69 Charger. N88 speed control???? #614970
02/16/10 09:31 PM
02/16/10 09:31 PM
Glendale, AZ
69L78Nova Offline OP
Banned. Forever.
Banned. Forever.
Glendale, AZ
My 69 Charger has N88 on the fender tag. The only problem is, I cant find ANY evidence that this car ever had it installed. It has a 1 piece speedo cable, no switches inside, but has 3 strange holes on the inner fenderwell above the shock on the drivers side, behind the fender tag. Does anyone have a pic of what it would look like installed on a car? Id love to piece it back together over time, but need to know more about it.
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: 69 Charger. N88 speed control???? [Re: 69L78Nova] #614971
02/16/10 09:53 PM
02/16/10 09:53 PM
Houston, Tx
hemi68charger Offline
Houston, Tx
Real quick what I found from Chris' '69 Charger site..
Troy
Houston Mopar Connection Club
Re: 69 Charger. N88 speed control???? [Re: 69L78Nova] #614972
02/16/10 10:08 PM
02/16/10 10:08 PM
People's Republic of Kali
70runner Offline
70runner  Offline
As the pic illustrates the servo unit mounts there. I had a 70RR with cruise control. Many folks in the day removed this system, perhaps what happened to your Charger.
Servos from C bodies will work, except I believe the mounting bracket may be different.?. Also need control lines. The hardest thing to find will be correct t/s cruise control stick on the steering column. I used to have a big supply of these but sold them all off.
Re: 69 Charger. N88 speed control???? [Re: 70runner] #614973
02/16/10 10:20 PM
02/16/10 10:20 PM
Glendale, AZ
Banned. Forever.
Banned. Forever.
Glendale, AZ
Wow, this is interesting. It appears I have some serious parts hunting ahead of me!
1969 Nova
454/M21/3.31
5.0/4R70W/3.55
(Daily driver)
Re: 69 Charger. N88 speed control???? [Re: 69L78Nova] #614974
02/16/10 11:17 PM
02/16/10 11:17 PM
Tracy, New Brunswick, Canada
magnumcharger Offline
I bought a loaded (but rusty) 1969 Charger SE a few years ago, that had this option.
I sold the column and all the cruise parts for $600.
D'oh!!
Re: 69 Charger. N88 speed control???? [Re: magnumcharger] #614975
02/16/10 11:40 PM
02/16/10 11:40 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
My '68 had "auto speed control".
It was physically all there, but I never had it working.
Re: 69 Charger. N88 speed control???? [Re: 6bblgt] #614976
02/17/10 10:17 AM
02/17/10 10:17 AM
n/w, PA
demonH1B Offline
demonH1B  Offline
n/w, PA
I see on this thread a picture of a correct
looking '69 Charger R/T engine with a dual
snorkel air cleaner. Was there a rule on
'68 & '69 440 R/T's which ones got the
dual snorkel and which got the unsilenced?
I have seen them both ways.
Re: 69 Charger. N88 speed control???? [Re: demonH1B] #614977
02/17/10 10:38 AM
02/17/10 10:38 AM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
I'll forwan you. 1969 and prior cruise control parts are extremely difficult to locate.
the hardest part is going to be the brake switch. 1969 and older uses a vacuum interupt brake switch where as 1970 and later uses an electrical interupt switch.
The only pieces to interchange are the column switch, the servo bracket and the cables, the lost motion link might be the same, but I've never verified it .
The servo,both related electrical and vacuum harness's and brake switch and it's related mounting bracket are non-interchangable
Re: 69 Charger. N88 speed control???? [Re: hemi68charger] #614978
02/17/10 01:33 PM
02/17/10 01:33 PM
Minneapolis, MN
hemi70se Offline
hemi70se  Offline
Minneapolis, MN
That has got to be a pic from a 69 Charger R/T I had 20 years ago! How many Q5 Charger RT's would have had cruise. The A/C, discs, and dual snorkle air cleaner are also dead give-aways. It had that style AC because it was a Calif sold N95 noise reduction pkg car. I would definately like to know where you got that pic exactly.
Re: 69 Charger. N88 speed control???? [Re: hemi70se] #614979
02/17/10 01:40 PM
02/17/10 01:40 PM
Minneapolis, MN
hemi70se Offline
hemi70se  Offline
Minneapolis, MN
Here's a pic of it I scanned
Re: 69 Charger. N88 speed control???? [Re: hemi70se] #614980
02/17/10 01:43 PM
02/17/10 01:43 PM
Minneapolis, MN
hemi70se Offline
hemi70se  Offline
Minneapolis, MN
Interior shot showing:
cruise lever
power windows
6 way seat
A/C
tach
console
AM-FM
woodwheel
It's got to be the most loaded 69 Charger RT
Re: 69 Charger. N88 speed control???? [Re: hemi70se] #614981
02/17/10 05:47 PM
02/17/10 05:47 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
cruise lever
power windows
6 way seat
A/C
tach
console
AM-FM
woodwheel
Damn good question where I got that pic because I just checked my registry files & cant match that pic with the other pics of Q5 cars I have.
Your right that car is loaded but I know of some that top that one!
I only have 2 Q5/W1 cars registered....only 1 with a white top & stripe. No luggage rack or power windows though.
More engine shots here (another with cruise as well)
http://www.1969chargerregistry.com/gallery/engineshots
1MYTGTX
Re: 69 Charger. N88 speed control???? [Re: 1MYTGTX] #614982
02/20/10 02:39 AM
02/20/10 02:39 AM
Alberta, Canada
DRAG Offline
DRAG  Offline
Alberta, Canada
WOW! That is my dream 69 Charger R/T
Q5/W1 & full load! Where is that gem?
