Re: Piston weight difference, OK?
[Re: 68gtxsurvivor]
#630813
03/04/10 11:05 PM
03/04/10 11:05 PM
Posts: 1,051 The Great White North
RAMM
Absolutely a-ok. I wouldn't worry at all. J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
[Re: 68gtxsurvivor]
#630815
03/05/10 01:22 AM
03/05/10 01:22 AM
Posts: 43,200 Bend,OR USA
Cab_Burge
there is 28.? some grams to a ounce, so the new pistons would be around 2/3 of a ounce lighter than the old ones. BTW, does the piston wieghts you furnished include the wrist pins on both or not? Are the rings the same sizes on both sets of pistons, IE 1/16, 1/16 , 3/16 or are they different sizes like 5/64 on one set and 1/16 on the others?
[Re: 68gtxsurvivor]
#630818
03/05/10 11:56 PM
03/05/10 11:56 PM
Posts: 2,046 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
They are same ring size, weight is without the pins. One set is Ross the other is Diamond.
Best weigh the pins and retainers also. Some times BIG difference in weight between mfg's
