VALVESPRING TESTER #627210
02/28/10 06:01 PM
02/28/10 06:01 PM
Virginia Beach, VA
O
Old School Offline OP
O
Virginia Beach, VA
looking for a good bench mount valvespring tester.needs to go to at least 900lbs. what do you guys use?
also how about a good on engine valvespring remover. whats the best out there?
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: VALVESPRING TESTER [Re: Old School] #627211
02/28/10 07:38 PM
02/28/10 07:38 PM
Rimac 1000 lb. benh model I have both models that Moapr use to sell for the SB and the BB I think Comp Cams sells the same brand
Re: VALVESPRING TESTER [Re: Old School] #627212
02/28/10 07:41 PM
02/28/10 07:41 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
What rockers? Buxton Engineering make the best on head removal tool out there http://www.buxtonengineering.com/index.php
LSM Racing is a close second
http://www.lsmproducts.com/
Re: VALVESPRING TESTER [Re: Old School] #627213
02/28/10 09:09 PM
02/28/10 09:09 PM
Az
Crizila Offline
Crizila  Offline
Az
Go to Hughes web sight. I think they have a used one for sale.
Fastest 300
Re: VALVESPRING TESTER [Re: Al_Alguire] #627214
02/28/10 09:50 PM
02/28/10 09:50 PM
Virginia Beach, VA
O
O
Virginia Beach, VA
thanks al,thats exactly what i was looking for. have you used the on head spring tester? would it be better to buy a bench tester and pull the springs to test?
i n eed them for jessel,s on 572-13,s and t&d,s on indy sr,s.
Re: VALVESPRING TESTER [Re: Old School] #627215
02/28/10 11:54 PM
02/28/10 11:54 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
We make & sell them in 300lb, 600lb and 1000lb sizes, for $62. Mounts in a vise, drill press, what have you. Accurate within 1%, and has a 3.25" gauge face. PM me if you're interested.
Re: VALVESPRING TESTER [Re: topside] #627216
03/01/10 12:27 AM
03/01/10 12:27 AM
CDoering Offline
CDoering  Offline
Brian,
If you need one right away I can borrow the bench top tester from work this week. I have to return your compressor anyway. I'm off all week recovering from the latest round of jaw surgery.
Chris
Re: VALVESPRING TESTER [Re: Old School] #627217
03/01/10 01:02 AM
03/01/10 01:02 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Brian,Yes I have the on head tester. The LSM piece works well. I check them with a bench top unit first upon install but we use the on head to keep track of them during the season. The removal tool from LSM is nice and works well. The Buxton piece is easier to use but on this engine in my car it does not fit well due to engine set back. IIRC LSM will give you a break on price if you buy the removal tool and tester together. Lance is a great guy and a heck of a racer as well.
Re: VALVESPRING TESTER [Re: Al_Alguire] #627218
03/01/10 06:14 AM
03/01/10 06:14 AM
Charleston, SC
SCDaytona Offline
SCDaytona  Offline
Charleston, SC
I use the LSM on head vavle spring removal tool and it works great. Bought their spring tester and found it would give me a differnent reading each time I checked the spring pressure. Retuned it and bought a Buxton. It is repeatable.
Re: VALVESPRING TESTER [Re: SCDaytona] #627219
03/01/10 12:00 PM
03/01/10 12:00 PM
Sherwood park, Alberta.
go green Offline
go green  Offline
I have the LSM tool for removing the spring on the head . ( I keep on breaking inners ?? )
and the LSM head tester .
I use a Longarc bench tester 0 - 1200 PSI
I had to modify the on head tester because of the canted valve angle.
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: VALVESPRING TESTER [Re: Old School] #627220
03/01/10 01:12 PM
03/01/10 01:12 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Rimac, the best that I know of.
