Page 1 of 5 1 2 3 4 5
Turbo Big Block Header Pics #623304
02/24/10 11:31 PM
02/24/10 11:31 PM
Illinois
moparmattkos Offline OP
mopar addict
mopar addict
Illinois
I am lookin for ideas for fabbing up my big block turbo headers. Post your pics please!!!!!
www.sikosracing.net Heads up Drag racing
Re: Turbo Big Block Header Pics [Re: moparmattkos] #623305
02/25/10 08:09 AM
02/25/10 08:09 AM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Re: Turbo Big Block Header Pics [Re: Defbob] #623306
02/25/10 09:45 AM
02/25/10 09:45 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Heres mine...
Re: Turbo Big Block Header Pics [Re: joshking440] #623307
02/25/10 09:47 AM
02/25/10 09:47 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
another
Re: Turbo Big Block Header Pics [Re: joshking440] #623308
02/25/10 09:49 AM
02/25/10 09:49 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
one more
Re: Turbo Big Block Header Pics [Re: joshking440] #623309
02/25/10 10:18 AM
02/25/10 10:18 AM
St. Clair Shores, Michigan
bigsbigelow Offline
bigsbigelow  Offline
Josh, I never noticed before but are you not concerned about that cross over tube melting plug wires or even the distributor cap?
Ryan "Bigs" '73 Duster (BLKDUST) - Black, 100% factory sheet metal, flat hood, 346 cid, J Heads, and a bench seat. http://s268.photobucket.com/albums/jj1/bigsbigelow/ Best to date: 12.40 @ 109 mph
Re: Turbo Big Block Header Pics [Re: bigsbigelow] #623310
02/25/10 02:13 PM
02/25/10 02:13 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
there is a little more room then what appears in the pictures, but not a lot. I would say I have 3" or so from the cap to the tube. We are actually looking at making a heat shield for that crossover tube, just incase though
Re: Turbo Big Block Header Pics [Re: joshking440] #623311
02/25/10 02:34 PM
02/25/10 02:34 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Looks nice how is the exhaust routed for the turbo? Will it exit out normally under the car?
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Turbo Big Block Header Pics [Re: moparmattkos] #623312
02/25/10 02:49 PM
02/25/10 02:49 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Heres a pic of the exhaust
Re: Turbo Big Block Header Pics [Re: joshking440] #623313
02/25/10 04:07 PM
02/25/10 04:07 PM
So Cal
So Cal
Well that isn’t going to work for a street car.
Re: Turbo Big Block Header Pics [Re: joshking440] #623314
02/25/10 04:45 PM
02/25/10 04:45 PM
Odessa, Fl
blowndart Offline
blowndart  Offline
Odessa, Fl
there is a little more room then what appears in the pictures, but not a lot. I would say I have 3" or so from the cap to the tube. We are actually looking at making a heat shield for that crossover tube, just in case though
Ever though about just using header wrap? My down pipe is about 1/2" away from my cap and the wrap works well. Really keeps the heat down.
Re: Turbo Big Block Header Pics [Re: HealthServices] #623315
02/25/10 06:04 PM
02/25/10 06:04 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Do you mean because it looks like it hangs low?
Re: Turbo Big Block Header Pics [Re: joshking440] #623316
02/25/10 06:06 PM
02/25/10 06:06 PM
Dirty Dena, Maryland
dodge turbo Offline
dodge turbo  Offline
yeah why wouldnt that work for a street car???
78 Adventurer 150small block turbo'd 360w/Borg S475....smoke'em
Re: Turbo Big Block Header Pics [Re: dodge turbo] #623317
02/25/10 06:09 PM
02/25/10 06:09 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
It is not much lower than the k-member, and a good amount higher than the oilpan
Re: Turbo Big Block Header Pics [Re: joshking440] #623318
02/25/10 06:19 PM
02/25/10 06:19 PM
So Cal
So Cal
I need the exhaust to go to the rear bumper. 40% of the time I have my little girl with me. The fumes are not a biggy to me, but I don't want my 4 year old sniffing it.
Re: Turbo Big Block Header Pics [Re: HealthServices] #623319
02/25/10 06:34 PM
02/25/10 06:34 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
ethanol baby....
Post deleted by Defbob [Re: moparmattkos] #623320
02/25/10 06:54 PM
02/25/10 06:54 PM
Re: Turbo Big Block Header Pics #623321
02/25/10 08:13 PM
02/25/10 08:13 PM
So Cal
So Cal
With what I read the size, length, tuning of the exhaust is not as important before the turbo, as the restriction is in the turbo itself and the exhaust after it.
These are plenty 700+ hp turbo motors out there with just logs.
Post deleted by Defbob [Re: HealthServices] #623322
02/25/10 08:49 PM
02/25/10 08:49 PM
Re: Turbo Big Block Header Pics #623323
02/25/10 09:28 PM
02/25/10 09:28 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
And my logs are probably the most butch looking out there
