727 planetary gears #622953
02/24/10 04:14 PM
02/24/10 04:14 PM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
Do i need steelsplined gears in 800 hp, 2800 lbs, transbrake?
Háve anyone with more hp or weight used a standard 3 gear planetary for hundreds of runs?
Re: 727 planetary gears [Re: sshemi] #622954
02/24/10 04:18 PM
02/24/10 04:18 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
I talked to Joe at Tranzact about his opinion on the 3 pinion vs 4 pinion planets setup.
He told me that they actually had trouble with the 4 pinion setups. Went back to the 3 pinion setups and the problem went away.
This was in a blown puller application using a 727 making some serious HP...
I
Re: 727 planetary gears [Re: sshemi] #622955
02/24/10 05:25 PM
02/24/10 05:25 PM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
there is one member here who has stripped the splines out of the aluminum ones , forget who it was , maybe he will jump in
got a steel one in mine
WAXER
Re: 727 planetary gears [Re: Bob_Coomer] #622956
02/24/10 05:26 PM
02/24/10 05:26 PM
Chicagoland
chargerron69 Offline
Chicagoland
more or less you need the steel capped planet because you risk stripping the spline out of the aluminum
67 Coronet 383 hogged out 906's 727 430 dana best 10.48 @126.80 1.47 60 on fogger same car pump gas 605 wedge 9.98 @ 138.42 1.50 60 on wore out 9 inch radial slick ss springs and frame connectors its got more in it!!! 72 Newport 2 door 400 727 85 Ram 440 4 speed O/D 3.54 dana
Re: 727 planetary gears [Re: sshemi] #622957
02/24/10 05:38 PM
02/24/10 05:38 PM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
I run a 4 gear with a steel hat (splines). We have ran it for about 5 seasons now off the t brake and we are currently pushing approximately 800hp in a 3200# vehicle. I think it is a good idea in your case to run one with steel splines! I think john cope CRT has a 5 pinion that is all steel not just a steel hat added to an aluminum carrier.
Re: 727 planetary gears [Re: QWK_ENUF] #622958
02/24/10 08:00 PM
02/24/10 08:00 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
The usual cause of stripped aluminum planetaries is from mismatched splines. Between different years there was a change in the tooth angle on the spline that is so slight it's hardly noticeable. The planetary/output shaft combinations will mix and match, but one of the mismatches will be slightly loose and will eventually strip the teeth.
I think the steel cap would be mandatory for a heavy high torque car. A light weight car might be OK with the aluminum ones. Trans brake might put the odds in more of the steel cap units favor.
Re: 727 planetary gears [Re: QWK_ENUF] #622959
02/24/10 09:13 PM
02/24/10 09:13 PM
Lenox, MI
gj69charger Offline
gj69charger  Offline
Lenox, MI
I did it a few years ago, launching at Norwalk.
Re: 727 planetary gears [Re: gj69charger] #622960
02/25/10 01:29 PM
02/25/10 01:29 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I had it happen here to. Found it after an inspection after a rear failure at the line. I put a steel one in and forgot about it.
Re: 727 planetary gears [Re: B1MAXX] #622961
02/25/10 02:11 PM
02/25/10 02:11 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
at 800hp ...yes you need steel.
call protrans and ask Dave
Re: 727 planetary gears [Re: gj69charger] #622962
02/25/10 02:17 PM
02/25/10 02:17 PM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
This is a no brainer.
I am gonna order one.
Re: 727 planetary gears [Re: sshemi] #622963
02/25/10 02:54 PM
02/25/10 02:54 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We use stock 3 and 4 gear planetarys in all our trans unless steel is requested.We have logged thousands(yes thousands) of runs in my car and others with no problems.My current trans has been in my 65 for 10 years and seen duty in Curt's 3700# Challenger before that.I personally broke one planetary in all my years of racing,Ron McCelland tore out the splines in his similar trans a few years ago when he broke a rearend(1968 stock set of Dana gears)the only thing hurt was the front planetary.I would rather that happen than have more damage that would have occurred had that been a steel set.
Re: 727 planetary gears [Re: B G Racing] #622964
02/25/10 09:31 PM
02/25/10 09:31 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I have an old coffee can half full of gears removed from stripped aluminum front planetaries, and this was in the days when there was only one spline on the output shaft so spline mismatch wasn't the problem.
The factory offered a steel front planet carrier as far back as '66 so it's been a known weak point nearly since day one. Thus the two changes in spline angle to try tp prevent spline failure.
Re: 727 planetary gears [Re: gj69charger] #622965
02/25/10 09:43 PM
02/25/10 09:43 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
A picture is worth,,,,,,,,the paper it's printed on
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: 727 planetary gears [Re: hemi-itis] #622966
02/25/10 09:45 PM
02/25/10 09:45 PM
hemi-itis Offline
hemi-itis  Offline
Udder side
Re: 727 planetary gears *DELETED* [Re: hemi-itis] #622967
02/25/10 09:52 PM
02/25/10 09:52 PM
Kokomo, IN
540dust Offline
540dust  Offline
Kokomo, IN
Post deleted by 540dust
Re: 727 planetary gears [Re: 540dust] #622968
02/25/10 09:56 PM
02/25/10 09:56 PM
iowa
rook440 Offline
rook440  Offline
iowa
I wouldn't buy anything from Rick Allison ,,,over prices rebuilt stock junk !!!!!!!!!
Re: 727 planetary gears [Re: hemi-itis] #622969
02/25/10 10:10 PM
02/25/10 10:10 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
looks just like the 5 pinion steel planet out of a diesel 518 that is in my unit
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: 727 planetary gears [Re: dusturbd340W5] #622970
02/25/10 10:26 PM
02/25/10 10:26 PM
hemi-itis Offline
hemi-itis  Offline
Pushbutton 727 Purchased 10 years ago.Was expensive but he was the only show in town at the time
Re: 727 planetary gears [Re: hemi-itis] #2841661
11/04/20 12:46 PM
11/04/20 12:46 PM
Isle of Sheeps
Gtxxjon Offline
Gtxxjon  Offline
Isle of Sheeps
Hi Moparts,
Doing some 727 work for me/mates, when I realised one of them was a 76 model S/B.
On close inspection I was unhappy with the planetary gear excess play!
I could see from comparing it with an earlier trans that the gear set seemed indentical but the ring gear was different.
Different spline angles and much lower heights as well.
Even so the gear mess was excessive.
Am I right in thinking the ring gear is right but the planetaries has been changed.
I thought the earlier ones do not fit on the later 75-on shafts?
Do the A518 4-5-6 gear planets fit the 76 727 shafts???
many thanx in advance Gtxxjon
Carpe diem, quam minimum credula postero, thanx Horace!
There’s no point trying to fix stuff that ain’t broke,,, 'but if ain’t broke',,, you is not trying hard enough...
Re: 727 planetary gears [Re: Gtxxjon] #2841668
11/04/20 12:56 PM
11/04/20 12:56 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Welcome to the board.
There are three different spline angles in the 727 front planetary.
The spline included angles are as follows:
'62-'75= 90°
'76-'93= 75°
'94-on= 60°
The spline angles are sometimes expressed as the pressure angle which is half the included angle (45°, 37.5°, 30°)
Each change affected the diameter of the splines so smaller shafts will fit in larger planetaries but the loose fit will lead to early failure.
Annulus gear diameter is unchanged.
