Page 8 of 8 1 2 3 4 5 6 7 8
Re: Hot off the dyno!!!!!! [Re: mr. 63plymouth] #625343
03/05/10 08:17 PM
03/05/10 08:17 PM
Sask, Can.
72demon416 Offline
72demon416  Offline
Sask, Can.
Nice numbers(dyno and track) and nice car. I did have the pleasure of seeing it a couple years ago and it is sweet.
Re: Hot off the dyno!!!!!! [Re: mr. 63plymouth] #625344
03/05/10 08:22 PM
03/05/10 08:22 PM
Ardrossan,Alberta,Canada
LITEMUP Offline
super street
LITEMUP  Offline
super street
Here is a question for you BigBlockDart...how much power did Blaine make to post those times
Greg
Re: Hot off the dyno!!!!!! [Re: LITEMUP] #625345
03/05/10 09:29 PM
03/05/10 09:29 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
mr63 I never said you were lying i said who cares what a dyno sheet says its all about what you ran...(track dyno is where its at) you read into that wrong..
Mopar Performance
Re: Hot off the dyno!!!!!! [Re: moparniac] #625346
03/06/10 11:19 AM
03/06/10 11:19 AM
Central New York
slippery440 Offline
Crybaby440
slippery440  Offline
Crybaby440
Central New York
First and for most. Mr 63 Great build and numbers.Would love to see the car in person.
Second Why dose BG racing need all the attention when someone calls him out? This post was never about him or his reach around freinds.
If the MODS did their job I would not be hitting the notify MOD button. LOL
Re: Hot off the dyno!!!!!! [Re: slippery440] #625347
03/06/10 12:05 PM
03/06/10 12:05 PM
Edmonton alberta Canada
mr. 63plymouth Offline OP
Thanx buddy,I will be running the car here in Edmonton alberta,and in the fall(Oct.2,3) at mission B.C canada,and maybe at that gusses drive in burger joint in Wisconsin US.
Re: Hot off the dyno!!!!!! [Re: slippery440] #625348
03/06/10 12:19 PM
03/06/10 12:19 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
real nice man
Mopar Performance
Re: Hot off the dyno!!!!!! [Re: LITEMUP] #625349
03/06/10 03:16 PM
03/06/10 03:16 PM
Ontario,Canada
firefighter3931 Offline
Ontario,Canada
Greg
The Moroso slide rule shows 670hp to run 143 at 3000lb raceweight.
Just for comparison sake ; another member had a 528 with 14:1 compression, ported B1BS heads and a tunnel ram with 2 850 cfm holley's and a healthy roller cam. That motor made ~750hp and ran a best of 9.71 at 3900 raceweight. The Moroso calculator is showing that this combo is working perfectly if not slightly overachieving.
My own pump gas 572 made just over 700hp with a set of cnc'd Indy heads (360cfm) and a 1000cfm carb. I'm sure it wouldn't have made near that number with a 750 holley. FWIW, my engine and the aformentioned 528 were dynoed on the same Superflow and there are several members here who've used the same service.
Mr63 ; you've got a great running car and an impressive pump gas smallblock ! The power numbers do seem a bit high based on the sum of parts and track performance....Best of luck this upcoming season.
Ron
Re: Hot off the dyno!!!!!! [Re: firefighter3931] #625350
03/06/10 03:26 PM
03/06/10 03:26 PM
LITEMUP Offline
super street
LITEMUP  Offline
super street
Thanks for the level headed response. I also have that slide rule and it is very close to real world numbers!
I took it to the track a few times and boy did some people hate it when thier 800hp motors performed like 600hp motors lol.
Greg
