RAMM Offline
RAMM  Offline
Absolutely a-ok. I wouldn't worry at all. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: Piston weight difference, OK? [Re: 68gtxsurvivor] #630814
03/04/10 11:17 PM
03/04/10 11:17 PM
Florida STAYcation
dOoC Online penguin-006
The village idiot's idiot
dOoC  Online Penguin-006
Florida STAYcation
That is known as a crank OVERbalance .... this is cool.
Re: Piston weight difference, OK? [Re: 68gtxsurvivor] #630815
03/05/10 01:22 AM
03/05/10 01:22 AM
there is 28.? some grams to a ounce, so the new pistons would be around 2/3 of a ounce lighter than the old ones. BTW, does the piston wieghts you furnished include the wrist pins on both or not? Are the rings the same sizes on both sets of pistons, IE 1/16, 1/16 , 3/16 or are they different sizes like 5/64 on one set and 1/16 on the others?
Re: Piston weight difference, OK? [Re: Cab_Burge] #630816
03/05/10 11:01 AM
03/05/10 11:01 AM
NC
440Jim Offline
440Jim  Offline
NC
The piston weight difference is about the magnitude of doing a 50% balance compared to a 51% balance (or 49%). So if you have a reason to need other than the normal 50% balance, that is in the ball park.
But if you want a balanced assembly, and the normal 50% is right for the application, then it needs to be rebalanced to match the new pistons. I would rebalance the crank.
Re: Piston weight difference, OK? [Re: 440Jim] #630817
03/05/10 11:39 PM
03/05/10 11:39 PM
Lexington,VA
Lexington,VA
They are same ring size, weight is without the pins. One set is Ross the other is Diamond.
Re: Piston weight difference, OK? [Re: 68gtxsurvivor] #630818
03/05/10 11:56 PM
03/05/10 11:56 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
Best weigh the pins and retainers also. Some times BIG difference in weight between mfg's
