Page 4 of 13 1 2 3 4 5 6 12 13
Re: 70 cuda 340 - finally painted! [Re: jrwoodjoe] #623551
03/22/10 01:47 PM
03/22/10 01:47 PM
So Cal, USA
Fab64 Offline
Fab64  Offline
So Cal, USA
Absolutely incredible job, and great documentation, too! You are an inspiration to us all. Looking forward to more.
Roger
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623552
03/22/10 04:10 PM
03/22/10 04:10 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
I will post updates as I begin assembly.
Hemi Jack - Yes, I did add the torque boxes. Car is coded for S15 hemi suspension, so I guess it could have or should have come with them.
JS29R0B - For the undercoating I used the SEM truck bed liner. can be sprayed on nice and thick (put on 2 coats) and has a very nice texture.
VERY nice job! The car and color look awesome! As for the torque boxes, I have owned several '70 340/383 4-spd 'Cudas and all were A31/A36 axle pkg cars and none were equipped with torque boxes. I believe only the U, V and R-code cars came with them. However, I have seen many Los Angeles built 340 and 383 'Cudas with just the front torque boxes.
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5
‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7
‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
Re: 70 cuda 340 - finally painted! [Re: 70440+6bbl] #623553
03/22/10 04:12 PM
03/22/10 04:12 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
FK5 (this one with 39 years of wear and tear)
Re: 70 cuda 340 - finally painted! [Re: 70440+6bbl] #623554
03/22/10 11:14 PM
03/22/10 11:14 PM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
Factory body side molding, cool!
Admiration For Multiple Carburetor Vehicles...
Re: 70 cuda 340 - finally painted! [Re: Stewpar] #623555
03/23/10 08:42 AM
03/23/10 08:42 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
B,,
Very, Very, well done. Love the color. more please
Re: 70 cuda 340 - finally painted! [Re: gtx6970] #623556
03/25/10 09:41 PM
03/25/10 09:41 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Outstanding job, WOW!! That is the way to do it!!
Re: 70 cuda 340 - finally painted! [Re: jrwoodjoe] #623557
03/26/10 02:34 AM
03/26/10 02:34 AM
Maple Ridge, BC, Canada
Barnabas_Kriss Offline OP
jrwoodjoe - the part numbers for the steering column are as follows:
Ignition switch - 3747092
Bearing steering column upper - 2265656
Bearing retainer - 2925491
Key buzzer switch - 2947488
Turn signal lever - 2947953
Cylinder and key package (including door locks) - 3695555
Shaft coupling rebuild kit - 4443436
Can't find the part number for the turn signal switch - it is a 70 only part#.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623558
04/24/10 04:47 AM
04/24/10 04:47 AM
Here is a little update:
I've been restoring more of the parts, and started to do some assembly.
NOS side marker lights, all 4!
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623559
04/24/10 04:47 AM
04/24/10 04:47 AM
Installed
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623560
04/24/10 04:49 AM
04/24/10 04:49 AM
NOS door latches, orginal door weatherstrip, which cleaned up very nicely.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623561
04/24/10 04:50 AM
04/24/10 04:50 AM
Tail lights, original housings zinc dichromated, original lenses polished, original bezels re-chromed, LED panels installed.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623562
04/24/10 04:51 AM
04/24/10 04:51 AM
Tail lights assembled.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623563
04/24/10 04:54 AM
04/24/10 04:54 AM
Brake valve cleaned and disassembled, new O-rings installed.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623564
04/24/10 05:06 AM
04/24/10 05:06 AM
Seat adjusters, stripped, epoxy primed, re-painted.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623565
04/24/10 05:07 AM
04/24/10 05:07 AM
Pedal assy disassembled.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623566
04/24/10 05:08 AM
04/24/10 05:08 AM
Pedal assy restored, with new bearings, bushings, etc.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623567
04/24/10 05:10 AM
04/24/10 05:10 AM
Under dash parts installed.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623568
04/24/10 05:11 AM
04/24/10 05:11 AM
Heater box installed.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623569
04/24/10 05:20 AM
04/24/10 05:20 AM
Aluminum master cylinder installed. Brakes will be upgraded to 13" disks with viper calipers in the front, and 11.5" discs in the rear.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623570
04/24/10 08:23 AM
04/24/10 08:23 AM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
WOW, it's going to be AMAZING. One question, did you do your pedal assembly and if so, where did you get the bearings and bushings for it?
Joe
65 Barracuda
70 Challenger
