1st time degreeing cam?cam is now@103.5* ( UPDATED)
#614682
02/16/10 03:20 PM
02/16/10 03:20 PM
Posts: 1,365 elmira ny
hp340nos
elmira ny
motor is 340 stroker,ohio crankshaft 4" stroke crank,diamond dish pistons,herbert solid roller cam,pro gear 7 key timing set with tensioner,this is my 1st time degreeing a cam,i have a 11" moroso degree wheel,comp cam crank socket mounted tightly on the crank,ifound top dead center by using a positive stop rotating clockwise til it stopped, took reading on degree wheel,then turned it counterclockwise took another reading when it stopped, i then split the difference of the 2 readings and set the degree wheel to 0, i then set my indicator up on the deck surface with a pushrod contacting the indicator rotated clockwiseto find max lift ,then set the indicator to 0,rotated clockwise to .050 after max lift took a reading continued to turn clockwise to .050 before max lift took another reading.160*+80*=240*/2*=120*i am open to any suggestions as this is my 1st time degreeing a cam in.the cam is 108 lobe center installed at 104*,the cam was bought from moparts member and installed in his motor at 104* thanks again mike
Re: 1st timedegreeing cam?cam is at 120 what did i do wrong
[Re: maximum entropy]
#614684
02/16/10 03:59 PM
02/16/10 03:59 PM
Posts: 1,880 USA
Ron Silva
USA
Don't do what I just did. I set up on the #1 cylinder EXHAUST lobe. DOH!
The intake is the second lobe, not the first. And, you might come up with 120 if you did the exhaust.
SRT DEMON ONE SEAT
[Re: hp340nos]
#614687
02/16/10 06:17 PM
02/16/10 06:17 PM
Posts: 43,126 Bend,OR USA
Cab_Burge
yes i double checked that i was on the intake lobe not the exhaust lobe,what should i do to correct this?cam gear has up to +3/-3 degrees of adjustability.thanks mike
On most Cloyes double roller timing sets one tooth on the cam gear is 12 degrees of crankshaft travel, try moving the cam gear one tooth to the right of where it is now and redo the cam timing sequence Once you get the intake timing where your happy make sure and check the exahust lobe centers, it should be advanced as much as the intake lobe is, IE Intake (Max lift) Lobe Center is 105 ATDC on a 108 LSA cam the Exhaust Lobe Center should be at 111 BTDC If not the cam is not ground on the LSA the cam card says, return it to the cam company if it is not correct. BTW, those mulltiple keyway crank gears can be a real challenge to degree in correctly Like all things worth doing correctly, the first time is the hardest
[Re: hp340nos]
#614688
02/16/10 06:18 PM
02/16/10 06:18 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Verify that the dots/symbols are lined up correctly. You can use a speed square off the top of the block somewhere to give you a better visual center line to align the marks. Also note that every time you change the crank sprocket key way you have also changed TDC postions so TDC would need to be found again. If it still doesnt come clear, sometimes those degree wheels are marked funky. Go back to the basics, find .050 past max lift, then mark the degree wheel with a sharpie. Then find .050 before max lift and mark it too. Now look were both marks are on the degree wheel. Count each degree between the two, then divide by two. It should produce the same numbers. Rotate the engine around more than once recording each event. Sometimes its easy to loose a bit in slack or what ever. Keep doing it until you keep producing the same results. But remember about moving the crank keys..you gotta find the new TDC again, a bunch of people dont, its not worth the trouble of doing it then IMO. This is why I like the cam sprocket bushings.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: hp340nos]
#614689
02/16/10 06:19 PM
02/16/10 06:19 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Your 16* off that should be 1 tooth and the 3 degrees if I remember right(I think its 13 degrees per tooth) count the teeth and divide that into 360
[Re: 602heavy]
#614696
02/17/10 02:01 AM
02/17/10 02:01 AM
hp340nos
elmira ny
the timing marks seem to be lined up,im gonna rotate cam gear a tooth and see what happens.maybe timing dots are not located properly on the gears?
[Re: 602heavy]
#614699
02/17/10 12:09 PM
02/17/10 12:09 PM
MR_P_BODY
To save some time .............remove the front gear off the cam & get the intake lifter @ full lift , using degree wheel set the crank @ 106* ATDC , remove degree wheel , fit chain to crank sprocket with cam gear attached , eye up position of cam gear regards locating peg on cam , you can then rotate crank sprocket on keyway for best alignment with cam peg/gear , just makes life easier as opposed to removing degree wheel every time you gotta move sprocket around.
This is the procedure I use for setting up my gear drive on my small blocks... seems to make things easier and quicker.... JMO
[Re: hp340nos]
#614701
02/17/10 04:33 PM
02/17/10 04:33 PM
Posts: 1,200 UK
602heavy
UK
i verified tdc with piston stop then rotated cam gear 1 tooth counterclockwise 133* oops went wrong way,back through the whole process again went the other way clockwise 1 tooth from original postion came up with 147.5+66.5=214/2=107 ,i am getting close,cam is recommended to be installed at 104* i have some keyways on the cam gear i can move to try to get the other 3*,how close do you want it to be?looks like timing mark on the cam is marked 1 tooth off,marks are not inline.
You should be able to get within 1 degree , 2 degrees is no biggie but i would'nt want to go more than that.
[Re: hp340nos]
#614702
02/17/10 04:34 PM
02/17/10 04:34 PM
Bob_Coomer
Rock Springs
Whats the cam specs? I havent seen to many solid rollers want to be advanced to a 104 ICL. Unless its been ground on a 106 or something.... Do you care to post the cam specs.
[Re: Bob_Coomer]
#614703
02/17/10 04:40 PM
02/17/10 04:40 PM
Posts: 1,200 UK
602heavy
UK
You got me baffled here , maybe i'm missing the point somewhere (most of the time ) , but why would moving the crank sprocket loose TDC? , these multi keyed sprockets are meant to be moved around to help aid in degreeing the cam , just asking.
[Re: hp340nos]
#614704
02/17/10 04:42 PM
02/17/10 04:42 PM
MR_P_BODY
Thats why I said 1 tooth and 3 degrees in the earlier post... you moved it the 1 tooth and now you need to move it 3 more degrees on the sprocket .... isnt it fun
[Re: earthmover]
#614706
02/17/10 04:59 PM
02/17/10 04:59 PM
Posts: 1,200 UK
602heavy
UK
so mr p. if he moved it 1 more teeth it would be where he wants it right....or do you have to use the off set keys.....
One more tooth would be wayyyyy to much , moving the crank sprocket around should get the job done.
[Re: earthmover]
#614707
02/17/10 04:59 PM
02/17/10 04:59 PM
MR_P_BODY
No he has a sprocket that has 1, 2, or 3 degrees on it, if you move 1 tooth on the chain (sprocket) it will move it 13 degrees(might be 12)
[Re: MR_P_BODY]
#614708
02/17/10 06:14 PM
02/17/10 06:14 PM
hp340nos
elmira ny
the multi keys are on the cam gear not the crank gear.its a pro gear set 7 keyways on cam.mr pbody u hit it on the money,i will try the 3*advance on the cam gear and see what happens,cam is herbert billet solid roller part#ce6k, 246/254@.050 .585/.600 lift 108* lobe seperation,they recommend to install it to 104* ,they said it has 4*ground into it.motor is going into 88 dakota 3360#, motor is 418 9.6;1 compression street/strip,full ported polished x-heads flow 270@.600/172@.600,weiand x-celerator intake. 727 reverse pattern valve body,trans is ptc 4400 flash converter,3.91 gears.thanks mike
[Re: hp340nos]
#614709
02/17/10 09:14 PM
02/17/10 09:14 PM
hp340nos
elmira ny
[Re: hp340nos]
#614710
02/17/10 09:21 PM
02/17/10 09:21 PM
MR_P_BODY
[Re: hp340nos]
#614712
02/17/10 09:29 PM
02/17/10 09:29 PM
MR_P_BODY
does the 104* installed centerline seem right for this cam and my build?thanks again mike
Does to me if you need the torque(which most guys need) in a small block... specially in a stock stroke
[Re: MR_P_BODY]
#614713
02/17/10 09:52 PM
02/17/10 09:52 PM
Posts: 1,200 UK
602heavy
UK
You say you have no cam card? These are the valve events @ .050" 4* advanced. Intake opens-- 19* BTDC Intake closes-- 47* ABDC Exhaust opens-- 59* BBDC Exhaust closes-- 15* ATDC You can varify this along with installed ICL.
[Re: hp340nos]
#614714
02/18/10 12:22 AM
02/18/10 12:22 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Yep, with your 9.6 comp and 3400# 246*@ .050 Id want the ICL around 104* to 102* if intake valve clearence allows.
602,s Valve events are correct at a 104 ICL. How does he do that. mike
[Re: hp340nos]
#614716
02/18/10 09:02 AM
02/18/10 09:02 AM
MR_P_BODY
how do i go about checking the above cam measurements?will they fall into place once i get the cam at 104*icl?thanks again for any help. mike
With the degree wheel installed just like you did the cam C/L just start rotating the crank and check the points where the valve is then read the wheel... but you will need to move the dial indicator to the exhaust lobe when reading the exhaust events
[Re: hp340nos]
#614720
02/18/10 02:49 PM
02/18/10 02:49 PM
Posts: 1,200 UK
602heavy
UK
when checking cam events,i find tdc with piston stop,0 the degree wheel,now set-up the indicator.now do i find max lift say on the intake,then read the readings on the degree wheel?at what lift do i read the wheel?my wheel is moroso 11" marked 0-180 then 180 back to 0.
Varify TDC with piston stop & zero degree wheel ,turn motor over & zero dial indicator when #1 intake lifter is on base circle of lobe , continue to rotate motor & stop when dial indicator measures .050" lift , if you shoot past just back the crank up (.100") , read degree wheel which should show valve event @ 19.5* before top dead centre , continue to turn the motor & read off degree wheel @ full lift (103.5* ATDC)) , continue to turn motor & read off degree wheel when lifter is .050" before seated (46.5* ABDC) , if all works out you're good to go.
Sport 440 , you're too modest.
[Re: hp340nos]
#614722
02/18/10 03:10 PM
02/18/10 03:10 PM
Posts: 1,200 UK
602heavy
UK
my degree wheel has intake open/intake closed marked in red as well as exhaust open/closed marked.its also marked 0-180 then180-0.how do i know where btdc ,atdc etc are should i just watch the piston movement,thanks mike
It does get confusing , you just gotta count backwards , take a step back & figure where the piston is in relationship with degree wheel markings , you've come this far i'm sure you will sort it , as said , you are not alone regards the confusion with those degree wheels , if the maths is all funnky then check again , it will come good.
[Re: hp340nos]
#614724
02/18/10 06:45 PM
02/18/10 06:45 PM
Cab_Burge
im heading out to work now i will check it out in the mornin,thanks again everyone mike
some degree wheels are marked with TDC =0 (top dead center), 90 degrees after TDC, BDC(bottom dead center) = 180 after top dead center and some are marked 90 again BTDC(before top dead center or ABDC after bottom dead center) ) or 270, 270 = ATDC(after top dead center) Some degree wheels are marked both ways Keep in mind that all 90 degree V8 motors have two pistons that are at TDC at the same time, two at 90 ATDC, two at BDC and two at 90 ABDC or 90 degrees BTDC. Not all of them are at all four major points of the crankshaft revoluton at the same time, I think anyways My point is there are two pistons at TDC at the same time, #1 is in overlap beginning the #1 intake stroke and finishing the exhaust stroke while #6 is at the top of the compression stroke and starting down on the power stroke Another thing to keep in mind is the camshaft gear and cam move 1/2 the degrees that the crankshafts moves when rotating the crankshaft AND we always measure camshaft timing in CRANKSHAFT degrees HUH I hope this helps and makes sense Don't forget to check piston to valve clearances before starting the motor Especially on a roller cam like you have
[Re: Cab_Burge]
#614725
02/18/10 08:06 PM
02/18/10 08:06 PM
Posts: 1,200 UK
602heavy
UK
This is making my head hurt , as you say , fireing order is 90 crank degrees appart.
Re: 1st timedegreeing cam?cam is now@103.5*icl
[Re: 602heavy]
#614726
02/20/10 09:47 PM
02/20/10 09:47 PM
hp340nos
elmira ny
cam is all degree/d in @103.5*icl now,checked all cam events and everything matches up to specs 602heavy had listed,thanks to everyone that helped.mike d.
[Re: hp340nos]
#614727
02/20/10 10:06 PM
02/20/10 10:06 PM
Posts: 1,489 St. Louis Mo.
10 o to go
"Happy Don"
"Happy Don"
St. Louis Mo.
All those key ways .What happened to the single key way and the few keys that you would use . I remember the crank used them also but that double the degrees . Hope you found a good number , We always screw them in advance 99 to 102 on S.B cams. Dr
2009 418" build dan smith built
new 9.96 131.82
6.23 108
1.30 60 foot
best to date 9/15/09
8in 727 430 dana 2860 lb 3040 lb w driver
