Re: Hot off the dyno!!!!!!
[Re: moparniac]
#625346
03/06/10 11:19 AM
03/06/10 11:19 AM
Posts: 1,142 Central New York
slippery440
Crybaby440
Crybaby440
Central New York
First and for most. Mr 63 Great build and numbers.Would love to see the car in person. Second Why dose BG racing need all the attention when someone calls him out? This post was never about him or his reach around freinds.
If the MODS did their job I would not be hitting the notify MOD button. LOL
[Re: LITEMUP]
#625349
03/06/10 03:16 PM
03/06/10 03:16 PM
Posts: 1,646 Ontario,Canada
firefighter3931
Ontario,Canada
Here is a question for you BigBlockDart...how much power did Blaine make to post those times
Greg
The Moroso slide rule shows 670hp to run 143 at 3000lb raceweight.
Just for comparison sake ; another member had a 528 with 14:1 compression, ported B1BS heads and a tunnel ram with 2 850 cfm holley's and a healthy roller cam. That motor made ~750hp and ran a best of 9.71 at 3900 raceweight. The Moroso calculator is showing that this combo is working perfectly if not slightly overachieving.
My own pump gas 572 made just over 700hp with a set of cnc'd Indy heads (360cfm) and a 1000cfm carb. I'm sure it wouldn't have made near that number with a 750 holley. FWIW, my engine and the aformentioned 528 were dynoed on the same Superflow and there are several members here who've used the same service.
Mr63 ; you've got a great running car and an impressive pump gas smallblock ! The power numbers do seem a bit high based on the sum of parts and track performance....Best of luck this upcoming season.
Ron
[Re: firefighter3931]
#625350
03/06/10 03:26 PM
03/06/10 03:26 PM
Posts: 224 Ardrossan,Alberta,Canada
LITEMUP
super street
super street
Thanks for the level headed response. I also have that slide rule and it is very close to real world numbers! I took it to the track a few times and boy did some people hate it when thier 800hp motors performed like 600hp motors lol. Greg
