What is this marking ?????? #630090
03/03/10 10:12 PM
03/03/10 10:12 PM
dark side of the moon
Dougsmopars Offline OP
I'm restoring a 68 GTX. I saw a restored 68 and it had the number 16 hand written in marker on the drivers valve cover on front of cover behind power steering pump. Today i see a restored 69 A12 Road Runner on ebay it has 23 on front of drivers cover. What is this number/marking mean?
Re: What is this marking ?????? [Re: Dougsmopars] #630091
03/04/10 08:04 AM
03/04/10 08:04 AM
colorado
a12superbee Offline
a12superbee  Offline
colorado
60 views and no replies. I'll stick my foot in my mouth.
I want to say it's the last two digits of the entire engine assembly part number.
Not to be confused with the engine code as seen on the fender tag.
I'm sure someone will be along shortly to correct if necessary.
I can't afford this. mark
Re: What is this marking ?????? [Re: a12superbee] #630092
03/04/10 11:03 AM
03/04/10 11:03 AM
Lansing, MI
70gtx440dana Offline
Lansing, MI
I am interested as well. I have an original 70 440HP motor. It has a number on each valve cover in front. However, they are not the same #. Was this an inspection #?
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: What is this marking ?????? [Re: Dougsmopars] #630093
03/04/10 11:11 AM
03/04/10 11:11 AM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
engine assembly codes, same as found on the buildsheet - one desiginates options( such as with or without A/C or 6 pack versus 4 barrel as an example) and the other is trans combinations
Re: What is this marking ?????? [Re: gtx6970] #630094
03/04/10 11:32 AM
03/04/10 11:32 AM
Long Island, NY
shakerjoe Offline
shakerjoe  Offline
Long Island, NY
I agree
Re: What is this marking ?????? [Re: Dougsmopars] #630095
03/04/10 03:02 PM
03/04/10 03:02 PM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
I've also heard that it was the number of that years motors "twentythird" 440 6pak. I saw it on a HEMI and was told that, but everyone elses reasons make sence too.
Re: What is this marking ?????? [Re: DANA60] #630096
03/04/10 03:46 PM
03/04/10 03:46 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Bill & Shaker are correct; engine & trans codes.
Re: What is this marking ?????? [Re: topside] #630097
03/04/10 05:38 PM
03/04/10 05:38 PM
So what would be correct for a 68 with 440 4 barrel? No build sheet with car. The 68 i saw had 16 on one cover nothing on the other cover
Re: What is this marking ?????? [Re: topside] #630098
03/04/10 09:52 PM
03/04/10 09:52 PM
Ft. Worth, TX
TransAm Twins Offline
Ft. Worth, TX
Were these markings only applied to 440, 440-6 & Hemis? Don't think I have ever seen them on anything else.
Re: What is this marking ?????? [Re: TransAm Twins] #630099
03/04/10 10:19 PM
03/04/10 10:19 PM
MO
cdp Offline
cdp  Offline
MO
I had a 40k mile 69 318 Cuda and the #'s were marked on the covers.
Wish I still had the pics.
One side was trans code, the other engine/carb combo I think.
This is some reference pics of a 5k mile 69.5 superbee 440-6.
Re: What is this marking ?????? [Re: cdp] #630100
03/04/10 10:19 PM
03/04/10 10:19 PM
MO
cdp Offline
cdp  Offline
MO
pass. side.
Re: What is this marking ?????? [Re: cdp] #630101
03/05/10 01:20 AM
03/05/10 01:20 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
pass. side.
The passenger's side numbers on this A12 are the last three digits of the engine part number for a 440 - 6bbl -2946950 with an automatic transmission.
2946949 in the engine part number for a 440 - 6bbl engine for a manual transmission.
MikeR
Re: What is this marking ?????? [Re: A12] #630102
03/05/10 09:06 AM
03/05/10 09:06 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
I've seen a lot of "5" and "0" on the driver's side front of A12-440 valve covers; does that maybe mean the 95 or 9 0 are gone from another 950 or are those inspector's marks???
Re: What is this marking ?????? [Re: A12] #630103
03/05/10 05:53 PM
03/05/10 05:53 PM
Trying to find out what numbers belong on my 68. 440 4 barrel auto trans. I've seen unrestored 69's with the 3 digit number on the top of valve cover passenger's side. I beleive on 69 it was the 3 digit engine code found at top left of fender tag. But 68's don't have that code on the tag.
Re: What is this marking ?????? [Re: Dougsmopars] #630104
03/05/10 08:41 PM
03/05/10 08:41 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
My 68 has either a line and 62 or 162 on the right front valve cover 62 is my engine code. This is a late St. Louis built car. You can kinda see it in this pic.
Re: What is this marking ?????? [Re: rrunner] #630105
03/11/10 10:08 PM
03/11/10 10:08 PM
were there any numbers on the other cover?
