TQ question
#625746
02/27/10 12:42 PM
02/27/10 12:42 PM
Posts: 2,242 ILLINOIS
volaredon
ILLINOIS
I want to swap out the AFB (newer Weber version #9635 with Mopar linkage adapter) for a TQ. I have a Performer intake so I can run either.
Combo; '83 D 250 (3/4 ton 2WD) daily driver, 318, 727, 3.55s, engine has stock 360-2bbl cam, (dang close to COMP 252) EQ Magnum heads, Hooker Super comp headers and true 2-1/4 duals all the way out to the bumper, and the Performer/AFB.
I have 2 #9265s TQs here, that I had rebushed and I then kitted. OE app is 80 truck 360 on these carbs. I have my suspicions as to why, but neither carb ran worth a S#!T when I test ran them on my engine. (maybe an answer to my own Q here) but I am thinking of sending 1 or both to DemonSizzler; but they both run the same; mixture screws all the way in and still seems rich, one seeping fuel between the bowl and top casting (airhorn). About 30 min run time total combined between the 2 TQs since kitted.. Would I be better starting off with a early-mid 70s TQ instead of the '80 model?
Back when my brother HAD an 80 360 powered Ramcharger (for which both my present carbs are the exact OEM application) I could not find "these" carbs and built-up a 74 440 Cali version.(what I could find at the time) On that otherwise stock 360, that carb ran great! and passed smog here in IL.
(where I now live in IL, smog is a non issue; I just want the thing to run right) It don't run "bad" with the AFB at all I just think there's more to be had with a TQ based on other TQ equipped smallblocks I have had before.
Re: TQ question
[Re: volaredon]
#625749
02/27/10 06:12 PM
02/27/10 06:12 PM
RapidRobert
Not sure on that but I'm thinking that the 80 ones probably dont have ported vac (& the earlier ones may not either) which is preferable in most cases. On your deal I'm wondering if the bowl is warped. EDIT worded that backwards, meant to say ported is preferred (most cases)
Re: TQ question
[Re: broncobra]
#625753
02/28/10 08:46 AM
02/28/10 08:46 AM
Posts: 16,823 Between Houston & Galveston TX
SattyNoCar
Have you rebuilt a TQ yourself before? If you 'double stack' or put the wrong o-rings (too thick) in the wells you will effectively raise the top causing all kinds of problems. Is the float level set correct?
John
Re: TQ question
[Re: SattyNoCar]
#625754
02/28/10 11:04 AM
02/28/10 11:04 AM
volaredon
ILLINOIS
Yes I have rebuilt TQs before. with great results. Thats why I wasn't afraid at all to tear into these two. but neither "turned out" and seem to be having the same problems. and, yes the float is set correct. I even re-tore the 1st one apart to reset them, before I ever bolted it on, 'cause I got 2 different sets of spec's and reset that one, after talking to DemonSizzler, from my original setup.
