Re: 64 dodge polara help finding parts
[Re: demonbeekeepr]
#617672
02/19/10 08:53 AM
02/19/10 08:53 AM
Posts: 1,443 Maryland
Dads426
Maryland
I used a hemi scoop from WS Racing in Ohio on our 64 Plymouth. Ok in quality and price, but needs some work if you want it perfect. The Sled City Fiberglass is probably a better piece.
Not sure on the clear emblems. Try Kraemer (sp?)Automotive.
Disc brakes; any of the kits from PST, Summit, ebay work and are pretty reasonable (they provide new spindles). Some don't have brake hoses.
Also on 64's if you are converting from power brakes to manual (get a dual master cylinder) you will need a new brake pedal. The ratio is different.
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
[Re: pushbutton]
#617676
02/19/10 10:31 AM
02/19/10 10:31 AM
I think Bill's Special T's also sells the lenses.
I'd either go with the A-body spindle, rotor and caliper setup or the Wilwood setup. It bolts up really nice to drum spindles but costs around $700.00. It's also quite a bit lighter!
#617677
02/19/10 11:13 AM
02/19/10 11:13 AM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
Just find A body 73 up discs.They will bolt on as will later F M and I believ J body discs.Then get a 69 C body master for discs.Only other thing you need is a prop valve.If you find a setup from a disc car use that valve.I have late B body setup on my 65.They are a bit taller than the A body and work fantastic.Try and stay away fro the early discs as the rotors are expensive.If you go with factory discs use ceramic pads.I have them on the 65 and they stop great.Rocky
Chrysler Firepower
[Re: 383man]
#617680
02/19/10 10:58 PM
02/19/10 10:58 PM
Posts: 1,058 Dallas, Texas
FC7cuda
Dallas, Texas
I've got some of the emblems and some other parts. Drop me a PM with your email and I;ll send some pics. Tom
68 Charger 70 Cuda
