'69 Dart 340 getting gently preped for the Race track. #623122
02/24/10 07:52 PM
02/24/10 07:52 PM
Central Oregon
Rodney Offline OP
Rodney  Offline OP
Central Oregon
I'm thinkin' this could be fun if we do it right!
Here's the tire we'll be running without much problem {I hope}
I've owned this one for a long long time and finally getting the time to bolt on a set of slicks and some other things to do sum drag racing.
340 727 3.91's spool drive line loop stage 2 shift kit.
hum?
what else?
rev limiter
some pump gas with a splash of 110.
with only 67k on the clock I'm not planning on doing much to the engine to begin with, leak down compression test change the oils and check everything out. album here
Re: '69 Dart 340 getting gently preped for the Race track. [Re: Rodney] #623123
02/24/10 11:06 PM
02/24/10 11:06 PM
Bend, Oregon
67cuda340 Offline
super street
67cuda340  Offline
super street
Bend, Oregon
That car reminds me of my 69 GTS 340 I had back
in the late 90's. I ran a 235/60/15 Drag
radial and ran low 8's 1/8 mile. Car was bone stock except for a few bolt on's.
We will see you at the track?
Matt
1973 Dodge Dart Sport 360 Drag radials 12.30 1/4 mile 7.82 1/8 mile
Re: '69 Dart 340 getting gently preped for the Race track. [Re: 67cuda340] #623124
02/25/10 12:22 AM
02/25/10 12:22 AM
Central Oregon
Rodney Offline OP
Rodney  Offline OP
Central Oregon
Re: '69 Dart 340 getting gently preped for the Race track. [Re: 67cuda340] #623125
02/25/10 12:25 AM
02/25/10 12:25 AM
Central Oregon
Rodney Offline OP
Rodney  Offline OP
Central Oregon
in the late 90's. I ran a 275/60/15 Drag
Matt
thanks I was wondering about that!
Re: '69 Dart 340 getting gently preped for the Race track. [Re: Rodney] #623126
02/25/10 12:50 AM
02/25/10 12:50 AM
Pewaukee, WI
Airgrabber Offline
Airgrabber  Offline
Pewaukee, WI
Looking good! What size are your new tires? The TTI's are the best!
Re: '69 Dart 340 getting gently preped for the Race track. [Re: Airgrabber] #623127
02/25/10 01:44 AM
02/25/10 01:44 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
Where's the torch and welder??
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: '69 Dart 340 getting gently preped for the Race track. [Re: Airgrabber] #623128
02/25/10 11:54 AM
02/25/10 11:54 AM
Central Oregon
Rodney Offline OP
Rodney  Offline OP
Central Oregon
these tires on the rear.
it's going to be a tight fit
on these from Stockton wheels
Re: '69 Dart 340 getting gently preped for the Race track. [Re: Rodney] #623129
02/25/10 12:59 PM
02/25/10 12:59 PM
Norwalk Ohio
cudasteve68 Offline
cudasteve68  Offline
Norwalk Ohio
when this was a street car I ran a 245/60/14 M&H Racemaster cheater slick.
Car went 12.0's with a small cam'ed 372 (.070 over 360)
Re: '69 Dart 340 getting gently preped for the Race track. [Re: cudasteve68] #623130
02/25/10 01:59 PM
02/25/10 01:59 PM
Central Oregon
Rodney Offline OP
Rodney  Offline OP
Central Oregon
nice! what did you start with for air pressure in the rear?
burn out is not needed from what I understand?
here is our TTI headers got them with the coating
they look great
Re: '69 Dart 340 getting gently preped for the Race track. [Re: Rodney] #623131
02/25/10 06:41 PM
02/25/10 06:41 PM
Motor City
Shaker223 Offline
Shaker223  Offline
Motor City
The 255/60/15 MT fit on my 70 Dart. I'm going to trim the wheel lip a little . W/O trimming the tire has 3/8" clearance. The spring side is fine.
Re: '69 Dart 340 getting gently preped for the Race track. [Re: Shaker223] #623132
02/25/10 08:49 PM
02/25/10 08:49 PM
Central Oregon
Rodney Offline OP
Rodney  Offline OP
Central Oregon
good to know thanks
wish the wheels would show up so I can see for myself.
got to love the way that 6 runs
my mom drove a Dart for 20 + years like yours,
Well not quite
Re: '69 Dart 340 getting gently preped for the Race track. [Re: Shaker223] #623133
02/27/10 11:43 AM
02/27/10 11:43 AM
Central Oregon
Rodney Offline OP
Rodney  Offline OP
Central Oregon
It's hard to believe but this 8 3/4 rear axle has NEVER been apart! I had to remove the push lock washers from the axle bearing retainers before removing the axles The bearings were in desperate need of grease and the OEM U-joints are just about ready to go. I've been looking forward to working on my Dart for years, this is fun.
Re: '69 Dart 340 getting gently preped for the Race track. [Re: Rodney] #623134
02/28/10 11:02 AM
02/28/10 11:02 AM
Central Oregon
Rodney Offline OP
Rodney  Offline OP
Central Oregon
The 391's going in and the adjustable pinion snubber installed. This type snubber is different than the one's I've installed in the past, it screws up and down rather than using a pin.
We found the aftermarket axles are a little to long {better than to short}
Guess I will have to ship them back to Dutchman unless I can find someone local to cut them down.
has anyone ever shortened axles?
use a cut off wheel in a chop saw to cut axles?
grind the bevel and touch up the splines?
thinking out loud. is anyone listening?
I would like to avoid shipping them back if I can.
Sure hope the off set is correct for the brakes I'll check that out today.
thanks for taking a look.
Re: '69 Dart 340 getting gently preped for the Race track. [Re: Rodney] #623135
02/28/10 03:15 PM
02/28/10 03:15 PM
Cab_Burge Online work
Cab_Burge  Online Work
Rod, I have had to shorten my 35 spline axles twice, once when I shorten the 8 3/4 and again when I put them in the Dana 60 that is in the car now. I had the Dana shortened one inch more than the old 8 3/4. I used a metal cut off wheel on a chop saw like they have at a muffler shop or a welders shop, beveled it lightly on the cut off wheel after the cutting
Re: '69 Dart 340 getting gently preped for the Race track. [Re: Cab_Burge] #623136
04/04/10 04:39 PM
04/04/10 04:39 PM
Central Oregon
Rodney Offline OP
Rodney  Offline OP
Central Oregon
Some more images of parts new and old,
Finally having some time to work on the cars!
We are needing a set of +.010 pistons for this 340 real bad. CR 12.5?
Re: '69 Dart 340 getting gently preped for the Race track. [Re: Rodney] #623137
04/04/10 09:53 PM
04/04/10 09:53 PM
Bend, Oregon
67cuda340 Offline
super street
67cuda340  Offline
super street
Bend, Oregon
Get ur done..
See you at the track
Matt
Re: '69 Dart 340 getting gently preped for the Race track. [Re: 67cuda340] #623138
01/27/11 11:16 PM
01/27/11 11:16 PM
Central Oregon
Rodney Offline OP
Rodney  Offline OP
Central Oregon
here's an update on the 69 Dart
trying like heck to get her back together before knee surgery next week.
I called in reinforcements to lend a hand this weekend.
I did a little more testing on the dyno to find the Holley mechanical fuel pump doesn't do the job.
it did make about as much HP but during the sweep lost all pressure. We will install an electric pump instead.
Thanks for taking a look.
Re: '69 Dart 340 getting gently preped for the Race track. [Re: Rodney] #623139
01/28/11 03:28 AM
01/28/11 03:28 AM
Topeka Kansas
K
ksj Offline
ksj  Offline
K
Topeka Kansas
Looks good.9 months before giving us updates is not acceptable.
Re: '69 Dart 340 getting gently preped for the Race track. [Re: ksj] #623140
01/28/11 11:11 AM
01/28/11 11:11 AM
Central Oregon
Rodney Offline OP
Rodney  Offline OP
Central Oregon
Has it been that long?
seems pages are missing from this thread?
hopefully I'll post the finished project this weekend.
I painted the engine compartment before the engine went back in but the rest of the paint work will have to come next year.
the dyno test results are here
I thought I posted them?
This project is a good distraction from my up coming surgery for total knee replacement. That's going to slow me down more that usual.
Re: '69 Dart 340 getting gently preped for the Race track. [Re: ksj] #623141
05/04/11 12:25 PM
05/04/11 12:25 PM
Central Oregon
Rodney Offline OP
Rodney  Offline OP
Central Oregon
The '69 made a few passes down the 1/8 mile before we decided not to go any further until a new valve body and reverse pattern shifter is install. The car ran a couple 8.40's at part throttle since the transmission wasn't shifting properly.
Nothing to write home about but we aren't finished.
It was a successful day for us with the Dart, it launches hard, stops OK with the drum breaks and sounds good.
I was trying to keep the Dart as OEM as possible but to make the car more user friendly for the "big guy" we are going to also install a single seat and a good set of belts for safety.
