Re: Help with 426 hemi ID
[Re: 300vert]
#615493
02/17/10 01:59 PM
02/17/10 01:59 PM
Posts: 209 Arkansas
beatupcuda
Arkansas
OK, once I respond you should get plenty of people telling you different, if there is no vin stamped, then it was bought over the counter, as a bare block or replacement and did not come in anything
[Re: 300vert]
#615495
02/17/10 02:42 PM
02/17/10 02:42 PM
Posts: 10,731 North Dakota
6PakBee
North Dakota
It seems odd that it has the 'NM42624290001' stamping, which has an assembly date, and then has the 3-7-68 stamped also. I don't have access to Snoopy's 10,000 day calendar convertor, it would be interesting to see if the two dates match. What is the casting date on the block? It would have to be a '68 casting to have the VIN pad. It may be a service shortblock. Does it have the rivet above the center soft pug opening? Can't remember which side. For street Hemi's, '66 is stamped BH426 and '67 is stamped CH426. '68 and later blocks do not have the year code and displacement stamped on the distributor pad. Typcially they will have 'WT' stamped (or 'TW' as I have seen) for water tested.
[Re: Mopar_Rich]
#615496
02/17/10 02:49 PM
02/17/10 02:49 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
The oil pan rail is stamped: 3-7-68 R2 HC NM42624290001 "maltese cross" The top pad of the engine is stamped: SM 105 Any thoughts on what this engine came out of? Thanks!
Pictures would help ALLOT
Just based on what you've posted I'll have to make a few assumptions.
3-7-68 = Engine short block assembly date R2 HC = Need to see a pic of that to go further NM42624290001 = NM (normally stamped MN) Marrysville Plant 426 = 426 Cubic inch engine 2429 = Final assembly date March 22,1968
"maltese cross" = .001 undersize crankshaft
SM = S = "Service" M is likely a "W" which would be Water Tested Block, a "T" would normaly be there as well.
105 engine build sequence
As mentioned above by another poster it's likey a Service Assembly sold over the counter or installed under warranty. Look for signs of a rivot or a metal tag on the side near a freeze plug boss, service/warranty engines all had them.
