tin splash shield in oil pan? #622780
02/24/10 12:38 PM
02/24/10 12:38 PM
montreal, quebec, canada
jimmy71demon Offline OP
when i took the pan off my old 340 block there was a tin "splash shield" i call it, im thinking to make sure that when the crank is turning the oil doesnt splash all over the place and stays in the bottom of the pan. now i have accuired another block and put a stroker crank in it but it rubs on this shield. i tried denting the shield with a hammer everywhere the crank rubs but with little success. is this really what the shield is for, and do i need to put it back on? could i do without it, or do the make aftermarket ones specially for this?
thanks for ur input guys
Im goin fast Mom!
Re: tin splash shield in oil pan? [Re: jimmy71demon] #622781
02/24/10 12:51 PM
02/24/10 12:51 PM
Newfoundland
codfish Offline
codfish  Offline
Newfoundland
It's called a windage tray. It's designed to keep excess oil from being splashed around on the rotating assembly. Keeps more oil in the pan, around the oil pump pickup to prevent starvation, and is supposed to free up a few hp supposedly.
They are available aftermarket.
codfish
Re: tin splash shield in oil pan? [Re: codfish] #622782
02/24/10 02:08 PM
02/24/10 02:08 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Yhays not really a windage tray.The tray bolts to the mains on a SB.Thats a baffle to control slosh in the pan.Rocky
Chrysler Firepower
Re: tin splash shield in oil pan? [Re: therocks] #622783
02/24/10 02:59 PM
02/24/10 02:59 PM
Newfoundland
codfish Offline
codfish  Offline
Newfoundland
Learned something today
I have an RB.
codfish
Re: tin splash shield in oil pan? [Re: codfish] #622784
02/24/10 03:21 PM
02/24/10 03:21 PM
so is it a big deal if i dont put it back on with my stoker crank? or should i try and find an aftermarket one....?
Im goin fast Mom!
Re: tin splash shield in oil pan? [Re: jimmy71demon] #622785
02/24/10 06:12 PM
02/24/10 06:12 PM
Toronto, Ont, Canada
boydsdodge Offline
boydsdodge  Offline
I'd run one and if you can't get the stock one to fit, I am sure there is someone out there making them for the stroker.
Here is what I found in my Big inch Mopar small blocks book.
Windage is a loss of engine output due to excess oil getting in the way of the crankshaft and connecting rods.
Windage is a major problem on a stroker engine
since as the stroke getslonger, the crankshaft gets closer to the walls of the block and windage losses are increased.
I testing with a 408 stroker engine the typical losses due to windage are about 42 HP without the a proper windage tray.
Re: tin splash shield in oil pan? [Re: boydsdodge] #622786
02/25/10 11:08 AM
02/25/10 11:08 AM
WOW that much really? ok cool thanks for the info i will start my search for a windage tray to fit this application!
thanks again guys for ur input
Im goin fast Mom!
Re: tin splash shield in oil pan? [Re: jimmy71demon] #622787
02/25/10 04:57 PM
02/25/10 04:57 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Post a picture of the tin part that's hitting...
