Intake gasket?? #621990
02/23/10 06:09 PM
02/23/10 06:09 PM
NY
W
WICKD6PK Offline OP
WICKD6PK  Offline OP
W
NY
OK had some work done to my intake and was wondering do you guys reuse the ol tub or go new??? I read the edelbrock instr that you have to use the paper gaskets also??? I have never used them just the plain ol tub. Thanks guys!
Re: Intake gasket?? [Re: WICKD6PK] #621991
02/23/10 06:14 PM
02/23/10 06:14 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
I have never used the tub with other gaskets together.
Those old tubs can be use many times, as long as they are in good shape...
I like that Shellac (sp?) Indian Head brush on stuff, usually has a brush made on the lid...Nasty stuff but does a very good job for these valley pans.
Advance carries some, I think Perma-Tex makes there brand of Shellac.
Re: Intake gasket?? [Re: Bob_Coomer] #621992
02/23/10 06:20 PM
02/23/10 06:20 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Re: Intake gasket?? [Re: WILD BILL] #621993
02/23/10 06:34 PM
02/23/10 06:34 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
Before I went to the Indy heads I always had a problem using the tub and paper gasket. So I made me a valley plate out of plexi-glass similar to the Indy plate.I stoped it at the bottom of the head and used silicon to seal it to the heads. That way I could use the nice thick Mr Gasket ones with no problem. And you could see down in the lifter area to check things out. But after a while it stain the glass and you could not see in the lifter area very well.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Intake gasket?? [Re: MRMOPAR622] #621994
02/23/10 07:19 PM
02/23/10 07:19 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
How thick was the Lexan?
Re: Intake gasket?? [Re: '72CudaRacer] #621995
02/23/10 07:26 PM
02/23/10 07:26 PM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
I use the valley pan and a gasket on each side. But I had to cut the intake so everything would line up properly.
Re: Intake gasket?? [Re: MRMOPAR622] #621996
02/23/10 07:30 PM
02/23/10 07:30 PM
michigan
sturmenater Offline
sturmenater  Offline
michigan
wow i think im going to steal that idea i wonder if i could coat the bottom side with a clear coat or something to keep it from staining
Re: Intake gasket?? [Re: Bob_Coomer] #621997
02/24/10 08:44 PM
02/24/10 08:44 PM
NY
W
WICKD6PK Offline OP
WICKD6PK  Offline OP
W
NY
thanks for the input guys i never used those gaskets either but just wanted to make sure i wasnt missin somethin thanks again!
