Re: Rust and Primer Question.
[Re: Snoopy]
#628263
03/01/10 09:40 PM
03/01/10 09:40 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
That's bad rust. push on it. I bet your finger goes straight through it.
that's at the point I'm afraid, that you're gonna have to cut it out and patch in new metal. a minimum repair would be to cut the area out to good clean metal, and prime the edges so that the rust doesn't spread.
it's amazing how fast scale rust like that will spread, but a clean edge will stay solid for a long time.
**Photobucket sucks**
[Re: 70Duster440]
#628267
03/01/10 09:52 PM
03/01/10 09:52 PM
Posts: 7,664 IN
ahy
IN
Cancer. Cut it out and patch.
Agree. I'd get taken care of now, matching up the paint as well as possible. That way its ready for the overall re-paint next year. With that kind of rust, the quick fixes last 3 months or until the first rain... whichever comes first.
[Re: Alaskan_TA]
#628269
03/01/10 11:17 PM
03/01/10 11:17 PM
Posts: 6,516 Santa Cruz, California
Lefty
Chip, scrape and wire brush away all the loose rust. Clean with brake clean or final prep. Brush on Miracle paint with a new/clean chip brush. Top coat with spray bomb to cover Miracle paint. It'll last many years and not rust anymore than it is now. Get the black and use the leftover on frame and chassis stuff. Follow the directions about storing the leftover paint (don't remove the lid). http://www.hirschauto.com/prodinfo.asp?number=MIR-QUART
[Re: Snoopy]
#628273
03/02/10 09:12 AM
03/02/10 09:12 AM
Posts: 15,487 Florida
scratchnfotraction
x2 on the ospho doing my truck roof this week,thats stuff is killer and it will get the rust out sand/grind/prime I am using the "all metal" to patch up the pin holes and trim holesthat are in the cab/fenders/doors the surface rust on my roof was bad...it was rusted,sanded,primed,painted with out getting the rust out the first time before I got it I am on the 3rd coat of ospho and it is almost rust free..this last time should do it right down to the shiny metal and helps eat some of the stubborn primer and paint off good luck
