26" Radiator Shroud Repros #61691
05/22/08 04:27 PM
05/22/08 04:27 PM
The Historic Hudson Valley
MONC Offline OP
MONC  Offline OP
Does anyone know if the 26" fan shrouds be reproduce fit the E bodies with the 340 sixpacks?
In any description I found it only mentions big blocks, so I was wondering if there is a difference either in the shroud itself or the mounting bolt holes.
Re: 26" Radiator Shroud Repros [Re: MONC] #61692
05/22/08 04:29 PM
05/22/08 04:29 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
same shroud with 26 inch radiators
2998326 still avail at any mopar dealer
I stock them btw
Re: 26" Radiator Shroud Repros [Re: gtx6970] #61693
05/28/08 07:18 PM
05/28/08 07:18 PM
MONC Offline OP
MONC  Offline OP
Thanks, and what about the correct mounting bolts?
Anyone know the right sizes and correct type?
Re: 26" Radiator Shroud Repros [Re: MONC] #61694
05/28/08 07:30 PM
05/28/08 07:30 PM
At a gas station near you
badblack68 Offline
badblack68  Offline
The 26" radiator uses 5 special nut to attach the shroud. I have them in stock and I`m sure that Bill does as well.
Re: 26" Radiator Shroud Repros [Re: badblack68] #61695
05/28/08 08:19 PM
05/28/08 08:19 PM
Calgary, Alberta Canada
m46rat Offline
m46rat  Offline
It uses four small square clips that attach themselves to the radiator side brackets, two per bracket. Then you need four finely threaded bolts with very small hex heads(SEMS stamped on early 1970 model year bolt heads and a stylised "P" stamped on all later ones) and large washers to attach the shroud to the rad brackets You can get the NOS bolts(silver zinc plated) and clips from Roger Gibson. They are for all 26" E and B Body rads.
Re: 26" Radiator Shroud Repros [Re: MONC] #61696
05/29/08 06:13 AM
05/29/08 06:13 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
This is what was on my Dec built 1970 challenger
instock as well btw
#8 - 32 X 3/4"
Re: 26" Radiator Shroud Repros [Re: gtx6970] #61697
05/29/08 10:40 AM
05/29/08 10:40 AM
m46rat Offline
m46rat  Offline
Bill: Those four bolts will secure your rad to the rad support, but they are waaaaay tooo big to fit those four clips that you show, I will post a pic. of the proper bolts used for the shroud tonight.
Re: 26" Radiator Shroud Repros [Re: m46rat] #61698
05/29/08 04:22 PM
05/29/08 04:22 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Dwight
I know the picture makes them look bigger than they actually are. But trust me they are the correct size to fit the clips shown and correctly secure the shroud.
Radiator to rad support bolts are 1/4-20 x 3/4" with a 1" captive washer
also in stock.
Re: 26" Radiator Shroud Repros [Re: gtx6970] #61699
05/29/08 04:38 PM
05/29/08 04:38 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
comparison pic of the 2 different bolts shown above
Re: 26" Radiator Shroud Repros [Re: gtx6970] #61700
05/29/08 08:25 PM
05/29/08 08:25 PM
cataclysm80 Offline
cataclysm80  Offline
Good to know those are available. I scrounged several from a junk yard looking for ones with good threads. Also picked up some overflow hose clips.
Tav
Re: 26" Radiator Shroud Repros -Bolts [Re: cataclysm80] #61701
06/18/08 01:37 PM
06/18/08 01:37 PM
MONC Offline OP
MONC  Offline OP
Anyone else repro these?
Haven't heard back from Bill, and I need them ASAP
Re: 26" Radiator Shroud Repros -Bolts [Re: MONC] #61702
06/18/08 03:00 PM
06/18/08 03:00 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I'm right here,
Call now if you want
