Re: B--1 Originals a thing of the past ?
[Re: Gearbox]
#617304
02/18/10 09:29 PM
02/18/10 09:29 PM
Posts: 2,128 Salt Lake City
camastomcat
Salt Lake City
With all the new CNC cylinder Head options out today, do you think the B-1's are a thing of the past for Race Motors. Seems intake options are limited, compared to todays products. Looking to spec my 500 low deck , thought about B1's but now considering others due to intake choices Indy, Eddy,all seem to be good for this power range. 800hp goal with original block on a budget.
Those heads aren't even close to the B1's. B1's are good to 604 CI and over 1000HP. The -1's,SR, edelbrock RPM, or victors are not even in the same class. They work fine for a street/strip deal, but not for all out racing. And if you want to really pick up the pace, Predators or PSO's will get it done for the wedge motors. JMHO
[Re: Gearbox]
#617306
02/18/10 09:38 PM
02/18/10 09:38 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
B1's a very much a option. CNC programs are out there for these heads as well. 800 hp is doable with Indy -1's but would need full tilt porting max effort deal. Its not going to happen with 10:1 compression. My Indy engine is easily in that hp range, but its 15:1 compression, alky injected, CNC ported heads, .800 roller,but does have a cast intake etc. So it can be done. It be hard not to build 800 hp with a nice set of B1 Originals 13-14:1 compression and cast intake, and Dominator carb, .750-.800 lift solid roller. I dont want to sound like a spoil sport, but 800hp with a stock block is really, really pushing it. A stock block of tis caliber would need to be girdled, and aftermarket main caps, hard block etc... But at this point a aftermarket block can be purchased for the same money and actually live.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: AndyF]
#617309
02/18/10 09:56 PM
02/18/10 09:56 PM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
Well B1 original heads only have the one intake that fits and it only really fits on low deck blocks so that is a limitation. But it is a very good intake design that is very capable of supporting a bunch of power.
Only issue I see with the B1 design is that those heads make more power than is really safe for a production low deck block. And the aftermarket isn't making cast iron low deck blocks. Someone either needs to design a RB version of the intake manifold or someone needs to do a low deck mega block.
One or the other would open up a whole new chapter for Mopar race motors.
I call BS on that one..
Stop trying to scare potential users away.
Gecker has been using 400 blocks for the duration of these heads, making 900+hp constantly..
Very few failures in nearly 20 years..
Just do everything right like anyone would do on higher hp engines and you will have no problems..
Chris..
[Re: camastomcat]
#617310
02/18/10 10:24 PM
02/18/10 10:24 PM
Posts: 19,377 Las Vegas
Al_Alguire
Las Vegas
Ummmmm.......B1 heads are from from a thing of the past. They are something that many folks seem to be intimidated by or misinformed about. They have been a round for a number of years and have always worked very well. Although they seem to be a mistery to many Mopar loyalists. As someone stated earlier you can dang near fall out of bed and make 800+hp. IMO if you are making less than 850 with a set of originals with minor porting you are doing something wrong. In my book they are the best bang for the buck out there in a Mopar head and the B1 intake is the best piece out there for a Mopar cast single four intake.
[Re: roadhazard]
#617311
02/18/10 11:15 PM
02/18/10 11:15 PM
Posts: 2,840 Flint, Michigan
B1Fish540
Flint, Michigan
The standard B1's use a Max Wedge opening and standard bolt location.
Use an Indy, E'Brock Victor or even a tunnel ram
B1's are Top Notch in my book. Besides try to get some personalized help and info out of the others.
No, the b1 intake port is bigger than a max Wedge, by quite a bit. So the only intake that will work is the B1 cast dominator intake. Which is pretty good, since it is the best flowing cast intake anyway.
Also, Andy, the B1 intake is used on RBs all the time with the spacers Koffels provides.
The B1, B1-MC and PSO are the best flowing inline valve heads period. The OP needs to do more research.
[Re: B1Fish540]
#617312
02/18/10 11:27 PM
02/18/10 11:27 PM
Posts: 660 San Diego
formula S
San Diego
I'll bet he's talking about b1 bs heads
[Re: joshking440]
#617314
02/18/10 11:47 PM
02/18/10 11:47 PM
Posts: 1,015 Down South
DaKuda
Down South
I call BS on two things: 1. B1 heads are outdated....BS.....AWESOME heads 2. INDY 440-1 are not a good race head....BS....Ive seen them in the 8's quite often. This post is how crap gets started. If anyone has a set of OUTDATED B1 heads wanting to trade for a set of these.....RACE.....Edelbrock RPM's (as stated) Im MORE than willing to trade for your B1's....I can make do with them.....
[Re: Bob_Coomer]
#617320
02/19/10 05:47 AM
02/19/10 05:47 AM
Posts: 2,933 Finalnd, Perkele
jyrki
Finalnd, Perkele
Anyone ever comapred flow against port area between Indys and B1's?
Plynouth VIP '67 TT IC EFI
[Re: jyrki]
#617321
02/19/10 08:14 AM
02/19/10 08:14 AM
Posts: 694 Michigan
Super Scamp
Rank and File!! here's the chain of command on the Heads issue From the bottom to the top.. Cast stock heads with a port job. Aluminum heads Eddies,Edelbrock,MP,440 Source all above with port work. Indy cast, with port work Indy Aluminum with port work then B1 with port work and the current all mighty PREDATOR!!1 Now the rank and file the cost just keeps going up as you upgrade for better flow..
Just One Man's Opinion
Mopar Mafia Racing
[Re: formula S]
#617322
02/19/10 10:02 AM
02/19/10 10:02 AM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
I stand corrected, thinking about 1 and typing another
FWIW the BS heads will replace the Indy-1's currently sitting in my garage.
[Re: Super Scamp]
#617325
02/19/10 10:51 AM
02/19/10 10:51 AM
Posts: 3,441 Mo.
supercomp
Mo.
Do you have a Mopar in that corvette? If so
[Re: MuscleMike]
#617326
02/19/10 11:17 AM
02/19/10 11:17 AM
Posts: 31,051 Oregon
AndyF
Andy:
The B1 RB manifold situation is being "addressed."
I'm not at liberty to say but......stay tuned!
Mike @MM
Good news. It was always one of those "obvious" holes in the aftermarket that just never seemed to get filled. Now if someone would just do a dual plane max wedge intake with a 4500 flange!
[Re: Super Scamp]
#617327
02/19/10 12:23 PM
02/19/10 12:23 PM
B1Fish540
Flint, Michigan
There is one head that flows nearly the same as(or better than) B1s and it deserves to be mentioned although it is no longer made...the "Brewer". fred Brewers design was based on the AMC pro stock head and has longer/narrower ruuners and longer valves than a B1. Some of these features are in the B1-PSO(pro stock option) now sold by Best Machine.
[Re: AndyF]
#617328
02/19/10 12:30 PM
02/19/10 12:30 PM
B1Fish540
Flint, Michigan
Andy:
Mike @MM
I dont know why anyone would want something like that, Andy. It would not be legal for NSS. Sheet metal TR would get the job done better.
[Re: AndyF]
#617331
02/19/10 08:49 PM
02/19/10 08:49 PM
B1Fish540
Flint, Michigan
The C-454 was fairly popular back in the day. I think it would be even more popular these days given the number of 500+ inch street motors running around.
The Indy DP can be reworked for a 4500 flange so that is about the only option for a guy with a big street motor who wants to run a Dominator.
Seems to me it wouldn't cost much of anything for Indy to produce a 4500 verison of the DP intake. A very minor change to the casting would add the material and then it is just a super easy change to the CAD file to produce either 4150 or 4500 versions. A little bit extra inventory on hand and people have a whole new option.
well, i like the way you think, Andy..a dual dom B1 street motor? now thats thinkin out side the box!
[Re: B1Fish540]
#617332
02/19/10 09:05 PM
02/19/10 09:05 PM
IIRC, somebody will be coming out with an intake to allow B1s in NSS.
ill be going with 800 edelbrocks on my 605 b1 ts motor.
