Rust and Primer Question. #628262
03/01/10 09:38 PM
03/01/10 09:38 PM
Central Coast, Calif.
Snoopy Offline OP
Snoopy  Offline OP
I need to try to slow down some rust problems. I know you guys on the East coast won't consider this a serious problem, seeing that I can't read a paper through the rusty spot.
How do I treat the affected area after I remove the rust? I figured that I would prime it, but it will just start to rust again.
What is the best way to handle the problem until I can get the car ready for paint in the next year?
Re: Rust and Primer Question. [Re: Snoopy] #628263
03/01/10 09:40 PM
03/01/10 09:40 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
That's bad rust. push on it. I bet your finger goes straight through it.
that's at the point I'm afraid, that you're gonna have to cut it out and patch in new metal. a minimum repair would be to cut the area out to good clean metal, and prime the edges so that the rust doesn't spread.
it's amazing how fast scale rust like that will spread, but a clean edge will stay solid for a long time.
**Photobucket sucks**
Re: Rust and Primer Question. [Re: Snoopy] #628264
03/01/10 09:40 PM
03/01/10 09:40 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
Cancer. Cut it out and patch.
Re: Rust and Primer Question. [Re: 70Duster440] #628265
03/01/10 09:42 PM
03/01/10 09:42 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
A little rust-mort should slow it down. Don't let it get on the surrounding paint though....
Re: Rust and Primer Question. [Re: Neil] #628266
03/01/10 09:50 PM
03/01/10 09:50 PM
Snoopy Offline OP
Snoopy  Offline OP
I pushed on it and it seems pretty solid, but you never know until you start trying to get to good metal. I will plan on replacing that section, but I need to stop the rust now and not leave a gaping hole.
What can I do to seal the primer so it won't rust through? Is there a one step method the prime and seal the spot until I can do it right?
Re: Rust and Primer Question. [Re: 70Duster440] #628267
03/01/10 09:52 PM
03/01/10 09:52 PM
IN
ahy Offline
ahy  Offline
IN
Agree. I'd get taken care of now, matching up the paint as well as possible. That way its ready for the overall re-paint next year. With that kind of rust, the quick fixes last 3 months or until the first rain... whichever comes first.
Re: Rust and Primer Question. [Re: Snoopy] #628268
03/01/10 09:54 PM
03/01/10 09:54 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
That is going to be a hole no matter what.
Scrape the bubbled part off & soak it in Ospho.
Re: Rust and Primer Question. [Re: Alaskan_TA] #628269
03/01/10 11:17 PM
03/01/10 11:17 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Chip, scrape and wire brush away all the loose rust. Clean with brake clean or final prep. Brush on Miracle paint with a new/clean chip brush. Top coat with spray bomb to cover Miracle paint. It'll last many years and not rust anymore than it is now.
Get the black and use the leftover on frame and chassis stuff. Follow the directions about storing the leftover paint (don't remove the lid).
http://www.hirschauto.com/prodinfo.asp?number=MIR-QUART
Re: Rust and Primer Question. [Re: Snoopy] #628270
03/01/10 11:22 PM
03/01/10 11:22 PM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
Snoopy - Eastwood Rust Encapsulator, clean best as possible, apply, let dry, prime and then topcoat with color matched spraybomb.
Ron
Re: Rust and Primer Question. [Re: Ronnman] #628271
03/02/10 01:23 AM
03/02/10 01:23 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Take your grinder to it and carefully grind it until the rust is gone. Then mask the area and spray it with primer and then some blue paint that sort of matches. It will be noticeable but better than a rust mound. If you try to leave it and put other crap over top you will only make it worse.
Re: Rust and Primer Question. [Re: DaytonaTurbo] #628272
03/02/10 03:03 AM
03/02/10 03:03 AM
Snoopy Offline OP
Snoopy  Offline OP
Thanks for all the input, I will try to get it to bare metal, hopefully without hitting air, and then try out a few of the above ideas.
Will DP90 protect the metal from rust without a topcoat? Assuming I can remove all the rust from the rusted surface. This will just be a short term fix to stop the spread.
Re: Rust and Primer Question. [Re: Snoopy] #628273
03/02/10 09:12 AM
03/02/10 09:12 AM
scratchnfotraction Offline
x2 on the ospho
doing my truck roof this week,thats stuff is killer and it will get the rust out
sand/grind/prime
I am using the "all metal" to patch up the pin holes and trim holesthat are in the cab/fenders/doors
the surface rust on my roof was bad...it was rusted,sanded,primed,painted with out getting the rust out the first time before I got it
I am on the 3rd coat of ospho and it is almost rust free..this last time should do it
right down to the shiny metal and helps eat some of the stubborn primer and paint off
good luck
Re: Rust and Primer Question. [Re: scratchnfotraction] #628274
03/02/10 10:57 AM
03/02/10 10:57 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Two different ways to approach this. #1 wire brush,grind,ect. to remove loose rust. Then apply a rust coating such as Por 15,fill,paint. #2 sandblast cut out bad metal weld in a patch. If your going to paint the whole car later it really doesn't matter which you do now. In my experience you'll always find hidden spots when you strip it anyway. Hope it doesn't look like this when you blast it.
Doug
Re: Rust and Primer Question. [Re: dvw] #628275
03/02/10 08:23 PM
03/02/10 08:23 PM
Snoopy Offline OP
Snoopy  Offline OP
Concerning the Ospho, how do you apply it and how long do you leave it on?
