Page 1 of 3 1 2 3
1st time degreeing cam?cam is now@103.5* ( UPDATED) #614682
02/16/10 03:20 PM
02/16/10 03:20 PM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
motor is 340 stroker,ohio crankshaft 4" stroke crank,diamond dish pistons,herbert solid roller cam,pro gear 7 key timing set with tensioner,this is my 1st time degreeing a cam,i have a 11" moroso degree wheel,comp cam crank socket mounted tightly on the crank,ifound top dead center by using a positive stop rotating clockwise til it stopped, took reading on degree wheel,then turned it counterclockwise took another reading when it stopped, i then split the difference of the 2 readings and set the degree wheel to 0, i then set my indicator up on the deck surface with a pushrod contacting the indicator rotated clockwiseto find max lift ,then set the indicator to 0,rotated clockwise to .050 after max lift took a reading continued to turn clockwise to .050 before max lift took another reading.160*+80*=240*/2*=120*i am open to any suggestions as this is my 1st time degreeing a cam in.the cam is 108 lobe center installed at 104*,the cam was bought from moparts member and installed in his motor at 104* thanks again mike
Re: 1st timedegreeing cam?cam is at 120 what did i do wrong [Re: hp340nos] #614683
02/16/10 03:54 PM
02/16/10 03:54 PM
organ
maximum entropy Offline
organ
sounds like you did it correctly, and you're a tooth off.
Re: 1st timedegreeing cam?cam is at 120 what did i do wrong [Re: maximum entropy] #614684
02/16/10 03:59 PM
02/16/10 03:59 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
Don't do what I just did. I set up on the #1 cylinder EXHAUST lobe. DOH!
The intake is the second lobe, not the first. And, you might come up with 120 if you did the exhaust.
SRT DEMON ONE SEAT
Re: 1st timedegreeing cam?cam is at 120 what did i do wrong [Re: Ron Silva] #614685
02/16/10 04:09 PM
02/16/10 04:09 PM
organ
organ
fergot to mention that- thanks.
Re: 1st timedegreeing cam?cam is at 120 what did i do wrong [Re: maximum entropy] #614686
02/16/10 06:06 PM
02/16/10 06:06 PM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
yes i double checked that i was on the intake lobe not the exhaust lobe,what should i do to correct this?cam gear has up to +3/-3 degrees of adjustability.thanks mike
Re: 1st timedegreeing cam?cam is at 120 what did i do wrong [Re: hp340nos] #614687
02/16/10 06:17 PM
02/16/10 06:17 PM
Cab_Burge Online work
Cab_Burge  Online Work
On most Cloyes double roller timing sets one tooth on the cam gear is 12 degrees of crankshaft travel, try moving the cam gear one tooth to the right of where it is now and redo the cam timing sequence Once you get the intake timing where your happy make sure and check the exahust lobe centers, it should be advanced as much as the intake lobe is, IE Intake (Max lift) Lobe Center is 105 ATDC on a 108 LSA cam the Exhaust Lobe Center should be at 111 BTDC If not the cam is not ground on the LSA the cam card says, return it to the cam company if it is not correct. BTW, those mulltiple keyway crank gears can be a real challenge to degree in correctly Like all things worth doing correctly, the first time is the hardest
Re: 1st timedegreeing cam?cam is at 120 what did i do wrong [Re: hp340nos] #614688
02/16/10 06:18 PM
02/16/10 06:18 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Verify that the dots/symbols are lined up correctly. You can use a speed square off the top of the block somewhere to give you a better visual center line to align the marks. Also note that every time you change the crank sprocket key way you have also changed TDC postions so TDC would need to be found again.
If it still doesnt come clear, sometimes those degree wheels are marked funky.
Go back to the basics, find .050 past max lift, then mark the degree wheel with a sharpie. Then find .050 before max lift and mark it too. Now look were both marks are on the degree wheel. Count each degree between the two, then divide by two. It should produce the same numbers.
Rotate the engine around more than once recording each event. Sometimes its easy to loose a bit in slack or what ever. Keep doing it until you keep producing the same results.
But remember about moving the crank keys..you gotta find the new TDC again, a bunch of people dont, its not worth the trouble of doing it then IMO.
This is why I like the cam sprocket bushings.
Re: 1st timedegreeing cam?cam is at 120 what did i do wrong [Re: hp340nos] #614689
02/16/10 06:19 PM
02/16/10 06:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Your 16* off that should be 1 tooth and the 3 degrees
if I remember right(I think its 13 degrees per tooth)
count the teeth and divide that into 360
Re: 1st timedegreeing cam?cam is at 120 what did i do wrong [Re: Cab_Burge] #614690
02/16/10 06:19 PM
02/16/10 06:19 PM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
i will try that cab,that would make sense.thanks mike
Re: 1st timedegreeing cam?cam is at 120 what did i do wrong [Re: hp340nos] #614691
02/16/10 06:22 PM
02/16/10 06:22 PM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
i will count the teeth alsothanks guys
Re: 1st timedegreeing cam?cam is at 120 what did i do wrong [Re: Ron Silva] #614692
02/16/10 06:39 PM
02/16/10 06:39 PM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
yep good point, and for a hemi its the the opposite the first lobe is intake
MOPAR OR NO CAR
Re: 1st timedegreeing cam?cam is at 120 what did i do wrong [Re: hemigod426] #614693
02/16/10 08:12 PM
02/16/10 08:12 PM
UK
602heavy Offline
602heavy  Offline
UK
Plenty ways to skin a cat.............the most accurate in my opininon is to degree the lobe @ .050" lift open/close checking against cam card , from these #s lobe intake centreline will fall into place.
Re: 1st timedegreeing cam?cam is at 120 what did i do wrong [Re: 602heavy] #614694
02/16/10 09:07 PM
02/16/10 09:07 PM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
602 heavy, i didnt get a cam card with it it was second hand,i called herbert for the specs.
Re: 1st timedegreeing cam?cam is at 120 what did i do wrong [Re: hp340nos] #614695
02/16/10 09:57 PM
02/16/10 09:57 PM
UK
602heavy Offline
602heavy  Offline
UK
To save some time .............remove the front gear off the cam & get the intake lifter @ full lift , using degree wheel set the crank @ 106* ATDC , remove degree wheel , fit chain to crank sprocket with cam gear attached , eye up position of cam gear regards locating peg on cam , you can then rotate crank sprocket on keyway for best alignment with cam peg/gear , just makes life easier as opposed to removing degree wheel every time you gotta move sprocket around.
Re: 1st timedegreeing cam?cam is at 120 what did i do wrong [Re: 602heavy] #614696
02/17/10 02:01 AM
02/17/10 02:01 AM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
the timing marks seem to be lined up,im gonna rotate cam gear a tooth and see what happens.maybe timing dots are not located properly on the gears?
Re: 1st timedegreeing cam?cam is at 120 what did i do wrong [Re: hp340nos] #614697
02/17/10 02:41 AM
02/17/10 02:41 AM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
do i rotate it one tooth clockwise or counterclockwise.
Re: 1st timedegreeing cam?cam is at 120 what did i do wrong [Re: hp340nos] #614698
02/17/10 02:48 AM
02/17/10 02:48 AM
To advance the cam rotate the cam gear counter clockwise That will move the intake lobe closer to TDC, which advances the cam Don't forget to to verify TDC before moving the cam
Re: 1st timedegreeing cam?cam is at 120 what did i do wrong [Re: 602heavy] #614699
02/17/10 12:09 PM
02/17/10 12:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
This is the procedure I use for setting up my gear
drive on my small blocks... seems to make things
easier and quicker.... JMO
Re: 1st timedegreeing cam?cam is at 120 what did i do wrong [Re: MR_P_BODY] #614700
02/17/10 02:20 PM
02/17/10 02:20 PM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
i verified tdc with piston stop then rotated cam gear 1 tooth counterclockwise 133* oops went wrong way,back through the whole process again went the other way clockwise 1 tooth from original postion came up with 147.5+66.5=214/2=107 ,i am getting close,cam is recommended to be installed at 104* i have some keyways on the cam gear i can move to try to get the other 3*,how close do you want it to be?looks like timing mark on the cam is marked 1 tooth off,marks are not inline.
Re: 1st timedegreeing cam?cam is at 120 what did i do wrong [Re: hp340nos] #614701
02/17/10 04:33 PM
02/17/10 04:33 PM
UK
602heavy Offline
602heavy  Offline
UK
You should be able to get within 1 degree , 2 degrees is no biggie but i would'nt want to go more than that.
Page 1 of 3 1 2 3
