External oil kits #619168
02/20/10 10:00 PM
02/20/10 10:00 PM
corpus christi tex
Cheatham Offline OP
Cheatham  Offline OP
corpus christi tex
I ordered Milodon 21010 with external filter mounting cover21215, going in a Dart with slant6 schumacher conversion mounts there is NO way it going to fit, motor is installed with the HV oil pump and i opened up the fitting for a 1/2 pick up tube and was wanting to upgrade the oiling system, is there another kit i can exchange for or should i keep the set up that i already have. motor plate isnt an option. Has anyone dealt with this in this type of situation?
Re: External oil kits [Re: Cheatham] #619169
02/20/10 11:46 PM
02/20/10 11:46 PM
northeast texas
strokin73cuda Offline
northeast texas
I have no idea. for ya
496 stroker,Indy srs , new best 6.87 @ 98 1.46 60'
Re: External oil kits [Re: Cheatham] #619170
02/20/10 11:59 PM
02/20/10 11:59 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Can ya post some pic's of what you have??
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: External oil kits [Re: hemi-itis] #619171
02/21/10 12:27 AM
02/21/10 12:27 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
I know you dont want to hear this but a motor plate or elephant ears with some kind of other limiter is the best.
Its easy enough to mill the water pump housing, to make pulley alignment work.
Re: External oil kits [Re: Cheatham] #619172
02/21/10 01:48 AM
02/21/10 01:48 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Why won't the pump work?
Re: External oil kits [Re: rowin4] #619173
02/21/10 11:28 AM
02/21/10 11:28 AM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
i run the external stuff with motor mounts. i just used the milodon pump with a stock type cover, works well.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: External oil kits [Re: 68 HEMI GTS] #619174
02/21/10 01:27 PM
02/21/10 01:27 PM
corpus christi tex
Cheatham Offline OP
Cheatham  Offline OP
corpus christi tex
I see that Milodon has a similar set up as yours but next issue looks like the lower radiater hose will be in the way of the fitting on the front of the oil pump??
Re: External oil kits [Re: Cheatham] #619175
02/21/10 01:58 PM
02/21/10 01:58 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
There is a rubber hose that will work, Andy F had it listed in his book. At the time i put this together i didn't know about it so i just went with the blingy tuner hoses from summit.
