Re: recurving a stock distributor [Re: 440newport] #627306
03/02/10 10:10 AM
03/02/10 10:10 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
standard motor products VC184 is a 17 degree vaccuum advance module. that's the shortest vac. advance canister I've seen for the electronic ignition dizzies...
I've been looking at vac advance cans for the last little while. I can't see anything for a big block that's less than 18. The VC184 you mention has the arm the opposite way, like for a slant or SB. They actually have a 13 degree can for a SB or slant, VC173.
VC184 is for a small block dizzy....
wish I woulda known about the VC173 before I bought mine...of course, my mag heads don't like a lot of timing at WOT (32 seems to work best), so the 17 degree can is about right for me.
2017 Grand Cherokee Overland
Re: recurving a stock distributor [Re: patrick] #627307
03/04/10 06:34 PM
03/04/10 06:34 PM
St. John's Newfoundland
440newport Offline OP
Ok I measured the slot with digital calipers and came up with 0.480. It's a 17 degree plate so I get 0.01411" per degree. I was gonna make it advance 20 degrees so that means I need to take 14 at 0.197 off leaving 0.283 which doesn't seem like a lot, the weights are barely going to move in that space but I guess its right?
Re: recurving a stock distributor [Re: 440newport] #627308
03/04/10 06:59 PM
03/04/10 06:59 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
It is not right. You also need to measure the pin that sticks out of the top of the weight. See the * in my previous post.
Re: recurving a stock distributor [Re: Mattax] #627309
03/04/10 07:27 PM
03/04/10 07:27 PM
Doh! Yes that makes perfect sense. Ok I come with .380 now which seems more like it.
Re: recurving a stock distributor [Re: 440newport] #627310
03/04/10 07:57 PM
03/04/10 07:57 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
What I do is not worry about total advance at first, instead with the engine warmed up I start adding timing to see what the engine will take without the starter kicking back.. The more initial timing you can give it the better it will launch... Your not looking to rev the engine above 3000 rpm here just see what the starter will take & see how the car comes out of the hole... So now you know how much initial lead you want & you just need to limit the total to around 34-36 degrees
This chart may help...
Modifying advance slots
degrees / slot size
6.............. .340
7................355
8................375
9................390
10...............405
11.5 ...........420
12...............435
13...............445
14...............460
15...............475
16...............490
17...............505
18...............520
Re: recurving a stock distributor [Re: 1_WILD_RT] #627311
03/04/10 08:49 PM
03/04/10 08:49 PM
I went with .375. I'll try that until I get the car running, if it needs to be changed it's no big deal to do it over.
Thanks everybody for the help.
Re: recurving a stock distributor [Re: 440newport] #627312
03/04/10 08:50 PM
03/04/10 08:50 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Should put you real close...
Re: recurving a stock distributor [Re: 1_WILD_RT] #627313
03/07/10 08:37 PM
03/07/10 08:37 PM
One more question on this...
Before I took the dist apart I marked which way the reluctor was on the advance plate shaft, but I didn't mark which way the advance plate was on the main shaft. I believe if its 180* out the reluctor wont line up with the pick up correctly.
Is there a way to tell?
Re: recurving a stock distributor [Re: 440newport] #627314
03/07/10 11:01 PM
03/07/10 11:01 PM
It'll be the same either way but I would drill a hole in the top of your (or a spare) dist cap between the center and #1 terminals & check rotor phasing so if it (Phasing) is off you can correct it but dropping the adv plate on the pins 180 off keeps the phasing the same in spite of the directional arrow and the 2 choices of roll pin slots on the reluctor wanting to convince you otherwise and be aware when you freeze the rotor w the light that vac adv (if used) will shift the rotor (phasing) CCW on a SB and CW on a BB and that mechanical advance does not change phasing.
Re: recurving a stock distributor [Re: RapidRobert] #627315
03/07/10 11:16 PM
03/07/10 11:16 PM
Ok thanks. I thought that since the reluctor can go 2 ways and the "teeth" are not lined up with the pick up the same way between the 2, I thought turning the advance plate on the pins backwards would be the same as having the reluctor on backwards.
Re: recurving a stock distributor [Re: 440newport] #627316
03/07/10 11:28 PM
03/07/10 11:28 PM
visualize an analog clock showing 5 minutes before 5 o'clock and if you epoxied the hands to lock the hour and the minute hand together as one then rotated the hand assy 1/2 turn (180 deg) the offset would end up being the same and if you 1st changed the roll pin hole and if this put the hands at 10 minutes in front of 4 and you locked them together as before and again swapped them 180 the top hand would still be 10 minutes away from (12)
Re: recurving a stock distributor [Re: RapidRobert] #627317
03/08/10 05:56 AM
03/08/10 05:56 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
It's too bad these are big $$ and only for small blocks. I've been down that road of welding, completely dissasembling for springs and swapping cannisters. Never again.
This will be my next distributor.
http://www.summitracing.com/parts/MSD-8504/
