07 3.5 V6 using OIL ? #623192
02/24/10 08:38 PM
02/24/10 08:38 PM
FT. Worth TX
P
PASTLITE Offline OP
PASTLITE  Offline OP
P
FT. Worth TX
A friend of mine has a 07 Charger with a 3.5 V6 with 51000 miles. He changes his oil every 3000 miles,before he changes it the level is barly on the stick. He says he sees no leeks. And the car doesnt smoke. Anybody got any ideas what is happening.
Re: 07 3.5 V6 using OIL ? [Re: PASTLITE] #623193
02/24/10 09:13 PM
02/24/10 09:13 PM
Ridley Park, Pa.
69MOPE Offline
super gas
69MOPE  Offline
super gas
Ridley Park, Pa.
As per Chrysler, 1 quart in 850 miles is normal oil consumption!
Re: 07 3.5 V6 using OIL ? [Re: 69MOPE] #623194
02/24/10 09:29 PM
02/24/10 09:29 PM
70duster340 Offline
70duster340  Offline
Gees, seems sorta high, don't it?
Re: 07 3.5 V6 using OIL ? [Re: 70duster340] #623195
02/24/10 09:52 PM
02/24/10 09:52 PM
wisconsin
mod381 Offline
mod381  Offline
wisconsin
Not what you are going to want to here but that is going to be considered normal. The 3.5 is fairly common to use oil,very much so in the pacifica's
Re: 07 3.5 V6 using OIL ? [Re: mod381] #623196
02/24/10 10:07 PM
02/24/10 10:07 PM
Unfortunately back in New York
N
Nukechargerboy Offline
N
my 02 intrepid burns about 1.5 quarts of mobil 1 every 5k. At least it didn't blow up like a 2.7.
Re: 07 3.5 V6 using OIL ? [Re: Nukechargerboy] #623197
02/25/10 08:23 AM
02/25/10 08:23 AM
FT. Worth TX
P
PASTLITE Offline OP
PASTLITE  Offline OP
P
FT. Worth TX
Thanks for the replys
