Performer intake 383 #616855
02/18/10 11:49 AM
02/18/10 11:49 AM
San Antonio, TX
CurYellowBird Offline OP
San Antonio, TX
I'm messing with camquest and was wondering if the performer intake for a 383 would be considered standard flow, high flow, or max flow dual plane intake?
Anyone had good luck with this intake? I use it on my sbc and haven't had any problems. I just want to have a dual plane intake that takes some weight off the engine. I removed the stock intake and that sucker is HEAVY! I'm young and thought I was gonna get a hernia.
Found a guy nearby selling one in good shape for 100$.
Project War Bird: 1971 Plymouth Roadrunner 383 4 speed with air conditioning GY3 Curious yellow All original
Re: Performer intake 383 [Re: CurYellowBird] #616856
02/18/10 12:06 PM
02/18/10 12:06 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
The performer will do just what you want. It is much lighter than the OEM cast manifold and will give a slight bit more performance.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: Performer intake 383 [Re: MoparforLife] #616857
02/18/10 12:17 PM
02/18/10 12:17 PM
San Antonio, TX
San Antonio, TX
Does it flow any better than a HP 383 intake manifold?
Re: Performer intake 383 [Re: CurYellowBird] #616858
02/18/10 01:57 PM
02/18/10 01:57 PM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
It does flow slightly better.As far as the computer program it is a std flow intake.The Performer RPM is the ticket and is worth the increased price.
Leave the gun.......take the Cannoli's....Mike
Re: Performer intake 383 [Re: mike s] #616859
02/18/10 02:26 PM
02/18/10 02:26 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Hot Rod's 383 intake shootout part 1 didn't show any performance difference between the regular performer intake and the perf RPM when used on a 383 with bone stock heads and a decent cam.
Re: Performer intake 383 [Re: DaytonaTurbo] #616860
02/18/10 04:48 PM
02/18/10 04:48 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I always joked with the edelbrock guys that all they did with the Performer was cast the stock intake in aluminum and then turn it around backwards (look at one and you'll see what I mean!)
WIZE
In Car:
Re: Performer intake 383 [Re: Streetwize] #616861
02/18/10 05:26 PM
02/18/10 05:26 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
even if that's all they did, it saves a good 20lbs off the nose of the car! my cast iron intake is freaggin HEAVY!
but in terms of flow, yea, I'd say the performer is equal to, or a tad better than stock flow.
now performer RPM that's much taller, will flow a lot better than stock.
**Photobucket sucks**
Re: Performer intake 383 [Re: CurYellowBird] #616862
02/18/10 07:33 PM
02/18/10 07:33 PM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
The Performer is an improvement over the standard
manifold, not only in weight savings but in
performance. It parallels the HP manifold and is
very close to the M1 dual plane. The Performer
RPM is a great manifold which extends the power/
torque range over the Performer, given the proper
cam is installed. The benefit of the RPM is that
you retain "some" low end power while gaining
power midrange and top end. For a stock vehicle
this may be a good manifold, but the single plane 6 times out 10, gets the nod when modified. The
Performer is considered probably a standard flow
while the RPM may be the higher flow type. Check
on this though, I may not be accurate. Good
luck with this.
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: Performer intake 383 [Re: Streetwize] #616863
02/18/10 07:52 PM
02/18/10 07:52 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Actually Bobby, you're close. It IS the DP4B, turned around.
