Hemi Ignition Coil #614917
02/16/10 08:15 PM
02/16/10 08:15 PM
western PA
mopar4ya Offline OP
mopar4ya  Offline OP
western PA
Does anyone have a real NOS or original ignition coil they could post a picture of. I checked into having a reproduction coil silk screened today, and was told he couldn't do it? I was told I had to have an original that is shorter and fatter than other coils.
Dan.
Re: Hemi Ignition Coil [Re: mopar4ya] #614918
02/17/10 02:23 AM
02/17/10 02:23 AM
Turneffe
BJohnson Offline
BJohnson  Offline
Turneffe
Original '70 coil.
Re: Hemi Ignition Coil [Re: mopar4ya] #614919
02/17/10 02:25 AM
02/17/10 02:25 AM
Turneffe
BJohnson Offline
BJohnson  Offline
Turneffe
Reproduction coil.
Re: Hemi Ignition Coil [Re: BJohnson] #614920
02/17/10 07:22 AM
02/17/10 07:22 AM
western PA
mopar4ya Offline OP
mopar4ya  Offline OP
western PA
So, are the reproduction coils different in height and diameter than an original? Is it legal for someone to silk screen a reproduction?
Dan.
Re: Hemi Ignition Coil [Re: mopar4ya] #614921
02/17/10 10:08 AM
02/17/10 10:08 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Myself and Beepbeep talked with Tom at M+H a few years ago on this very subject.
There were at least 2 different venders suppling coils to Mopar back in the day.
Essix coils were typically green lettered and will have the 'made in usa ' printed on . Then there was the yellow lettered coil, that will have the 'made in usa ' cast into the top plastic hat of the coil near the tower (sorry,I can't remember who the vender was of the top of my head)
Yellow lettered coils 'as a general rule' were approx 1965 and earlier, ALTHOUGH some newer cars up until at least 1970 have been found with yellow lettered coils.
Essix also used at least 3 or 4 different can to casing crimp styles.
So variations in can size is a possibility.
So, it may very well be possibile to have a differnet can on various models thru the years.
Also, Tom has an internal enginering sheet to specify the change in lettering style on the can. approx Nov 1967 the CH412 was to be deleted from the case lettering, all coils prior to this date should have it, and if you allow approx 30-60 days to enter production approx anything after Jan 1968 will not have it.
ps- I have several used originals on hand as well as the repops, I'll do a comparison on can dimensions this weekend to compare and report back.
I also have a few NOS coils on hand but they're all 1972 date thus have the square box/mopar flag on them so I don't know if the can design will be relevant
WITH the CH412
Without
Re: Hemi Ignition Coil [Re: mopar4ya] #614922
02/17/10 11:32 AM
02/17/10 11:32 AM
Turneffe
BJohnson Offline
BJohnson  Offline
Turneffe
Dan.
Why would you want to go through all the expense of silk screening a coil when an exact reproduction is available? The Essex reproduction coils are identical to the originals in size lettering etc.. as they were reproduced from the original factory drawings. They also produce a little more voltage than the originals. They are also a licensed Chrysler product.
Re: Hemi Ignition Coil [Re: BJohnson] #614923
02/17/10 11:48 AM
02/17/10 11:48 AM
indiana
mopar mike Offline
mopar mike  Offline
indiana
who has them?? thanks
Re: Hemi Ignition Coil [Re: mopar mike] #614924
02/17/10 11:53 AM
02/17/10 11:53 AM
Turneffe
BJohnson Offline
BJohnson  Offline
Turneffe
Get a hold of Bill. They are date coded also, so make sure you specify your SPD.
Re: Hemi Ignition Coil [Re: gtx6970] #614925
02/17/10 09:08 PM
02/17/10 09:08 PM
western PA
mopar4ya Offline OP
mopar4ya  Offline OP
western PA
WITH the CH412
Without
Bill, thanks for taking the time getting me the info. I had bought a date coded coil from M&H for my engine. I have it mounted on my engine but not happy with the way it looks. When I was getting things adjusted and moved the coil a couple of times, the lettering was rubbing off, even though it was loose in the bracket. Seems if you look at the lettering wrong it rubs off. Not complaining, just the way it is.
SO,since I am running a Pertronics electronic ignition and I had bought their Blaster coil, I thought I would have it silk screened and use it. When I called PCG, I was told I had to have an NOS or original to have it done. Dave told me it had to be the shorter/fatter coil to be correct. I thought I have read of other people running a blaster coil that had been silk screened to look like an original.
I'm just confused. First I didn't know the multiple carb engines used a different coil, and second that I couldn't get a aftermarket unit done.
Dan.
Re: Hemi Ignition Coil [Re: mopar4ya] #614926
02/18/10 02:16 AM
02/18/10 02:16 AM
Turneffe
BJohnson Offline
BJohnson  Offline
Turneffe
No, that should not be the "way it is". Tom needs to be contacted and made aware of the problem as a lot of time and thought was put into the production of the coils. A problem cannot be fixed if no one speaks up that it is a problem.
Re: Hemi Ignition Coil [Re: BJohnson] #614927
02/18/10 12:10 PM
02/18/10 12:10 PM
Elizabethtown, KY
6T9Hemi Offline
6T9Hemi  Offline
Elizabethtown, KY
I picked up a green printed coil from Frank B. and had about half the numbers rubbed off when moving it in the bracket. Don't know where he gets his coils but the numbers and lettering rubs off very easy.
1969 340 4 Speed Swinger R4,
black vinyl, white butt stripe, 3:91
Re: Hemi Ignition Coil [Re: 6T9Hemi] #614928
02/18/10 07:52 PM
02/18/10 07:52 PM
was a total POS, letters fell off. as soon as i put it in the bracket. sent it to PCG, to redo.
Re: Hemi Ignition Coil #614929
02/18/10 09:04 PM
02/18/10 09:04 PM
western PA
mopar4ya Offline OP
mopar4ya  Offline OP
western PA
That's why I started this thread. I was wanting to have a pertronics unit done, or send the reproduction and have done since my numbers and lettering is coming off. Dave at PCG said I had to have an original for them to do it. Guess I should have asked if they would do a reproduction, before I assumed they wouldn't.
I don't know Tom at M&H, just glad someone picked up the ball and offered a reproduction coil. Maybe someone that deals with them could talk with them and come up with a better way to get the lettering to stick.
Thanks!
Dan.
Re: Hemi Ignition Coil [Re: mopar4ya] #614930
02/20/10 01:32 PM
02/20/10 01:32 PM
Dave Stuart (Chrysler) and I have been talking about something that might go over pretty well with the restoration enthusiast. What would you guys think about a dry transfer (similar to our VIN plate overlay) that is patterned from original artwork, has the same green color, looks completely original when applied and is very durable? It would allow you to restore these coils yourself! If there is enough interest I can start the manufacturing process after hearing some feedback.
Re: Hemi Ignition Coil #614931
02/20/10 04:07 PM
02/20/10 04:07 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Dave,
That sounds like an excellent solution for a common problem. I would buy a couple.
I am suprised that Dave at PCG doesn't require a copy of your Broadcast sheet, picture of your fender tag and VIN tag before he offers to do your coil.
Re: Hemi Ignition Coil [Re: Snoopy] #614932
02/20/10 04:08 PM
02/20/10 04:08 PM
Elizabethtown, KY
6T9Hemi Offline
6T9Hemi  Offline
Elizabethtown, KY
I would be in for a couple.
Re: Hemi Ignition Coil #614933
02/20/10 04:15 PM
02/20/10 04:15 PM
Snoopy Offline
Snoopy  Offline
Dave,
I know you offer the voltage regulator stamping service, have you considered offering a transfer?
Re: Hemi Ignition Coil [Re: Snoopy] #614934
02/20/10 04:18 PM
02/20/10 04:18 PM
Dave,
That sounds like an excellent solution for common problem. I would buy a couple.
SNOOPY, i know what your talking about PCG wanting all that documentation,but i want everyone to know without the documentation a restoration shop gave dave at PCG on my 69 tx9 hemi roadrunner, i would never had gotten my car and fender tag and dash vin back from this restoration shop out of O'Fallon Illinois.
Dave was able to retrieve my documentation to hand to the judge in court to win a decision to get my car back from this thief.
it worked out for me and i am so grateful that Dave at PCG had my documentation.
Re: Hemi Ignition Coil #614935
02/20/10 07:29 PM
02/20/10 07:29 PM
western PA
mopar4ya Offline OP
mopar4ya  Offline OP
western PA
If they look as nice as the M&H when new with ALL lettering intact, YES! I would buy one today.
Dan.
Re: Hemi Ignition Coil [Re: mopar4ya] #614936
02/21/10 01:50 AM
02/21/10 01:50 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
i would also buy one, kind of did my own on a MSD blaster II, not even close to the repo's but better than the MSD red coil at a glance.
