Re: Motor plate waterpump sealing questions??? [Re: nosboy] #630651
03/05/10 03:25 PM
03/05/10 03:25 PM
Az
Crizila Offline
Crizila  Offline
Az
So Gary, does this thread answer your question
Fastest 300
Re: Motor plate waterpump sealing questions??? [Re: nosboy] #630652
03/06/10 10:22 AM
03/06/10 10:22 AM
NC
440Jim Offline
440Jim  Offline
NC
Using gaskets with the motor plate will eventually work loose and cause a water leak. I have great success with just RTV. I am using studs, and that holds up the engine even if I have to take off the water pump or timing cover.
Re: Motor plate waterpump sealing questions??? [Re: nosboy] #630653
03/06/10 10:33 AM
03/06/10 10:33 AM
charlotte nc
jimmysarrow Offline
jimmysarrow  Offline
charlotte nc
I have tried both ways , just gaskets or just RTV, and had leaks.Started using fel-pro gaskets with a lite coat of rtv on both sides of gaskets and no leaks, been doing this for about 5 years.
Re: Motor plate waterpump sealing questions??? [Re: 440Jim] #630654
03/06/10 10:57 AM
03/06/10 10:57 AM
Central Oregon
Rodney Offline
Rodney  Offline
Central Oregon
same here
studs are a must IMO.
make sure all surfaces are clean and flat {180 wet dry on a piece of glass to level surfaces} before assembly.
Re: Motor plate waterpump sealing questions??? [Re: nosboy] #630655
03/07/10 04:21 PM
03/07/10 04:21 PM
Chicago,Illinois
N
nosboy Offline OP
nosboy  Offline OP
N
Chicago,Illinois
I think I'll go with they YAMABOND theory for now.. You guys confused the HECK out of me.... aT LEAST i HAVE ANOTHER DIRECTION IF IT does leak!!! Thanks Guys.....
Re: Motor plate waterpump sealing questions??? [Re: nosboy] #630656
03/07/10 07:20 PM
03/07/10 07:20 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I hope you have a 1 piece motor plate
Nothing wrong with either set up but most gaskets don't stand up well to torsional stress.
Best of luck!
Re: Motor plate waterpump sealing questions??? [Re: roadhazard] #630657
03/07/10 08:43 PM
03/07/10 08:43 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
For those of you looking for the Superperformance gaskets, I stock them here. I have PM'd a few of you.
I even stock the ever popular Twin Turbo Yugo Defibulator gaskets in the MP-15. You oughta see them.
Let me know if I can help, either PM or compwedgeracing@aol.com.
Todd
RIP Monte Smith
Re: Motor plate waterpump sealing questions??? [Re: nosboy] #630658
03/21/10 07:29 PM
03/21/10 07:29 PM
Chicago,Illinois
N
nosboy Offline OP
nosboy  Offline OP
N
Chicago,Illinois
Well, I used SILICONE ( red high temp rtv) between the motor plate and block and I used Gaskets with the same silicone between the plate and the block!!! I tightened the SNOTS out of the 6 socket head cap screws (csr electric pump) and HOPEFULLY she doesnt leak!!! A little combination of both ideas!!! Thanks for the ideas and info... Gary Oles nosboy
