Re: 727 planetary gears
[Re: sshemi]
#622954
02/24/10 04:18 PM
02/24/10 04:18 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
I talked to Joe at Tranzact about his opinion on the 3 pinion vs 4 pinion planets setup. He told me that they actually had trouble with the 4 pinion setups. Went back to the 3 pinion setups and the problem went away. This was in a blown puller application using a 727 making some serious HP... I
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: sshemi]
#622955
02/24/10 05:25 PM
02/24/10 05:25 PM
Posts: 2,442 LOWELL IN
QWK_ENUF
LOWELL IN
there is one member here who has stripped the splines out of the aluminum ones , forget who it was , maybe he will jump in got a steel one in mine
WAXER
[Re: sshemi]
#622957
02/24/10 05:38 PM
02/24/10 05:38 PM
Posts: 2,563 S.E. Michigan
cl440
S.E. Michigan
I run a 4 gear with a steel hat (splines). We have ran it for about 5 seasons now off the t brake and we are currently pushing approximately 800hp in a 3200# vehicle. I think it is a good idea in your case to run one with steel splines! I think john cope CRT has a 5 pinion that is all steel not just a steel hat added to an aluminum carrier.
[Re: QWK_ENUF]
#622958
02/24/10 08:00 PM
02/24/10 08:00 PM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
The usual cause of stripped aluminum planetaries is from mismatched splines. Between different years there was a change in the tooth angle on the spline that is so slight it's hardly noticeable. The planetary/output shaft combinations will mix and match, but one of the mismatches will be slightly loose and will eventually strip the teeth.
I think the steel cap would be mandatory for a heavy high torque car. A light weight car might be OK with the aluminum ones. Trans brake might put the odds in more of the steel cap units favor.
[Re: QWK_ENUF]
#622959
02/24/10 09:13 PM
02/24/10 09:13 PM
Posts: 256 Lenox, MI
gj69charger
Lenox, MI
I did it a few years ago, launching at Norwalk.
[Re: B G Racing]
#622964
02/25/10 09:31 PM
02/25/10 09:31 PM
Posts: 25,858 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I have an old coffee can half full of gears removed from stripped aluminum front planetaries, and this was in the days when there was only one spline on the output shaft so spline mismatch wasn't the problem.
The factory offered a steel front planet carrier as far back as '66 so it's been a known weak point nearly since day one. Thus the two changes in spline angle to try tp prevent spline failure.
Re: 727 planetary gears *DELETED*
[Re: hemi-itis]
#622967
02/25/10 09:52 PM
02/25/10 09:52 PM
Posts: 656 Kokomo, IN
540dust
Kokomo, IN
Post deleted by 540dust
[Re: hemi-itis]
#622969
02/25/10 10:10 PM
02/25/10 10:10 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
A picture is worth,,,,,,,,the paper it's printed on
looks just like the 5 pinion steel planet out of a diesel 518 that is in my unit
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: dusturbd340W5]
#622970
02/25/10 10:26 PM
02/25/10 10:26 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
Pushbutton 727 Purchased 10 years ago.Was expensive but he was the only show in town at the time
[Re: hemi-itis]
#2841661
11/04/20 12:46 PM
11/04/20 12:46 PM
Posts: 348 Isle of Sheeps
Gtxxjon
Isle of Sheeps
Hi Moparts,
Doing some 727 work for me/mates, when I realised one of them was a 76 model S/B. On close inspection I was unhappy with the planetary gear excess play! I could see from comparing it with an earlier trans that the gear set seemed indentical but the ring gear was different. Different spline angles and much lower heights as well. Even so the gear mess was excessive.
Am I right in thinking the ring gear is right but the planetaries has been changed. I thought the earlier ones do not fit on the later 75-on shafts?
Do the A518 4-5-6 gear planets fit the 76 727 shafts???
many thanx in advance Gtxxjon
Carpe diem, quam minimum credula postero, thanx Horace!
There’s no point trying to fix stuff that ain’t broke,,, 'but if ain’t broke',,, you is not trying hard enough...
[Re: Gtxxjon]
#2841668
11/04/20 12:56 PM
11/04/20 12:56 PM
John_Kunkel
Rio Linda, CA
Welcome to the board.
There are three different spline angles in the 727 front planetary.
The spline included angles are as follows:
'62-'75= 90°
'76-'93= 75°
'94-on= 60°
The spline angles are sometimes expressed as the pressure angle which is half the included angle (45°, 37.5°, 30°)
Each change affected the diameter of the splines so smaller shafts will fit in larger planetaries but the loose fit will lead to early failure.
Annulus gear diameter is unchanged.
