REAR AXLE SPRING PAD QUESTION?????????????????????????? #620280
02/21/10 09:12 PM
02/21/10 09:12 PM
alabama
mopars rule Offline OP
mopar addict
mopar addict
alabama
I am narrowing my 8 3/4 rear and tacked on the new spring pads and put it in the car for a trial fit before I get too far. Well the locating hole in the new mopar performance spring pads are larger than the originals causing a loose fit on the springs locating pin. Will this cause any issues? Can I use them? Should I find some spring pads with the smaller hole?
Re: REAR AXLE SPRING PAD QUESTION?????????????????????????? [Re: mopars rule] #620281
02/21/10 09:14 PM
02/21/10 09:14 PM
Rather be in Fallon, Nevada
RussW Offline
super gas
RussW  Offline
super gas
I'd get larger center bolts and drill out the springs.
Re: REAR AXLE SPRING PAD QUESTION?????????????????????????? [Re: mopars rule] #620282
02/21/10 09:28 PM
02/21/10 09:28 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
Weld in spacers, or plug and re-drill the holes again. The Mopar Perf units are basically the only ones that have this problem, all the others have the 1/2" hole
AL....
Alan Jones
Re: REAR AXLE SPRING PAD QUESTION?????????????????????????? [Re: LA360] #620283
02/21/10 09:53 PM
02/21/10 09:53 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Get a 3/8 pipe nipple and cut it up to make some spacers then tack them in place.
Re: REAR AXLE SPRING PAD QUESTION?????????????????????? [Re: The Shadow] #620284
02/21/10 10:06 PM
02/21/10 10:06 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I was going to say the same , weld up and redrill or use some tubing as a spacer.
Re: REAR AXLE SPRING PAD QUESTION?????????????????????????? [Re: The Shadow] #620285
02/21/10 10:19 PM
02/21/10 10:19 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
That's what I do.
Re: REAR AXLE SPRING PAD QUESTION?????????????????????? [Re: rowin4] #620286
02/21/10 11:21 PM
02/21/10 11:21 PM
Re: REAR AXLE SPRING PAD QUESTION?????????????????????????? [Re: mopars rule] #620287
02/22/10 12:03 AM
02/22/10 12:03 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
The larger spring center hole won't cause a problem because the hole in the shock plate locates the springs and the U-bolts locate the housing.
If you are paranoid about the large hole, just install a couple lock washers under the head of the spring center-bolt.
Re: REAR AXLE SPRING PAD QUESTION?????????????????????????? [Re: DoctorDiff] #620288
02/22/10 12:43 AM
02/22/10 12:43 AM
alabama
mopar addict
mopar addict
alabama
Thanks fellas, now I feel better. Why would the mopar perches have such a big locater hole instead of the stock size?
Re: REAR AXLE SPRING PAD QUESTION?????????????????????????? [Re: mopars rule] #620289
02/22/10 12:53 AM
02/22/10 12:53 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Mopar perches are actually stock Dakota pieces.
