lost oil pressure Found the problem
#616066
02/17/10 08:04 PM
02/17/10 08:04 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
Lost oil pressure at the end of a run yesterday. Looked down as it was dropping to 0. Shut off the engine, coasted off the track. Checked the block , no holes, over full on the oil because of the accumilator, fired it back up , no oil pressure so I loaded it up. Today pulled the dizzy thought maybe the pump shaft may have broke or stripped, perfect shape, pulled the valve covers , thought maybe a rocker or push rod broke allowing a lifter to come out, every thing good there, pulled the pan, not a spec of anything in it. I have never heard of a big block pump going bad or do they. What should I look at next? Usually holds 45-50 at a hot idle and 70-75 hot at high rev's.
Re: lost oil pressure
[Re: rowin4]
#616067
02/17/10 08:35 PM
02/17/10 08:35 PM
Posts: 2,514 PA
moparacer
PA
How much oil did you drain out of it?
It didn't get low and uncover the pickup for a second did it?
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: rowin4]
#616068
02/17/10 08:37 PM
02/17/10 08:37 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Well I guess your down to the pump or filter
[Re: Comp_Chassis]
#616074
02/17/10 09:44 PM
02/17/10 09:44 PM
rowin4
Drained out 2 1/2 galloons, pan 7 plus 3 accumitator. Lifter was the second thought, I checked them , all ok Both the gage's are mechanical , both 0. The filters a 2qt. wix racing remote, can't see that just plugging up. I'll pull the pump tomorrow and take a look.
[Re: 602heavy]
#616081
02/18/10 05:56 PM
02/18/10 05:56 PM
MR_P_BODY
Oil pick up fallen off?
Can that thing un-screw on a BB without crashing into something(when the pan is on.... maybe broke off but like some of the others I believe the by-pass is stuck open
[Re: Rodney]
#616082
02/18/10 06:12 PM
02/18/10 06:12 PM
rowin4
if the accumulator had oil in it wouldn't you have to have oil pressure for it have been full?
Yes that is correct , but as you lose pressure the accumulator empties to try to make up for the loss of pressure which it did. The engine has a external oil system , the pick up is a static mount , lines were all tight and nothing on the screen. I ordered a new pump today, don't want to have another problem with that one. Hope that's what the problem is. Thanks for the info guy's
