Re: New trans slipping
[Re: Burlapen]
#619239
02/20/10 11:03 PM
02/20/10 11:03 PM
RapidRobert
Moving it back is going to up the throttle pressure & therefore up the line pressure and make it shift later/harder & less likely to slip. If it's 3/4 of the way back & it's slipping going around the block gently there's a serious problem if the fluid level is up & I'm sure you're on top of that. I'd wire it all the way back & retry it but this does not sound good
[Re: Burlapen]
#619242
02/21/10 05:13 PM
02/21/10 05:13 PM
Posts: 25,877 Rio Linda, CA
John_Kunkel
Rio Linda, CA
With the lever 3/4 of the way back you have all the pressure you need for medium throttle. Even with the TP linkage missing a new transmission shouldn't slip at medium throttle, it takes more than a few local miles to cause enough damage to make it slip noticeably.
