Big Block Volare/Aspen #625609
02/27/10 08:52 AM
02/27/10 08:52 AM
North Carolina
CALSDART Offline OP
CALSDART  Offline OP
North Carolina
I am interested in building a Big Block Volare/Aspen with a 727. Does anyone have any specs on the engine mounts, headers and rearend that you have used?
Re: Big Block Volare/Aspen [Re: CALSDART] #625610
02/27/10 09:07 AM
02/27/10 09:07 AM
Elbridge, NY
Dart1031 Offline
Dart1031  Offline
Elbridge, NY
I've never done it personally, but I know guys have used 66-70 B-body axles in F-bodies. I think the Schumacher BB spool type conversion mounts will work. And the TTI under chassis headers should work.
Re: Big Block Volare/Aspen [Re: CALSDART] #625611
02/27/10 10:35 AM
02/27/10 10:35 AM
Burlington,Ont.
77DragracerR/T Offline
Burlington,Ont.
As mentioned the 8 3/4 from a 66 B-body works great as that's what i have in mine.I run a sb stroker though so no help on the mounts for you.There are a few on here with big blocks in F-bodies.Just remember that front end is already heavy before you add weight to it.
What is your plan with the car,street/strip?
77 Aspen R/T 60'@1.41 10.76 @ 123.26
http://www.youtube.com/watch?v=Eya3Ue8KoZk
Re: Big Block Volare/Aspen [Re: CALSDART] #625612
02/27/10 11:57 AM
02/27/10 11:57 AM
Southwestern Ontario Canada
racealittle Offline
racealittle  Offline
I had one as a 440/727 for nearly 25 years. I just recently sold it.
It can be done, and can be fun; but with all the stroker small block possibilities available today, why would you?
The extra expense to put a BB in, can be applied to a lighter SB combination.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen! Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
Re: Big Block Volare/Aspen [Re: racealittle] #625613
02/27/10 12:35 PM
02/27/10 12:35 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
This used to be a very popular swap and I seem to recall a kit being available.
I built a 440 for a guy who was doing the same deal back in 1981 ish .........if there was a store bought kit available , I'd bet green dollars that there is one sitting on a shelf somewhere looking for you.
I seem to recall it being a very easy 10.80 deal , but he sold the car shortly after finishing it.
Actually , someone just had to have it would be closer to the truth.
But it was a pretty easy swap , with a minimum of cussing and only one ding required on a header tube.
Re: Big Block Volare/Aspen [Re: tubtar] #625614
02/27/10 01:28 PM
02/27/10 01:28 PM
California, USA
P
Phil Saran Offline
Phil Saran  Offline
P
California, USA
You should be able to use the stock K member and then the Schumacher motor mounts to install it
in a Volare/Aspen.
I know the K-member/torsion bars are different
from the 67-76 A-body.
My 74 Duster has a old MP K-member with spool
mounts for my 383/727 combo.
Phil Saran Parker, Colorado
Re: Big Block Volare/Aspen [Re: Phil Saran] #625615
02/27/10 01:46 PM
02/27/10 01:46 PM
Stow ,Ohio
demon440 Offline
demon440  Offline
Stow ,Ohio
Or you can go to BBD.com and RMS motorsports
has a front end kit for this if I'm not mistaken.
Re: Big Block Volare/Aspen [Re: CALSDART] #625616
02/27/10 02:38 PM
02/27/10 02:38 PM
Missouri
StrokerPost Offline
StrokerPost  Offline
Missouri
Here is what we did in my dad's Volare. Just made a plate. Headers are 1 3/4 B body headers. we had to alter the tube on # 7 cyl.
Here it is in the car.
Re: Big Block Volare/Aspen [Re: CALSDART] #625617
02/27/10 09:43 PM
02/27/10 09:43 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
A 66-70 B-Body housing is 3/4" wider overall than the stock axle. Cut the perches off and move them (you should do this any way to get the pinion angle correct).While you're at it it's easy to move the springs in(search my old posts for pics). Duster or Demon drive shaft from a 727 equipped car fits,as does the 727 itself.B-body headers usually fit with some issues at the steering coupler which can be trimmed. A last note. I haven't done it myself but a friend claims if you swap the stock 318 motor mount brackets right to left the R/B engine will come very close to bolting in.
Good Luck
Doug
Re: Big Block Volare/Aspen [Re: CALSDART] #625618
02/27/10 10:28 PM
02/27/10 10:28 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
If you want to keep it cheap just move the k-frame engine mount brackets rearward just like they did on the DC A-body big block k-frame and use the '73-up bb spool type mounts(B or C body). This works if you are starting with a small block car, will take more work with a /6 k frame. I think B/E body header should fit without too many problems.
Re: Big Block Volare/Aspen [Re: 446acuda] #625619
02/27/10 11:00 PM
02/27/10 11:00 PM
The Great White North
RAMM Offline
RAMM  Offline
I have done this twice and I used the stock 400 spool type mounts to perch my 452 low deck stroker into place with zero and I mean zero mods. I used 1 3/4 headers for B/E/C/ body (all of em) ZERO issues. In fact it was so easy and such a nice sleeper I would like to do it again and run in the 9's with the engine I have now--700+hp 470 low deck. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: Big Block Volare/Aspen [Re: 77DragracerR/T] #625620
02/28/10 08:33 AM
02/28/10 08:33 AM
North Carolina
CALSDART Offline OP
CALSDART  Offline OP
North Carolina
Thanks for the info. This is going to be a street car.
