making a package tray cover? #618384
02/19/10 10:23 PM
02/19/10 10:23 PM
Rancho Cordova, CA
Exit1965 Offline OP
Exit1965  Offline OP
Rancho Cordova, CA
I don't have a package tray and want to cover up the area so I was thinking of making a cover of some thin wood.
Has anyone done this, and are there any tips for making the cutout match the contours of the package tray area? Its for a 67 Dart.
Thanks.
Re: making a package tray cover? [Re: Exit1965] #618385
02/19/10 10:29 PM
02/19/10 10:29 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
My 68 Road Runner had a custom interior which used thin (Laun?) plywood with vinyl covering. The package tray had been wrapped with cloth. I didn't keep the parts so I don't have pictures. I would think using some heavy cardboard that you can trim with scissors would work at making a template.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: making a package tray cover? [Re: RoadRunner] #618386
02/20/10 02:47 AM
02/20/10 02:47 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I recovered my junky old package tray. Coated it with contact cement and layed a piece of vinyl over top. Looks great considering I made it out of leftovers from my seat upholstery job.
Re: making a package tray cover? [Re: DaytonaTurbo] #618387
02/20/10 06:26 AM
02/20/10 06:26 AM
Sandy, OR
DART67GT Offline
DART67GT  Offline
Sandy, OR
Shag carpet is the way to go!
But seriously, just get some cardboard to make a template if you don't have the old package tray. Then use some whiteboard material or something similar to make the tray. Either paint it or cover with the material of your choice.
1967 Dodge Dart GT 3.23 sure grip 8.75/727/360 .020 over w/edelbrock heads 2000 Dodge Ram 2500 Quad Cab CTD
Re: making a package tray cover? [Re: DART67GT] #618388
02/20/10 08:52 AM
02/20/10 08:52 AM
BDW Offline
BDW  Offline
You can go to Home Depot, they have thin fiber board that is an exact match as far as thickness goes.
You can create a template with cardboard and thick paper stock, once you're happy with the fit, just transfer to the fiber board.
This can be covered, or just paint it.
Re: making a package tray cover? [Re: BDW] #618389
02/20/10 09:51 AM
02/20/10 09:51 AM
Big Sky Country
MO_PA Offline
MO_PA  Offline
Big Sky Country
When an old one isn't available for a pattern, make a cardboard template, then use a piece of 1/8 inch masonite, paint the rough side a color that matches the true color for your car.
Re: making a package tray cover? [Re: MO_PA] #618390
02/20/10 10:36 AM
02/20/10 10:36 AM
Rancho Cordova, CA
Exit1965 Offline OP
Exit1965  Offline OP
Rancho Cordova, CA
Thanks all, I will probably use masonite and make a paper/cardboard template.
Re: making a package tray cover? [Re: BDW] #618391
02/20/10 10:56 AM
02/20/10 10:56 AM
You can create a template with thick paper stock, once you're happy with the fit, just transfer to the fiber board.
Home Depot 1/8" fiberboard brown in color
Re: making a package tray cover? [Re: RapidRobert] #618392
02/21/10 03:15 PM
02/21/10 03:15 PM
Rancho Cordova, CA
Exit1965 Offline OP
Exit1965  Offline OP
Rancho Cordova, CA
Here's a pic of the final product..not perfect on the corners, but I shoved some black carpet pieces back there and it's hard to notice unless you look.
It's painted with some old flat black BBQ paint I had.
Re: making a package tray cover? [Re: Exit1965] #618393
02/21/10 03:19 PM
02/21/10 03:19 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Didn't see this in time to help but if anyone else is in need try using a large sheet of aliminum foil to make the template, you can force it into the corners & along the edges to form a perfect pattern...
BTW Your package tray looks great!
