Help with 426 hemi ID #615492
02/17/10 01:51 PM
02/17/10 01:51 PM
Pennsylvania
3
300vert Offline OP
300vert  Offline OP
Pennsylvania
I recently acquired a (I think) 1968 426 hemi and I was hoping to learn whatit might belong to. There is no VIN on the bellhousing or the pad on the block side. The oil pan rail is stamped:
3-7-68
R2 HC
NM42624290001
"maltese cross"
The top pad of the engine is stamped:
SM
105
Any thoughts on what this engine came out of? Thanks!
Re: Help with 426 hemi ID [Re: 300vert] #615493
02/17/10 01:59 PM
02/17/10 01:59 PM
Arkansas
beatupcuda Offline
beatupcuda  Offline
Arkansas
OK, once I respond you should get plenty of people telling you different,
if there is no vin stamped, then it was bought over the counter, as a bare block or replacement
and did not come in anything
Re: Help with 426 hemi ID [Re: 300vert] #615494
02/17/10 02:10 PM
02/17/10 02:10 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
The 3-7-68 is the build date.
The "maltese cross" means the bearings are .001 undersize.
The NM42624290001 should be the casting # with sequence, but the number doesn't look like anything I have seen.
The stampings on the pad are weird too.
They should be F(letter) 426, with the letter being the year, with 1968 = D, but I have never seen SM 105.
So check that you have cross bolts on the center 3 mains, and that the top 4 head studs go into the valley area. That's the real way to tell if it's a Hemi block.
If it is a Hemi block, then I suspect it was purchased separately and was not part of a production build.
Re: Help with 426 hemi ID [Re: 300vert] #615495
02/17/10 02:42 PM
02/17/10 02:42 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
It seems odd that it has the 'NM42624290001' stamping, which has an assembly date, and then has the 3-7-68 stamped also. I don't have access to Snoopy's 10,000 day calendar convertor, it would be interesting to see if the two dates match. What is the casting date on the block? It would have to be a '68 casting to have the VIN pad. It may be a service shortblock. Does it have the rivet above the center soft pug opening? Can't remember which side. For street Hemi's, '66 is stamped BH426 and '67 is stamped CH426. '68 and later blocks do not have the year code and displacement stamped on the distributor pad. Typcially they will have 'WT' stamped (or 'TW' as I have seen) for water tested.
Re: Help with 426 hemi ID [Re: Mopar_Rich] #615496
02/17/10 02:49 PM
02/17/10 02:49 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
3-7-68
R2 HC
NM42624290001
"maltese cross"
SM
105
Pictures would help ALLOT
Just based on what you've posted I'll have to make a few assumptions.
3-7-68 = Engine short block assembly date
R2 HC = Need to see a pic of that to go further
NM42624290001 = NM (normally stamped MN) Marrysville Plant
426 = 426 Cubic inch engine
2429 = Final assembly date March 22,1968
"maltese cross" = .001 undersize crankshaft
SM = S = "Service" M is likely a "W" which would be Water Tested Block, a "T" would normaly be there as well.
105 engine build sequence
As mentioned above by another poster it's likey a Service Assembly sold over the counter or installed under warranty. Look for signs of a rivot or a metal tag on the side near a freeze plug boss, service/warranty engines all had them.
Re: Help with 426 hemi ID [Re: ScottSmith_Harms] #615497
02/17/10 02:51 PM
02/17/10 02:51 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Tag
Re: Help with 426 hemi ID [Re: ScottSmith_Harms] #615498
02/18/10 09:45 AM
02/18/10 09:45 AM
Pennsylvania
3
300vert Offline OP
300vert  Offline OP
Pennsylvania
Some pictures from my not so great camera of the stampings and casting date. Cast date is 1/15/68.
Re: Help with 426 hemi ID [Re: 300vert] #615499
02/18/10 09:46 AM
02/18/10 09:46 AM
Pennsylvania
3
300vert Offline OP
300vert  Offline OP
Pennsylvania
More pictures
Re: Help with 426 hemi ID [Re: 300vert] #615500
02/18/10 09:47 AM
02/18/10 09:47 AM
Pennsylvania
3
300vert Offline OP
300vert  Offline OP
Pennsylvania
Oil pan rail
Re: Help with 426 hemi ID [Re: 300vert] #615501
02/18/10 09:48 AM
02/18/10 09:48 AM
Pennsylvania
3
300vert Offline OP
300vert  Offline OP
Pennsylvania
and another
Re: Help with 426 hemi ID [Re: 300vert] #615502
02/18/10 10:08 AM
02/18/10 10:08 AM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
S.M. Sox and Martin?
