duster rear shock bolts #61453
05/22/08 08:50 AM
05/22/08 08:50 AM
Anonymous OP
Anonymous OP
I pulled the shock bolts off the old shocks to clean up and install new shocks yesterday. These are not just a regular bolt,and the threads were a litttle messed up,so I decided to replace them. No luck finding them. I used a thread chaser to clean up the threads,worked great. Now the nut on the shock side is trashed,apears to be of a softer alloy. Where can I get these? Or,where can I order complete new bolts? No luck at the part stores,rockauto,just suspension,fastener shop. What does everyone else do, I'm not the only one who replaces shocks. thanks for any help! John
Re: duster rear shock bolts #61454
05/22/08 09:01 AM
05/22/08 09:01 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Maybe Year One or another restoration supply house has shock hardware.
Re: duster rear shock bolts [Re: bobby66] #61455
05/22/08 09:23 AM
05/22/08 09:23 AM
Anonymous OP
Anonymous OP
No luck at yearone. I did see a shock hardware kit that was a couple regular bolts,nuts and the convex washers for another aplication for a mere $73! They sure like makin' money.
Re: duster rear shock bolts #61456
05/22/08 09:55 AM
05/22/08 09:55 AM
Anonymous OP
Anonymous OP
did you try MoPar? i'm sure they have what you need.
Re: duster rear shock bolts #61457
05/22/08 10:22 AM
05/22/08 10:22 AM
Anonymous OP
Anonymous OP
mopar has discontinued the parts.
Re: duster rear shock bolts #61458
05/22/08 10:27 AM
05/22/08 10:27 AM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
why wont a regular bolt work?
Re: duster rear shock bolts [Re: 05dakota] #61459
05/22/08 10:34 AM
05/22/08 10:34 AM
Anonymous OP
Anonymous OP
It's basically a 6" stud with a big stop in the middle(looks like a big washer but is machined as part of stud). One side goes through the trunk floor and the other is the shock side.
Re: duster rear shock bolts #61460
05/22/08 10:36 AM
05/22/08 10:36 AM
Anywhere the British Secret Se...
Moonraker Offline
Moonraker  Offline
Junkyard
Re: duster rear shock bolts [Re: Moonraker] #61461
05/22/08 11:11 AM
05/22/08 11:11 AM
md
mopars4ever Offline
mopars4ever  Offline
md
2071714 stud - www.bradsnosparts.com shows to have 4 of them. Sorry, nobody shows the nuts 152371. This was referenced to the 72 model year. Have Brads double check the numbers for you to make sure they are correct for your year.Mike
Re: duster rear shock bolts [Re: mopars4ever] #61462
05/22/08 11:39 AM
05/22/08 11:39 AM
Anonymous OP
Anonymous OP
Brads has the correct stud but no nuts. I would just use a nut and shock washer from the parts store but half of the shock bushing rides on the nut. What does everyone else use?
Re: duster rear shock bolts #61463
05/22/08 11:42 AM
05/22/08 11:42 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Post a pic of the old nut. Someone may have some laying around. Mike
Re: duster rear shock bolts [Re: mopars4ever] #61464
05/22/08 01:04 PM
05/22/08 01:04 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Is it a kind of shouldered nut? Maybe McMaster-Carr has something like it.
Re: duster rear shock bolts [Re: slantzilla] #61465
05/22/08 01:59 PM
05/22/08 01:59 PM
Anonymous OP
Anonymous OP
Yes it is,if I uderstand you correctly. I tried fastenal (my neighbor) no dice. Will keep looking.
Re: duster rear shock bolts #61466
05/22/08 07:55 PM
05/22/08 07:55 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I am going down to my shop Saturday. I can dig through the pile of stuff from my Duster and see if we kept the shock mounts when we put the ladder bar/coilovers in. PM me if you want them so I don't forget.
Re: duster rear shock bolts #61467
05/22/08 08:31 PM
05/22/08 08:31 PM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
These are replacements for one's in the shock plates - would they work?
Ride eternal, shiny and chrome
Re: duster rear shock bolts [Re: DirectSubjection] #61468
05/22/08 08:47 PM
05/22/08 08:47 PM
Anonymous OP
Anonymous OP
They dont look long enough, but I certainly apreciate your effort. They need to be about 6" long.
Re: duster rear shock bolts #61469
05/22/08 10:24 PM
05/22/08 10:24 PM
Anonymous OP
Anonymous OP
too bad MoPar discontinued them. . could be worse tho, my duster came with some sort of "shock extension",
the purpose of which i have zero clue.
Re: duster rear shock bolts #61470
05/22/08 11:07 PM
05/22/08 11:07 PM
New Jersey Bada Bing
bremotorsports Offline
Is there legitimate demand out there in "A-Body land" for this piece? I believe I may even have one or two NOS pieces, and thus could have one of my subcontractors reproduce this based on a pristine sample.
I will now say "Let the people speak"
Bill Rolik
Sorry, but the NOS pieces would not be for sale.
Re: duster rear shock bolts [Re: bremotorsports] #61471
05/23/08 01:56 AM
05/23/08 01:56 AM
md
mopars4ever Offline
mopars4ever  Offline
md
The shock extensions are used for racing so the car will get added lift. Mike
Re: duster rear shock bolts [Re: bremotorsports] #61472
05/23/08 10:17 AM
05/23/08 10:17 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Bill Rolik
it's for an a body bill , according to some aftermarket suppliers there is no market for a body parts .
i have to swap out the air shocks in my dart , i'm not even sure what these things look like ...
but if you make it they will buy them ...
