Indy pushrods #623761
02/25/10 06:20 AM
02/25/10 06:20 AM
WI
mopar873 Offline OP
mopar873  Offline OP
WI
Last year I broke a rocker arm and also chewed up that pushrod. I figured I would go ahead and purchase a new set of pushrods and keep my old ones for spares. I bought a set of Indy pushrods, being told by them that they would work in my combo just fine. The more I am reading on here about their customer service, I am starting to worry. My car has a Comp .690 roller with 1.55 springs. I didn't run it hard with those pushrods last fall and took the shafts off for the winter to make it easier on the springs. Are these Indy's junk, or will they hold up?
Re: Indy pushrods [Re: mopar873] #623762
02/25/10 08:56 AM
02/25/10 08:56 AM
i'm running them in my 500 ci megablock with -1 indy heads and a .650 comp cam and they work fine for me a for a few seasons so far. im also using harland sharp roller rockers. 1.5's.
that .692 roller cam is the one i wish i had in my motor. mine is a CONSERVATIVE BUILD!
Re: Indy pushrods [Re: mopar873] #623763
02/25/10 09:02 AM
02/25/10 09:02 AM
Chicago,Illinois
N
nosboy Offline
nosboy  Offline
N
Chicago,Illinois
I've had a BUNCH of bad experiences with INDY and their -1 pushrods in their kit.. I figured out ( after chewing up a rocker) that the intake pushrods and the exhaust pushrods were .050 different.. Also the cup size (raadius) was different than they gave me in their -1 kit.. It took a call to Smith Brothers to order a CORRECT set of pushrods... I haven't had ANY PROBLEMS with SMITH BROTHERS (unlike Indy)..... FYI...
Re: Indy pushrods [Re: nosboy] #623764
02/25/10 10:10 AM
02/25/10 10:10 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We have used hundereds of Indy pushrod kits(we cut and build for each application)Hemi,Wedge and small block.The only issues we have seen is the occasional loss of a pushrod for varying reasons,ie: adjustment,geometry,bad rocker or adjuster,and cam and lifter issues.We had a bad set of 5/16 SB pushrods that the lifter ends flattened in the press,but that was over 8 years ago and Indy replaced them,nothing since.We also use Manton and Smith with no problems either.
Re: Indy pushrods [Re: B G Racing] #623765
02/25/10 11:15 AM
02/25/10 11:15 AM
Sidney,Ohio
challenger1320 Offline
Sidney,Ohio
I just bought a set from Trends in Detroit, MI. One piece, custom lenght, 210 deg rad. on the ball (.080 moly) for $117.00 plus shipping. That is less than Indy gets for the cut to fit crap.
Re: Indy pushrods [Re: challenger1320] #623766
02/25/10 12:44 PM
02/25/10 12:44 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
That's great!!! We are not suggesting to anyone who's to buy and who has the best pricing,just sharing our experience on the subject of "Indy pushrods"If we were only buying one set then I would want the "best" and not necessarrly the "cheapest" since a "junk pushrod" can cause a lot of damage.In some applications we are paying $350 to $500 for a set of custom made pushrods and certainly not from Indy.For the most part,since we make a quite a few sets that range from .080 to .180 wall at differnt lengths(especially Hemi)the price varys as well as the cam and spring demands,we find the Indy kits serve our purpose for the majority of our street and bracket engine builds.Just or opinion,experience and thoughts on the suject,nothing more. Respectfully Bob
Re: Indy pushrods [Re: B G Racing] #623767
02/25/10 01:04 PM
02/25/10 01:04 PM
tboomer Online work
tboomer  Online Work
Bad1970dust uses Indy pushrods in his 8 sec. duster...He makes his own and has never had a problem...
Re: Indy pushrods [Re: tboomer] #623768
02/25/10 01:57 PM
02/25/10 01:57 PM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
We had two sets that came with the oval and rectangle port small block heads. Used one set, they galled badly, threw the others away. I don't like their rocker arms either. T&D rockers and Smith Brothers pushrods are the only way to go if you're really going to lean on it.
Re: Indy pushrods [Re: dodgeboy11] #623769
02/25/10 02:32 PM
02/25/10 02:32 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
I'll see if I can link to a related post...
https://board.moparts.org/ubbthreads/show...page=0&vc=1
Re: Indy pushrods [Re: mopar873] #623770
02/25/10 10:20 PM
02/25/10 10:20 PM
fresno ca
mikeysmopars Offline
fresno ca
Your instinct about not installing those pushrods are right on. Even if you follow thier chart on what they want for adjustment. They Break and its your fault. They'r not going to be there to help you after the fact. If you want I have a hole set
out of my $5000.00 kit i'll hook you up with.
you'll only have to replace 2 rockers and 6 or 7 pushrods! Thier pushrods and adjuster screws are junk! Heads are awesome.
I know i'm going to get some rebuttal from the pro builders but people like me that only have the one race car, It Sucks To spend the kind of money Indy gets and skimps on critical parts.
Whats worse is how they walk away refuse and forget you after the money is spent.
Smith Brothers Pushrods!!!
Harland Sharp Rockers !!
Founder and CEO of the Central Valley Mopar Drag Pack
Re: Indy pushrods [Re: mopar873] #623771
02/25/10 10:32 PM
02/25/10 10:32 PM
Wisconsin
MagnumExpress Offline
Wisconsin
While I don't disagree with Indy's service after the sale I do disagree that there products are junk. I have ran the same pushrods and rocker arms for ten years with no problems. Last year I broke a rocker arm. Replaced with new set of Indy's. Still using same pushrods. Care must be taken to ensure proper pushrod length so not to much adjuster is protruding from the bottom of the rocker. I think ten years on the rockers is pretty good. I cut and press my own. Never galled one. Did gall MP pushrods years back. Just my opinion.
#9 in the world. 2006 IHRA Super Rod
2010 IHRA Div.5 Hot Rod Champion
Re: Indy pushrods [Re: MagnumExpress] #623772
02/25/10 10:45 PM
02/25/10 10:45 PM
fresno ca
fresno ca
Everyone that has had good luck with indy's rockers and pushrods all seem to have been from a few years ago before the economy started putting a strain on suppliers to do the materials cheeper.
No more russian rullette for me!
Re: Indy pushrods [Re: MagnumExpress] #623773
02/26/10 11:16 AM
02/26/10 11:16 AM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
but what kind of spring pressure are you running thats the biggest deal with the Indy rockers and push rods
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Indy pushrods [Re: MagnumExpress] #623774
02/26/10 11:20 AM
02/26/10 11:20 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Please reply with your pertinent spring load data.
Re: Indy pushrods [Re: mopar873] #623775
02/26/10 03:25 PM
02/26/10 03:25 PM
charlotte nc
jimmysarrow Offline
jimmysarrow  Offline
charlotte nc
I use k-motion 950 springs with no problems , indy pushrod kit, ( 3rd set ) no problems , and same Indy rockers 1.5 for 8 years on a ultradyne cam 278-283 duration w/ 682 lift. Indy makes good products , I just don't let them do the work.
Re: Indy pushrods [Re: dusturbd340W5] #623776
02/26/10 06:41 PM
02/26/10 06:41 PM
Wisconsin
Wisconsin
Springs are K-Motion. Seat pressure @ 245. Open @ 650. Cam lift @ valve .640 I agree with Jimmy
Re: Indy pushrods [Re: MagnumExpress] #623777
02/26/10 08:03 PM
02/26/10 08:03 PM
Cambridge Vt.
mark_gates Offline
mark_gates  Offline
Cambridge Vt.
I burned up a bunch of them in the 511. The Indy rocker arms don't supply enough oil at 600lbs over the nose. I ended up going with a set of Comp pushrod oiler roller lifters and custom Smith bros. pushrods.
Re: Indy pushrods [Re: mikeysmopars] #623778
02/26/10 08:37 PM
02/26/10 08:37 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
I don't agree with that assessment. Most failures are a result of inferior labour surrounding the part. Things like galled ends... recieved no oil. So do you blame the pushrod? My rockers weren't grooved for pushrod oiling. So instead of putting it together and waiting for it to all blow apart, I took the responsibility to groove them, so I wouldn't be pointing false fingers at indy, claiming everything they make is junk.
Its weird that Bob George has built more of these than all the individuals put together and has no failures.....
Re: Indy pushrods [Re: RemCharger] #623779
02/26/10 09:09 PM
02/26/10 09:09 PM
fresno ca
fresno ca
So when you buy a "complete Kit" from any engine supplier, you should go in and modify the parts?
My intent was to buy a one source head kit from someone reputible. Indy didn't reccomend grooving anything. Just make the pushrods so the adjuster screws come out right at flush or one thread sticking out Per thier sheet. Did it exactly as directed and pitched half the valve train.
Everyone has problems with thier stuff from time to time but c'mon, I'm not alone here this isn't a random rant. Just bent at the fact that Indy absolutly bails after the sale Unless your a dealer. Thats it! I'll become a dealer and begin defending thier stuff!!
PS Not bagging on anything they sell except the pushrods and rockers. JMO!
Re: Indy pushrods [Re: mopar873] #623780
02/26/10 10:29 PM
02/26/10 10:29 PM
Massachusetts, USA
maxeffort Offline
maxeffort  Offline
Massachusetts, USA
I use Smith Bros pushrods with very good results for many custom applications including builds with indy shaft rockers. If you are buying new pushrods, look them up.
The trend pushrods are very good too.
official member of the Sleepy Labeef band alumni club.
