Key wont turn off car????
#62270
05/23/08 08:02 PM
05/23/08 08:02 PM
Posts: 1,481 Outside
thedriver
Outside
So i fire the dodge up today, got her all warmed up nice, go to turn it off and the key didnt cut the ignition?? Power stayed on in the car. I went around the back of the car and killed it on the batt. disconect switch. Where do i start on this?? Is it the ignition switch in the steering column or like a simple wire somewhere. It seems like every spring when i start this car, some new gremelin pops up.
1973 challenger Dana. 4 speed. Low deck.
Re: Key wont turn off car????
[Re: thedriver]
#62271
05/23/08 08:05 PM
05/23/08 08:05 PM
I would think the ignition switch in the column myself.
[Re: thedriver]
#62272
05/23/08 08:10 PM
05/23/08 08:10 PM
Have you done any rewiring of the alternator. The alternator could be self exciting once it is spun up. You need to have the control input switched off with the key.
#62273
05/23/08 08:13 PM
05/23/08 08:13 PM
thedriver
Outside
the alternator? hmmm, was tuggin on those wires when i changed the valve cover gaskets...thats the first to check i guess!
[Re: thedriver]
#62274
05/23/08 08:34 PM
05/23/08 08:34 PM
Posts: 8,165 Left Coast
BobR
Left Coast
MSD ignition? If so and you are using a single wire alternator you have to put a resistor(MSD supplied) in the alternator. -Bob
[Re: DirectSubjection]
#62276
05/24/08 01:45 AM
05/24/08 01:45 AM
thedriver
Outside
a resistor in the alternator?? seems funny since ive had the msd for 7 years and no problems yet...why now?
[Re: thedriver]
#62277
05/24/08 01:59 AM
05/24/08 01:59 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
I think you mean a diode in the alternator field +12 Volt power line?
To test, just remove (unplug) the +12volt spade connector (or both connectors if your not sure which one is the +12 volt one) at the back of the alternator. Fire up the car, and try shutting it off. It should stop running if the problem was power feeding back from the alternator, if it keeps running, most likely the ignition switch circuit is still suppling power (bad key switch?)
Anyhow, if it is the alternator, install the diode. If you have a CD ignition like a MSD, there is a way that a resistor may help by adding it into the wire that senses the ignition is on (I think it is the small red wire?)
[Re: NachoRT74]
#62279
05/24/08 12:16 PM
05/24/08 12:16 PM
thedriver
Outside
thanx guys! gonna get my butt out to the garage and see what i can find this mornin here!
[Re: BobR]
#62281
05/24/08 01:07 PM
05/24/08 01:07 PM
thedriver
Outside
im not even sure what kind of alternator i have. its on a 73 340. arent the 1 wire alternators for the older vehicles??
