any R5/P7 turbocharged motors out there? #618004
02/19/10 04:19 PM
02/19/10 04:19 PM
Europa, Estonia
Georg Offline OP
Georg  Offline OP
Europa, Estonia
From day to day Iam more and more thinking to trie build my new R5/P7 motor with turbocharger. Seems very interesting and ofcorse cost a lot, but seems to be worth to trie...? I got some good tips from "go green" but everyone who have some hints/tips to share are welcome!
Georg
Outlaw Plymouth Valiant R5/P7 Powered by Liuzzo Racing COMP Performance Group dealer in Baltic Premium Performance
Re: any R5/P7 turbocharged motors out there? [Re: Georg] #618005
02/21/10 09:57 AM
02/21/10 09:57 AM
Europa, Estonia
Georg Offline OP
Georg  Offline OP
Europa, Estonia
nothing?
Re: any R5/P7 turbocharged motors out there? [Re: Georg] #618006
02/22/10 12:28 PM
02/22/10 12:28 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Go for it!
I don't see why you shouldn't unless there's rules against it for the class you're going to be racing.
- Stu Harmon
Re: any R5/P7 turbocharged motors out there? [Re: feets] #618007
02/22/10 02:15 PM
02/22/10 02:15 PM
Europa, Estonia
Georg Offline OP
Georg  Offline OP
Europa, Estonia
There is no motor limits in our "ProStreet" class. What I ask here is help from you who have been there and done that. I mean building turbocharged race motor/motors. As turbo motors are quite new for me, I want to hear as many tips and thoughts as possible to make this project work first time and good.
Georg
Re: any R5/P7 turbocharged motors out there? [Re: Georg] #618008
02/22/10 02:45 PM
02/22/10 02:45 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Then turbocharge and beat the other guys.
Like any other engine, keep it out of detonation. A turbo motor is less violent than a nitrous motor. It will live much longer.
It's not that hard to build. A moderate engine with sufficient boost will make serious power.
You need to think about air flow. It needs to get in and out as easily as possible, just like any other engine. A fairly mild cam will work fine and require less exotic valvetrain.
- Stu Harmon
Re: any R5/P7 turbocharged motors out there? [Re: feets] #618009
02/22/10 03:43 PM
02/22/10 03:43 PM
Europa, Estonia
Georg Offline OP
Georg  Offline OP
Europa, Estonia
Just that are there any R5/P7 Dodge motors out there which is turbocharged? I heard that there is...
I ask it because what to know what good/bad sides R5/P7 motor have for turbocharging? Are the lower end strong enough etc.? Heads seems to be very good for doing it...
Re: any R5/P7 turbocharged motors out there? [Re: Georg] #618010
02/22/10 04:38 PM
02/22/10 04:38 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
Go here and ask your questions they will be happy to advise you. http://www.smreperformance.com/
I asked them about turbo on my hemi99 motor and they advised against it. They said the pro stock motors have light internal parts and could not take alot of boost(like 2000+ hp) Maybe the Nascar motors would be different, i dont know, but you could ask them and find out.
Re: any R5/P7 turbocharged motors out there? [Re: B1Fish540] #618011
02/22/10 05:08 PM
02/22/10 05:08 PM
Europa, Estonia
Georg Offline OP
Georg  Offline OP
Europa, Estonia
thanks I will do it
Re: any R5/P7 turbocharged motors out there? [Re: Georg] #618012
02/22/10 11:38 PM
02/22/10 11:38 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Three things to think about:
1) Most connecting rods fail on the exhaust stroke. The heavy piston flies upwards and there's no cushion of air (compression) to help slow it down. The crank pulls the rod down but the piston keeps going. It rips the rod in half and the piston slams the head.
With a turbo motor there's some back pressure in the exhaust stroke. The piston is pushing the air into the turbo and creates boost in the exhaust header. That boost helps slow the piston. It's not an impressive amount of force but it is there.
2) RPM = death. If you spin a motor faster to make more power you're going to have trouble. Spinning an engine at 7200 rpm makes internal stress 144% higher than spinning it at 6000 rpm. If you keep the engine speed moderate you can make more power using turbos with less stress.
3) Maybe this chart will help you understand internal engine pressures better. The turbo motor in this chart makes twice the power of the naturally aspirated motor BUT the peak pressure is only increased 20%.
Slow the engine down 1200 rpm and turbocharge it to make more power with less stress on the connecting rods as well as the rest of the engine.
- Stu Harmon
Re: any R5/P7 turbocharged motors out there? [Re: feets] #618013
02/23/10 02:21 AM
02/23/10 02:21 AM
Europa, Estonia
Georg Offline OP
Georg  Offline OP
Europa, Estonia
Thanks a lot, "feets"
Re: any R5/P7 turbocharged motors out there? [Re: Georg] #618014
02/23/10 07:03 PM
02/23/10 07:03 PM
back home in georgia ,lake sid...
105630 Offline
105630  Offline
I don't understand the people who say an 99 hemi can't be turbocharged.Yes you can't or don't want the rotating assembly the prostock guys use ,that given -I have a new crank ,rods and pistons and thick wall wrist pins that were made to my specs and see no reason this engine will not make power,the only thing I don't like is the block ,but it is a carbon block .They twist these engines to 10 thousand rpms and then drop the clutch and they seem to hold up petty good.Maybe I'm hard headed but I expect at least 2500 plus horsepower out this thing and that is not dreaming .If you are going to turbo any engine count on changing just about everything but block and heads ,and buy the best for the intended horsepower you plan and be honest in your goal and then go do it.If you listen to someone tell you it can't be done ,your never know if it will.
Re: any R5/P7 turbocharged motors out there? [Re: 105630] #618015
02/23/10 07:14 PM
02/23/10 07:14 PM
105630 Offline
105630  Offline
My opinion on the r5 p7 engine is the engine would be a great turbo engine,you just not going to get a lot of cubic inches out of it .Another item is the head gasket ,with the open deck ,I don't know how it would handle high boost pressures a turbo is going to make.I would think if you look at what the ford guys did a few years back with the 360 to 400 cubic inch engine that they ran single turbos on ,would give you a fair idea what a r5 could do .They took an engine with less head clamping and made it work and I don't see why it wouldn't work peroid.I would like to do one myself ,but in my class I need cubic inches.
Re: any R5/P7 turbocharged motors out there? [Re: 105630] #618016
02/24/10 12:15 PM
02/24/10 12:15 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
I was surprised they advised agaist it too. i was going to use all the stock components, tho, so maybe thats why they said that. I agree, the block is very strong and i think your motor will make all kinds of power!(and live!)
Re: any R5/P7 turbocharged motors out there? [Re: B1Fish540] #618017
02/26/10 08:55 AM
02/26/10 08:55 AM
Orlando Fl
Dos Snails Offline
Dos Snails  Offline
Orlando Fl
It would be nice to see some first hand info on the R5/P7 under hard boost. I'm sure that Troy's R5 build was / is at low PSI. The only drawback with the open deck would be the cylinders moving around under high boost. It seems to be a issue in imports cars but the the R5 or the 99 Hemi is a lot stronger but still a issue nun the less..
Re: any R5/P7 turbocharged motors out there? [Re: Dos Snails] #618018
02/27/10 10:52 AM
02/27/10 10:52 AM
british columia canada
P
polara408 Offline
polara408  Offline
P
Didn't Jesel build a Ram pickup with a twin turbo R5 to run on the salt flats a couple years ago. I think it did 200mph. I have an R5 P7 sitting in the shop.I was thinking of the turbo thing as well. Keep us posted on the progress.
Re: any R5/P7 turbocharged motors out there? [Re: polara408] #618019
02/28/10 06:15 AM
02/28/10 06:15 AM
Europa, Estonia
Georg Offline OP
Georg  Offline OP
Europa, Estonia
Re: any R5/P7 turbocharged motors out there? [Re: Georg] #618020
02/28/10 04:45 PM
02/28/10 04:45 PM
Orlando Fl
Dos Snails Offline
Dos Snails  Offline
Orlando Fl
Sweet!
Re: any R5/P7 turbocharged motors out there? [Re: Georg] #2186518
10/31/16 10:26 AM
10/31/16 10:26 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
Did you ever boost your R5?
Re: any R5/P7 turbocharged motors out there? [Re: Georg] #2186716
10/31/16 02:33 PM
10/31/16 02:33 PM
Cab_Burge Online work
Cab_Burge  Online Work
I know a 10.5 racer that used all three types of power adders including twin 88 MM turbo. Intercooling using race gas is mandatory to keep the motor out of detonation. He chose a water to air intercooler (it was twice as big as all the other racers in his class, he won that series every year he raced in it including when he used a Pro Charger work) with ice in it and he said to use the biggest one you can up
That was a real high $$$ maintenance motor though, short parts life work
IHTHs thumbs
Re: any R5/P7 turbocharged motors out there? [Re: Georg] #2186728
10/31/16 02:39 PM
10/31/16 02:39 PM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
I heard rumors Wayne Jesel's boosted R5 made 2400hp..
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
