Test results for our RTR FireCore Distributor. #616439
02/17/10 10:48 PM
02/17/10 10:48 PM
Cleveland
sunroofgtx Offline OP
Cleveland
All good news. Done by an independent test company that actually sells their own distributors. These will be here early March, but the coils 2 weeks after. You need a very good coil to run it. Notice zero degree's retard at 8000 rpm.
Box-CWS Ready to Run Distributor Coil-CWS Epoxy type
Test Parameters:
Pressure vessel charged at 3000PSI Nitrogen
Sun Distributor Machine
Ambient temp 62*F
Plugs gapped at .045
Plug Wires CWS FireCore 250
Test plugs Autolite 85
Total run and test time 1 hour 40 minutes
Full load 8000 RPM for 30 Minutes
Test Voltage 14V
OUTPUT TIMING
1000 ___32_____KV __0_____
2000 ___40_____KV __0_____
3000 ___42_____KV __0_____
4000 ___42¬_____KV __0_____
5000 ___42_____KV __0_____
6000 ___42_____KV __0_____
8000___42___KV __0____
Through Ballast resistor ___Not Required
Direct at 14V Volts to coil _X__
Test time Full load 30 minutes
Max Coil temp 100*F after 10 minutes, increase in temp to 128* after 30 minutes full RPM
Open Ground test 52,000 Volts, jumped to ground through case.
Opinion: From our testing the distributor and coil as tested were flawless and should offer more than adequate output on almost any naturally aspirated application up to the tested max RPM of 8000.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: Test results for our RTR FireCore Distributor. [Re: sunroofgtx] #616440
02/17/10 11:22 PM
02/17/10 11:22 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Sweet
Congrats on the results
Re: Test results for our RTR FireCore Distributor. [Re: sunroofgtx] #616441
02/17/10 11:35 PM
02/17/10 11:35 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
cool. sorry if i sound dumb but is this a GM HEI stile DIS? IF so are you going to come out with a MSD stile dis that use a separate control box? Can you tell me or pm what the cost will be. sounds like a nice set up.thanks Mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: Test results for our RTR FireCore Distributor. [Re: mopar65] #616442
02/17/10 11:42 PM
02/17/10 11:42 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
Cool.... ...when are the caps available seperately?
Re: Test results for our RTR FireCore Distributor. [Re: mopar65] #616443
02/18/10 12:03 AM
02/18/10 12:03 AM
Cleveland
Cleveland
Not even close to a GM. actually, it's the best parts of a lot of makes. There are a lot of factors that went into it to make it overkill. I believe we are the only distributor out there that out of the box, retards zero degree's, all the way to 8 grand. We had to make our own coil to keep up with it. No joke. He tested other coils, and they stoped at 5200 rpm. Our mechanical's will plug right into a msd unit.
ready to run vacuum on left, and mech on right.. These distributors will work with OEM caps and out HEI style caps.
Re: Test results for our RTR FireCore Distributor. [Re: sunroofgtx] #616444
02/18/10 02:27 AM
02/18/10 02:27 AM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
any pictures?
will you be selling coil and distributor together?
Re: Test results for our RTR FireCore Distributor. [Re: 70blackfish] #616445
02/18/10 09:44 AM
02/18/10 09:44 AM
Cleveland
Cleveland
The distributor will be out first. Closely followed by the coil..
Re: Test results for our RTR FireCore Distributor. [Re: sunroofgtx] #616446
02/18/10 10:26 AM
02/18/10 10:26 AM
NY usa
540challenger Offline
NY usa
Can these distributors be used with a Mopar performance chrome box or will they only work with a MSD type set-up?
Re: Test results for our RTR FireCore Distributor. [Re: 540challenger] #616447
02/18/10 02:48 PM
02/18/10 02:48 PM
Richmond Va, KeislerTKO 60...
V
VanishPt Offline
VanishPt  Offline
V
How do you adjust the curve?
Re: Test results for our RTR FireCore Distributor. [Re: sunroofgtx] #616448
02/18/10 03:32 PM
02/18/10 03:32 PM
wisconSIN
Blown61 Offline
Blown61  Offline
wisconSIN
Which coils gave up at 5200??
Re: Test results for our RTR FireCore Distributor. [Re: VanishPt] #616449
02/18/10 05:06 PM
02/18/10 05:06 PM
Cleveland
Cleveland
You adjust it as you do with the Mopar style lockout, and the advance is done with springs.
I don't have the names of the coils that gave out right now..
Yes, MSD boxes can be wired in. It's the same procedure as the RTR MSD distributor's. Check this out. Page 6 http://www.msdignition.com/instructions/Products/8360.pdf?terms=8360
The gold box is not compatible with our vacuum advance ready to run distributors. Our distributor is a capacitor discharge unit, not an inductive discharge.
Re: Test results for our RTR FireCore Distributor. [Re: sunroofgtx] #616450
02/18/10 05:43 PM
02/18/10 05:43 PM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
Few little questions. Maybe they are stupid but oh well.
Can it be used with a Crank trigger and become more of just a "dummy" distributor? Maybe you have a option which you will make just a dummy one?
Also you have any idea when it could start to sprak scatter?
I ask this because I'm running a MSD 10 system with some Real nice FIRECORE wires but have a Malory "dummy" crank trigger distributor which i do not think is the best even as just a dummy. Also i'm having a hard time finding replacement parts for it.
Re: Test results for our RTR FireCore Distributor. [Re: sunroofgtx] #616451
02/18/10 07:12 PM
02/18/10 07:12 PM
wisconSIN
Blown61 Offline
Blown61  Offline
wisconSIN
Does you coil put out more power then others?
Re: Test results for our RTR FireCore Distributor. [Re: Blown61] #616452
02/18/10 07:24 PM
02/18/10 07:24 PM
NE Ohio
DoubleD Online content
DoubleD  Online Content
NE Ohio
Nice - does that have the mopar pick-up what about the cap is that a mopar style cap also?
Re: Test results for our RTR FireCore Distributor. [Re: DoubleD] #616453
02/18/10 08:20 PM
02/18/10 08:20 PM
Cleveland
Cleveland
We engineered all of our distributors to accept both the OEM Mopar cap, AND our HEI style cap.
I am sure any distributor could be used as a dummy. I will check and get back.
Yes, our cd coil can be used as a standard coil, but a non-cd coil can not be used with our R T R distributors. To put it in perspective. It is in between an MSD SS and an HVC II.
Re: Test results for our RTR FireCore Distributor. [Re: sunroofgtx] #616454
02/19/10 01:50 AM
02/19/10 01:50 AM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
do you make your own caps?
Re: Test results for our RTR FireCore Distributor. [Re: 70blackfish] #616455
02/19/10 08:32 AM
02/19/10 08:32 AM
Cleveland
Cleveland
I can't make anything like that. I am the only company that you can get these from, if thats what you mean...
Re: Test results for our RTR FireCore Distributor. [Re: sunroofgtx] #616456
02/19/10 11:21 AM
02/19/10 11:21 AM
AndyF Offline
AndyF  Offline
Sounds great. I'll have to get my hands on the setup for one of my dyno mules.
Re: Test results for our RTR FireCore Distributor. [Re: AndyF] #616457
02/19/10 11:54 AM
02/19/10 11:54 AM
Overland Park, KS.
Joshs68 Offline
Joshs68  Offline
Overland Park, KS.
If I were to change over to the HEI style cap vs the OEM cap could I send in my wires and get the ends changed?
Re: Test results for our RTR FireCore Distributor. [Re: Joshs68] #616458
02/19/10 02:02 PM
02/19/10 02:02 PM
Cleveland
Cleveland
If you have enough length, of course we could swap out the ends. We will run a special, I'm sure. Maybe swap them for free if you buy a distributor, except shipping of course..
