Re: SCUMACHER MOUNTS FOR HEMI
[Re: old_racer]
#616737
02/18/10 09:44 AM
02/18/10 09:44 AM
Posts: 4,923 new berlin wisconsin
Mr T2U
i have hemi with schumacher mounts on a big block k member in a 72 road runner. TTI headers. motor sits a bit higher and off to one side, don't remember witch side. it really isn't that far off so you can't make some small adjustments to make it fit. i have a buddy who installed several hemi's with repo mounts and k members and had just as much trouble getting things to fit as i did with mine. on mine i would use the 2 1/8" tube headers instead of the 2 1/4" ones.
perception is 90% of reality
[Re: HemiStan]
#616739
02/18/10 10:20 AM
02/18/10 10:20 AM
Posts: 17,914 S.E. Michigan
ZIPPY
S.E. Michigan
Which conversion mounts are better, Schumacher or Arruzza? Arruzza looks a little more robust, but the left mount is a solid....
Rich H.
Esse Quam Videri
[Re: Mr T2U]
#616742
02/19/10 03:12 AM
02/19/10 03:12 AM
Posts: 8,857 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
ok i opend up the box and looked at them and i guiess mine are neither came with a paperwork showing other mounts and by tinman fabrickation in oak grove mn. (tinmanfabrication.com) these are the ones sold off e bay and are orange (in the ad) but thay cope pawder coated black and apear to be very nicely made came with all the bolts even to bolt to the block ![](/ubbthreads/images/graemlins/Twocents.gif)
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
[Re: toplescuda]
#616743
02/19/10 03:37 AM
02/19/10 03:37 AM
Posts: 10,167 A Red State
SNK-EYZ
A Red State
A buddy of mine has the Schumacher mounts on his 70 Hemicuda clone with a SHAKER hood and everything lines up perfectly. Schumachers website http://www.engine-swaps.com/
[Re: old_racer]
#616744
02/19/10 08:35 AM
02/19/10 08:35 AM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
Any one use the schumacher mounts to put a 426 hemi on a std big block k-member?, this is a 68 roadrunner. thought I read somewhere that the motor sat a little higher. I want to use headers. thanks Russ
I used them on a 69 RR. Fit perfect, but you need to check things. Stuff was all over the map back then
