Difference between steel and shaker hood emblems?????
#618311
02/19/10 09:30 PM
02/19/10 09:30 PM
Posts: 2,963 Wisconsin
Stewpar
Wisconsin
I show two different part numbers: #2888798 for steel and #3462273 for the shaker. This is written down in a binder from the OLD (pre-internet) days. Is this correct? I vaguely remember someone saying the shaker emblems have longer prongs?????
Admiration For Multiple Carburetor Vehicles...
Re: Difference between steel and shaker hood emblems???
[Re: Challenger 1]
#618313
02/19/10 10:39 PM
02/19/10 10:39 PM
Posts: 1,945 Grand Rapids MI
N9671X2
Grand Rapids MI
There tapered for the shaker...
I think this applies to some of the shaker emblems, like 426hemi, on some emblems I believe they are identical, except they have 3 pins rather than 2, example would be Cuda340. The shaker emblems have a 3rd pin in the middle, the outer two match the steel hood ones.
[Re: N9671X2]
#618315
02/20/10 07:21 AM
02/20/10 07:21 AM
Posts: 7,327 Toronto (YYZ) Ontario
YYZ
The tapering is for Challenger, rather than 'Cuda. However, only for the larger emblems such as 440 Sixpack and 426 Hemi. I have never seen a set of the 383 magnum shaker emblems to determine whether they are tapered, the 340 ones did not appear to be.
The 'Cuda emblems appear to be identical for steel hood & shaker hood, with the exception of the 3rd pin in the middle
[Re: floyd]
#618317
02/20/10 10:25 AM
02/20/10 10:25 AM
Stewpar
Wisconsin
I should have specified 1970 'Cuda. I knew the Challenger had been tapered. Does anyone have the description of the NOS #'s I gave in the original post?
[Re: floyd]
#618319
02/20/10 12:17 PM
02/20/10 12:17 PM
N9671X2
Grand Rapids MI
Sorry, I have no personal experience to back it up but I'd guess the "cuda 440-6" would not be tapered but would have three pins.
agree
[Re: floyd]
#618320
02/20/10 02:21 PM
02/20/10 02:21 PM
Posts: 3,624 Fort Worth, Texas
xs29j8
Fort Worth, Texas
Here is a `Cuda 440-6 Shaker nameplate...
Re: Difference between steel and shaker hood emblems?????
[Re: Stewpar]
#618321
02/20/10 03:20 PM
02/20/10 03:20 PM
Posts: 4,165 Florida
cataclysm80
Strangely worded question. Steel hood vs Shaker hood? Shaker hoods were made of steel. As far as I know, the hood emblem on the front of the hood (if it had an emblem) is the same whether it was a shaker hood or other hood. There is the Fratzog emblem, the DODGE lettering, or the Plymouth emblem. Not all the hoods had emblems though. It depends on make & model. Engine callout emblems have some differences, but again, they're not on all hoods. None on flat hoods or T/A or AAR hoods. On shaker hoods they go on the shaker bubble instead of the hood itself. What are you working on? Tav
[Re: Stewpar]
#618324
02/20/10 06:51 PM
02/20/10 06:51 PM
cataclysm80
I could have sworn that someone told me the Shaker hood emblems had longer prongs on them since the it was thicker? (shaker bubble)..........
The anodized aluminum hood trim on the front of a T/A hood uses longer retainers because the fiberglass hood is thicker than the steel hood.
Sorry I can't be much more helpful on the engine callouts. I have several pics, but I think they're all showing the installed emblem, so no pics of the pegs.
I've got some 340 emblems from a 'cuda here on a spare J54 hood. If info from them would help, tell me what you need.
Tav
[Re: xs29j8]
#618325
02/20/10 07:01 PM
02/20/10 07:01 PM
Stewpar
Wisconsin
Alan: Could I trouble you for the part number? Thank you!
[Re: Stewpar]
#618326
02/20/10 07:30 PM
02/20/10 07:30 PM
xs29j8
Fort Worth, Texas
Paul - The one pictured earlier is an original one from my 1970 `Cuda 440-6, and the part number is 3462273. Attached is a picture showing the 3462273 compared to a part number 2998761 "NOS" replacement nameplate purchased from Chrysler in the early 1980s...
Allen
[Re: Stewpar]
#618328
02/20/10 09:11 PM
02/20/10 09:11 PM
xs29j8
Fort Worth, Texas
Thanks Allen, that helps! Is the car in your avatar the 440-6bbl car? If so, where was it built?
Yes, that is my `Cuda 440-6 in the avatar... see attached pic.
On the design change for nameplate attachment, I have always thought it was due to reducing manufacturing costs... three nut attachment replaced by a simple push in attachment. Later in the 70s most nameplates were self adhesive, and later plastic self adhesive.
Here is 'Ole Yeller... built in Los Angeles, sold new in Aurora, Colorado... BS23V0E115XXX
[Re: Stewpar]
#2479866
04/09/18 11:00 AM
04/09/18 11:00 AM
Posts: 1,131 Home of the Bluegrass
MoparJunkie
Would anyone have the length of what the 383 and 440 shaker emblems are? I have the 426 hemi and 440 sixpack emblems with three pins, and I bought the 383 two pin emblems, however they are nowhere near the length of the two prior emblems.... Just wanting pics or confirmation of what I have or need???? TIA
"It takes a Mopar to catch a Mopar” 1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54 2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
