3 & 4 Speed Manual Transmission #63068
05/25/08 08:59 AM
05/25/08 08:59 AM
Germany
SPS Offline OP
SPS  Offline OP
Germany
Hello,
i have a couple questions about the 3 & 4 Speed Manual Transmissions.
A Smallblock A-Body with a 3 Speed Manual has the same body hump, bellhousing and tailshaft like the 4-Speed cars, right ?
Or are the parts different to the 4 Speed cars ?
If i would swap the 3-speed to a 4-speed, i can use the tailshaft from the 3-speed, right ?
Is for a smallblock A-Body, a manual 4-speed trans with iron housing or a trans with aluminium housing better ?
The aluminium housing would be better i think because the reduced weight from the trans.
Or is a iron housing better, because its stronger like the aluminium housing.
Thanks for answering my questions.
Greets from Germany
Re: 3 & 4 Speed Manual Transmission [Re: SPS] #63069
05/25/08 01:49 PM
05/25/08 01:49 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
All you need to do is go to www.bigblockdart.com they have all the information you may need.
The hump and and crossmember are the same,the shifter,clutch linkage,bell,and tailshaft are different as far as I know.
Gus
64 Plymouth Savoy
Dana 60
Re: 3 & 4 Speed Manual Transmission [Re: SPS] #63070
05/30/08 04:03 PM
05/30/08 04:03 PM
Germany
SPS Offline OP
SPS  Offline OP
Germany
Re: 3 & 4 Speed Manual Transmission [Re: SPS] #63071
05/30/08 04:26 PM
05/30/08 04:26 PM
P
Paul_Fancsali Offline
P
You can change over from a 3-4spd no problem you will need a new Yoke as 3 spd is different from the 4 spd If the 3 spd is col mounted the floor will not have the hump. Use the aluminum bell housing as scatter shield can be a real pain if you do not know what you are doing. However forget that if you plan on regularly racing go with a safety shield
Re: 3 & 4 Speed Manual Transmission [Re: Paul_Fancsali] #63072
05/30/08 09:27 PM
05/30/08 09:27 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
So and A-body 3-speed's (A-230?) output shaft is the larger size (same as a 727's)?
Re: 3 & 4 Speed Manual Transmission [Re: In_The_Pink] #63073
05/30/08 09:34 PM
05/30/08 09:34 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
A/F short A230 has small spline like 904 and long tailshaft B/E/Truck has 30-spline output like 727. And about an A230 tailhousing bolting to an A833, it not even close to to the same bolt pattern. Also the A230 uses 3/8" bolts where the A833 uses 7/16" bolts for the tailhousing to main case bolts.
Re: 3 & 4 Speed Manual Transmission [Re: SPS] #63074
05/31/08 10:45 AM
05/31/08 10:45 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
I just pulled a 3 speed. Mine was column shift. Slip yoke no worky with the 833OD.
If you need a 4 speed hump get an original for ease of installation.
Nobody will tell you that the repop ones are for 75 and 76 Abodies. Extra metal work will be required!
My clutch linkage works just fine. Mine is a slant!
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: 3 & 4 Speed Manual Transmission [Re: Rug_Trucker] #63075
05/31/08 10:46 AM
05/31/08 10:46 AM
Rug_Trucker Offline
Rug_Trucker  Offline
BTW the 3 speed was the same length as the 4 speed.
Re: 3 & 4 Speed Manual Transmission [Re: Rug_Trucker] #63076
05/31/08 03:48 PM
05/31/08 03:48 PM
Germany
SPS Offline OP
SPS  Offline OP
Germany
Hi,
thanks for the answers.
The car has a 3-Speed on the floor.
So the change to 4-Speed is easier.
Re: 3 & 4 Speed Manual Transmission [Re: SPS] #63077
05/31/08 04:41 PM
05/31/08 04:41 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
I'd also like to know if the 3-spped and 4-speed floor humps are the same, so I'm givng you a
Rug- was the 4-speed you tried the 3-speed slip yoke on/in an A/F-body or a B/E/Truck A-833?
Re: 3 & 4 Speed Manual Transmission [Re: In_The_Pink] #63078
05/31/08 06:00 PM
05/31/08 06:00 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Depends.
Early A bodies had a unique bellhousing for the htree speed and the four speed, they will not swap. Later A's had a common three and four speed bellhousing, will swap. If it's the later A then the clutch linkage swaps too.
I believe the humps are the same, if both are floor shifters obviously.
Don't be the exception.
Re: 3 & 4 Speed Manual Transmission [Re: Supercuda] #63079
06/05/08 01:42 PM
06/05/08 01:42 PM
Germany
SPS Offline OP
SPS  Offline OP
Germany
Hi Supercuda,
from what year starts the "later A" that you mean ?
Re: 3 & 4 Speed Manual Transmission [Re: SPS] #63080
06/07/08 09:21 PM
06/07/08 09:21 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
67 and up are generaly the late A's, but hte commonality of bellhousing patterns started later than that, I am not exactly sure when, I want to say 1970, but basically if it's aluminum it has both patterns.
Re: 3 & 4 Speed Manual Transmission [Re: Supercuda] #63081
06/09/08 08:16 PM
06/09/08 08:16 PM
Rug_Trucker Offline
Rug_Trucker  Offline
If you are talking SB or BB maybe so. Not on my 72 slant 3 speed housing.
Re: 3 & 4 Speed Manual Transmission [Re: Rug_Trucker] #63082
06/09/08 09:16 PM
06/09/08 09:16 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
67-76 3&4 speed A-body humps are the same within any respective year
