Is the drip rail supposed to have seam sealer? #628913
03/02/10 02:25 PM
03/02/10 02:25 PM
U.S.
basik Offline OP
basik  Offline OP
U.S.
What do you guys do to the drip rail before paint - do you fill it with any seam sealer? Did the factory seam seal there?
Re: Is the drip rail supposed to have seam sealer? [Re: basik] #628914
03/02/10 02:28 PM
03/02/10 02:28 PM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
Mine have all had sealer in them
NS1AAR
Re: Is the drip rail supposed to have seam sealer? [Re: ns1aar] #628915
03/02/10 08:18 PM
03/02/10 08:18 PM
Iowa - a member of the rustbel...
Birdturd Offline
Birdturd  Offline
what do you do with the "stuff" thats in the rail now, whats the easiest way to remove it?
Once its removed what do you put back on the rail?
Josh
Re: Is the drip rail supposed to have seam sealer? [Re: Birdturd] #628916
03/02/10 08:33 PM
03/02/10 08:33 PM
Rockford, IL
foz Offline
International Diplomat
foz  Offline
Rockford, IL
A wire wheel on a air tool works but is messy as hell!
Some restores leave it in. You can put it back too!
Re: Is the drip rail supposed to have seam sealer? [Re: Birdturd] #628917
03/02/10 08:53 PM
03/02/10 08:53 PM
Green Lane, PA
sawdust Offline
sawdust  Offline
Green Lane, PA
Josh
Low heat from propane torch and small scraper is what we use. Replace with a high quality seam sealer such as 3M (comes in standard caulk tubes)or what ever your local body shop supply man recommends. The cheaper stuff will shrink/crack a lot quicker than the original material did.
Re: Is the drip rail supposed to have seam sealer? [Re: sawdust] #628918
03/02/10 10:11 PM
03/02/10 10:11 PM
U.S.
basik Offline OP
basik  Offline OP
U.S.
Sometimes when I seam seal (and I do use 3M sealer) I worry about the sealer eventually cracking and then leaving a "trap" for water to stay in. There are some parts of my car where the sealer has cracked already and I haven't even driven the car yet.
Re: Is the drip rail supposed to have seam sealer? [Re: basik] #628919
03/02/10 10:33 PM
03/02/10 10:33 PM
IL . usa
cjs69mope Offline
cjs69mope  Offline
IL . usa
I am working on this as we speak what i am doing is fixing a car that some one else painted and the sealer has cracked and looks terrible .I want to fix with out painting the whole roof over .
step one tape roof off in the jamb twice.
step two using a small file scrape out old stuff to the metal carfully.
step three sand with 180 on homemade paint stick the thick 5 gal bucket type cut down.
step four treat with por-15 metal ready
step five paint with por -15 paint small brush works well .
step six retape and seam seal with hytec sealer from eastwood.
step seven smooth with solvent dipped paint stick
step eight retape & paint.(use no primer on seam sealer that is why it cracks prematurely)
step nine clear coat
step ten buff roof close to jamb to blend in .
this is what i am doing to fix a mistake .hope this helps with your project.....CJ
ps step eleven
1969 Dodge Charger 1969 Dodge Superbee
Re: Is the drip rail supposed to have seam sealer? [Re: cjs69mope] #628920
03/02/10 10:36 PM
03/02/10 10:36 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
ps step eleven
I guess I know why mine didn't come out so nice.. I went straight to step eleven..Jk
Re: Is the drip rail supposed to have seam sealer? [Re: foz] #628921
03/03/10 02:15 AM
03/03/10 02:15 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Re: Is the drip rail supposed to have seam sealer? [Re: 1_WILD_RT] #628922
03/03/10 03:49 AM
03/03/10 03:49 AM
Fitchbug, Mass.
WannaRunner Offline
WannaRunner  Offline
Fitchbug, Mass.
Nope! no cracks on that roof. lol.
Re: Is the drip rail supposed to have seam sealer? [Re: WannaRunner] #628923
03/03/10 11:02 AM
03/03/10 11:02 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
cjs69mope, thanks for that!
However, I do have a question.
I've got an A-100 that has good sealer in the drip rails, but has issues elsewhere. The sealer around the roof to the rear door openings and on a body seam where there was sealer but it has been cut out will have to be redone. Both of these areas will be difficult to keep primer away from during repainting.
I plan on soda blasting the entire body, then building up through the primer, filler and sealer stages before paint. What should I do to the fresh sealer areas to avoid shrinkage?
Re: Is the drip rail supposed to have seam sealer? [Re: RodStRace] #628924
03/03/10 05:06 PM
03/03/10 05:06 PM
IL . usa
cjs69mope Offline
cjs69mope  Offline
IL . usa
What i would do is just try and make sure that you sand the drip rails good with 180 or 220 before you prime the car and just seam seal the drip rails last before you paint the hytec sealer should not shrink or harden according to the directions it remains flexible and is paintable in 30-60 min .
just in the drip rails is where i would try and due this. fyi also 3m makes a two part epoxy base self level sealer made for roof ditches . just try and use a good product is what i am saying some seam seal dries hard that is going to crack in my opinion .you do not want that .....cj
Re: Is the drip rail supposed to have seam sealer? [Re: cjs69mope] #628925
03/03/10 05:20 PM
03/03/10 05:20 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Re: Is the drip rail supposed to have seam sealer? [Re: 1_WILD_RT] #628926
03/03/10 07:13 PM
03/03/10 07:13 PM
oregon
ramcharger1964 Offline
oregon
I second the motion on Fusor sealer. My experience with 3M seam sealer was not good. After 8 years my Fusor seams look brand new.
Hell B!tch Racing Co.
