Toyota Alternator
#629554
03/03/10 12:23 PM
03/03/10 12:23 PM
Posts: 1,534 Florida
CHRGR69
Was considering trying this on my 383. Who has the brackets and wiring schematic for this setup? I know the alt has a 3 prong connector and apparently eliminates the VR.
Grandma always said I had "hands of gold"!
Re: Toyota Alternator
[Re: CHRGR69]
#629556
03/03/10 02:42 PM
03/03/10 02:42 PM
Posts: 31,050 Oregon
AndyF
Most of the larger Mopar parts vendors carry that kit. 440Source, Mancini Racing, Hughes Engines, etc.
[Re: CHRGR69]
#629557
03/03/10 02:54 PM
03/03/10 02:54 PM
make sure you file a lawsuit against toyota when it causes your accelerator to stick at wot lol.
[Re: MarkZ]
#629561
03/04/10 08:56 PM
03/04/10 08:56 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
Mine is overcharging and now I think I know why I have the sense wire just over to the starter relay Thanks guys BTW I used the AR Engineering mount kit with the AR motor plate too it all fits perfect Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#629562
03/04/10 10:37 PM
03/04/10 10:37 PM
Posts: 8,882 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
That should be fine as long as its on the live side of the relay.
[Re: ademon]
#629565
03/05/10 02:36 AM
03/05/10 02:36 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Mine holds a constant 14.5v at the battery, is that overcharging?
About Ideal...
[Re: 1_WILD_RT]
#629566
03/05/10 11:37 AM
03/05/10 11:37 AM
Posts: 1,527 minnesota
Kirby
minnesota
Is this really worth doing? I have tons of stuff in my Cuda project. A/C,P/Seats, amp, electric fuel pump, line lock,H1/H4 headlights on relays, etc. I have done the Mad conversion, so I've eliminated the poor original connections, and figured running the headlights on relays would help "free" up some power for the rest. Stock alternator-
[Re: ademon]
#629570
03/05/10 03:48 PM
03/05/10 03:48 PM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
its worth doing, i have electric F/P, small amp, with everything on wipers included it still puts out 14.2v at idle 850 rpm.
