duster rear shock bolts
#61453
05/22/08 08:50 AM
05/22/08 08:50 AM
I pulled the shock bolts off the old shocks to clean up and install new shocks yesterday. These are not just a regular bolt,and the threads were a litttle messed up,so I decided to replace them. No luck finding them. I used a thread chaser to clean up the threads,worked great. Now the nut on the shock side is trashed,apears to be of a softer alloy. Where can I get these? Or,where can I order complete new bolts? No luck at the part stores,rockauto,just suspension,fastener shop. What does everyone else do, I'm not the only one who replaces shocks. thanks for any help! John
Re: duster rear shock bolts
[Re: bobby66]
#61455
05/22/08 09:23 AM
05/22/08 09:23 AM
No luck at yearone. I did see a shock hardware kit that was a couple regular bolts,nuts and the convex washers for another aplication for a mere $73! They sure like makin' money.
#61456
05/22/08 09:55 AM
05/22/08 09:55 AM
did you try MoPar? i'm sure they have what you need.
#61457
05/22/08 10:22 AM
05/22/08 10:22 AM
mopar has discontinued the parts.
[Re: 05dakota]
#61459
05/22/08 10:34 AM
05/22/08 10:34 AM
It's basically a 6" stud with a big stop in the middle(looks like a big washer but is machined as part of stud). One side goes through the trunk floor and the other is the shock side.
[Re: Moonraker]
#61461
05/22/08 11:11 AM
05/22/08 11:11 AM
Posts: 13,610 md
mopars4ever
md
2071714 stud - www.bradsnosparts.com shows to have 4 of them. Sorry, nobody shows the nuts 152371. This was referenced to the 72 model year. Have Brads double check the numbers for you to make sure they are correct for your year.Mike
[Re: mopars4ever]
#61462
05/22/08 11:39 AM
05/22/08 11:39 AM
Brads has the correct stud but no nuts. I would just use a nut and shock washer from the parts store but half of the shock bushing rides on the nut. What does everyone else use?
[Re: mopars4ever]
#61464
05/22/08 01:04 PM
05/22/08 01:04 PM
Posts: 20,205 Park Forest, IL
slantzilla
Park Forest, IL
Is it a kind of shouldered nut? Maybe McMaster-Carr has something like it.
[Re: slantzilla]
#61465
05/22/08 01:59 PM
05/22/08 01:59 PM
Yes it is,if I uderstand you correctly. I tried fastenal (my neighbor) no dice. Will keep looking.
[Re: DirectSubjection]
#61468
05/22/08 08:47 PM
05/22/08 08:47 PM
They dont look long enough, but I certainly apreciate your effort. They need to be about 6" long.
#61469
05/22/08 10:24 PM
05/22/08 10:24 PM
too bad MoPar discontinued them. . could be worse tho, my duster came with some sort of "shock extension", the purpose of which i have zero clue.
#61470
05/22/08 11:07 PM
05/22/08 11:07 PM
Posts: 2,902 New Jersey Bada Bing
bremotorsports
Is there legitimate demand out there in "A-Body land" for this piece? I believe I may even have one or two NOS pieces, and thus could have one of my subcontractors reproduce this based on a pristine sample. I will now say "Let the people speak" Bill Rolik Sorry, but the NOS pieces would not be for sale.
[Re: bremotorsports]
#61471
05/23/08 01:56 AM
05/23/08 01:56 AM
Posts: 13,610 md
mopars4ever
md
The shock extensions are used for racing so the car will get added lift. Mike
#61472
05/23/08 10:17 AM
05/23/08 10:17 AM
Posts: 75,089 A Banana Republic near you.
JohnRR
Bill Rolik
it's for an a body bill , according to some aftermarket suppliers there is no market for a body parts .
i have to swap out the air shocks in my dart , i'm not even sure what these things look like ...
but if you make it they will buy them ...
