Re: Motor plate waterpump sealing questions???
[Re: 440Jim]
#630654
03/06/10 10:57 AM
03/06/10 10:57 AM
Posts: 603 Central Oregon
Rodney
Central Oregon
Using gaskets with the motor plate will eventually work loose and cause a water leak. I have great success with just RTV. I am using studs, and that holds up the engine even if I have to take off the water pump or timing cover.
same here studs are a must IMO. make sure all surfaces are clean and flat {180 wet dry on a piece of glass to level surfaces} before assembly.
[Re: nosboy]
#630656
03/07/10 07:20 PM
03/07/10 07:20 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
I think I'll go with they YAMABOND theory for now.. You guys confused the HECK out of me.... aT LEAST i HAVE ANOTHER DIRECTION IF IT does leak!!! Thanks Guys.....
I hope you have a 1 piece motor plate Nothing wrong with either set up but most gaskets don't stand up well to torsional stress.
Best of luck!
[Re: roadhazard]
#630657
03/07/10 08:43 PM
03/07/10 08:43 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
For those of you looking for the Superperformance gaskets, I stock them here. I have PM'd a few of you. I even stock the ever popular Twin Turbo Yugo Defibulator gaskets in the MP-15. You oughta see them. Let me know if I can help, either PM or compwedgeracing@aol.com.Thanks Todd
RIP Monte Smith
