Mopar Cast aluminum valve covers #614322
02/15/10 11:01 PM
02/15/10 11:01 PM
Nebraska
Schluck02 Offline OP
Nebraska
I was wondering what to use and how to get the holes for pcv or breathers open on the cast aluminum valve covers. do you just use a punch and hammer or what?
Re: Mopar Cast aluminum valve covers [Re: Schluck02] #614323
02/15/10 11:36 PM
02/15/10 11:36 PM
Colo Springs, Co
dragaddict Offline
super street
dragaddict  Offline
super street
Colo Springs, Co
You can punch them out but iy is rough and never really seals around the hole. Any machine shop can bore the hole to the correct size cleanly but you will have to pay some labor and maybe setup time.
Re: Mopar Cast aluminum valve covers [Re: dragaddict] #614324
02/15/10 11:38 PM
02/15/10 11:38 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
How about a hole saw bit?
Re: Mopar Cast aluminum valve covers [Re: Neil] #614325
02/16/10 12:11 AM
02/16/10 12:11 AM
Cookeville
Chilort Offline
Will Work For Mopars
Chilort  Offline
Cookeville
I used a drill to start the hole and then a die grinder with an aluminum bit to get what I wanted. I'm not at all thrilled. I know folks have to install various breathers and PCVs and I have no idea why these aren't punched out from the factory.
Re: Mopar Cast aluminum valve covers [Re: Schluck02] #614326
02/16/10 12:12 AM
02/16/10 12:12 AM
SW MO
closer9 Offline
closer9  Offline
SW MO
Each has one hole already open, and you can get the grommets to fit these holes for PCV and breather. Seems like I got mine from Summit. That is all I'm using. I just pull the breather to add oil.
EDIT: Here they are at Summit
http://www.summitracing.com/parts/DCC-5249642/
Daily:
'19 Frontier 4WD
Belle:
'67 Belvedere Convertible, 318/727 in Go ManGo!
Other:
'64 C10, 283/3 on the tree
Re: Mopar Cast aluminum valve covers [Re: closer9] #614327
02/16/10 01:10 AM
02/16/10 01:10 AM
NE
moparpoolman Offline
NE
Yup, thats what I did. Rubber grommet for pcv valve in one side and instead of the cap they come with get a screw in breather cap,NICE. I know someone that just put the caps they come with on both sides, started the motor and without venting the crankcase the valley pan swelled up like a jiffy pop.
