lost oil pressure Found the problem #616066
02/17/10 08:04 PM
02/17/10 08:04 PM
gulfport, ms, west mi
rowin4 Offline OP
rowin4  Offline OP
Lost oil pressure at the end of a run yesterday. Looked down as it was dropping to 0. Shut off the engine, coasted off the track. Checked the block , no holes, over full on the oil because of the accumilator, fired it back up , no oil pressure so I loaded it up. Today pulled the dizzy thought maybe the pump shaft may have broke or stripped, perfect shape, pulled the valve covers , thought maybe a rocker or push rod broke allowing a lifter to come out, every thing good there, pulled the pan, not a spec of anything in it. I have never heard of a big block pump going bad or do they. What should I look at next? Usually holds 45-50 at a hot idle and 70-75 hot at high rev's.
Re: lost oil pressure [Re: rowin4] #616067
02/17/10 08:35 PM
02/17/10 08:35 PM
PA
moparacer Offline
moparacer  Offline
PA
How much oil did you drain out of it?
It didn't get low and uncover the pickup for a second did it?
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: lost oil pressure [Re: rowin4] #616068
02/17/10 08:37 PM
02/17/10 08:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Well I guess your down to the pump or filter
Re: lost oil pressure [Re: MR_P_BODY] #616069
02/17/10 08:41 PM
02/17/10 08:41 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
I lost oil pressure on my R5 last weekend. My input shaft bushing fell out of my crank spacer, to the inside of the crank. With the bushing adding that much weight and the clutch being off center. It took out my rear main bearing...
Luckily it didn't wreck anything.....
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: lost oil pressure [Re: DemonDust] #616070
02/17/10 08:45 PM
02/17/10 08:45 PM
Fredericksburg Va
P
plycuda Offline
plycuda  Offline
P
Fredericksburg Va
might check and see if something got in the releif valve.Thats what mine did had no pressure at all.
Re: lost oil pressure [Re: rowin4] #616071
02/17/10 08:59 PM
02/17/10 08:59 PM
Wisconsin
1964maxwedge Offline
Wisconsin
I would check to make sure you ,didn't pop out a lifter out of the bore .I ran into the same problem thats what mine was.
Re: lost oil pressure [Re: plycuda] #616072
02/17/10 09:16 PM
02/17/10 09:16 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
If you like drag racing, support your local track.
Re: lost oil pressure [Re: CHAPPER] #616073
02/17/10 09:26 PM
02/17/10 09:26 PM
Phoenix, AZ
Comp_Chassis Offline
Phoenix, AZ
Have you verified that the gauge is actually working? I have seen gauges fail before.
Re: lost oil pressure [Re: Comp_Chassis] #616074
02/17/10 09:44 PM
02/17/10 09:44 PM
rowin4 Offline OP
rowin4  Offline OP
Drained out 2 1/2 galloons, pan 7 plus 3 accumitator. Lifter was the second thought, I checked them , all ok Both the gage's are mechanical , both 0. The filters a 2qt. wix racing remote, can't see that just plugging up. I'll pull the pump tomorrow and take a look.
Re: lost oil pressure [Re: plycuda] #616075
02/18/10 12:56 AM
02/18/10 12:56 AM
northeast texas
strokin73cuda Offline
northeast texas
Is it external fed? May be sucking air somewhere.
496 stroker,Indy srs , new best 6.87 @ 98 1.46 60'
Re: lost oil pressure [Re: rowin4] #616076
02/18/10 05:03 AM
02/18/10 05:03 AM
Central Oregon
Rodney Offline
Rodney  Offline
Central Oregon
if the accumulator had oil in it wouldn't you have to have oil pressure for it have been full?
Re: lost oil pressure [Re: Rodney] #616077
02/18/10 04:43 PM
02/18/10 04:43 PM
Sidney,Ohio
challenger1320 Offline
Sidney,Ohio
I would bet the bypass is stuck in the oil pump
Re: lost oil pressure [Re: challenger1320] #616078
02/18/10 05:12 PM
02/18/10 05:12 PM
UK
602heavy Offline
602heavy  Offline
UK
Oil pick up fallen off?
Re: lost oil pressure [Re: challenger1320] #616079
02/18/10 05:16 PM
02/18/10 05:16 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Re: lost oil pressure [Re: 602heavy] #616080
02/18/10 05:48 PM
02/18/10 05:48 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Re: lost oil pressure [Re: 602heavy] #616081
02/18/10 05:56 PM
02/18/10 05:56 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Can that thing un-screw on a BB without crashing into
something(when the pan is on.... maybe broke off
but like some of the others I believe the by-pass
is stuck open
Re: lost oil pressure [Re: Rodney] #616082
02/18/10 06:12 PM
02/18/10 06:12 PM
rowin4 Offline OP
rowin4  Offline OP
Yes that is correct , but as you lose pressure the accumulator empties to try to make up for the loss of pressure which it did. The engine has a external oil system , the pick up is a static mount , lines were all tight and nothing on the screen. I ordered a new pump today, don't want to have another problem with that one. Hope that's what the problem is. Thanks for the info guy's
Re: lost oil pressure [Re: rowin4] #616083
02/18/10 08:11 PM
02/18/10 08:11 PM
UK
602heavy Offline
602heavy  Offline
UK
Gallery plug fallen out.
Had a flex plate bolt tear the rear gallery plug to bits.
Re: lost oil pressure [Re: 602heavy] #616084
02/18/10 11:18 PM
02/18/10 11:18 PM
Cab_Burge Online work
Cab_Burge  Online Work
(quote)
I have had the bypass plug come out of the pump, also had one customers motor missing one of the internal galley plug not installed, the one behind the cam gear Also have had several bypass valves stick in the oil pump, always at,WOT
Re: lost oil pressure [Re: Cab_Burge] #616085
02/21/10 02:17 AM
02/21/10 02:17 AM
rowin4 Offline OP
rowin4  Offline OP
The problem was that the by pass cap unscrewed and let the valve slide out to a point that it wedged and wouldn't return. Removed the cap and spring, inspected the little piston and reassembled. Used some blue lock tight this time.It primed right up with the drill , reassembled every thing I took apart and fired the engine. Oil pressure is back up to normal. Thanks every body for your input.
